17-4 PH Stainless Steel: Properties and Yield Strength
Written byMegan Conniff
19 min read
Published July 16, 2026Updated August 21, 2026
17-4 PH stainless steel is a precipitation hardening martensitic stainless steel alloy recognized for its exceptional mechanical performance across engineering and industrial applications. 17-4 PH stainless steel derives its designation from its chemical composition, containing 17% chromium and 4% nickel. Copper additions ranging from 3% to 5% contribute directly to its age-hardening capability. The combination of chromium, nickel, and copper gives the alloy a distinct advantage over conventional martensitic stainless steel grades in terms of strength and corrosion resistance.
17-4 PH stainless steel achieves a yield strength ranging from 105 ksi to 185 ksi, depending on the heat treatment condition applied. The alloy reaches a hardness of to 44 HRC in its H900 condition, making it one of the hardest grades among precipitation hardening stainless steels. Its corrosion resistance performs comparably to 304 stainless steel in most atmospheric and mildly corrosive environments. Machinability ratings place it at 45% to 50% relative to free-machining steels. Heat treatment through aging at temperatures ranging from 900°F to 1,150°F allows manufacturers to tailor their mechanical properties for specific application demands.
What Is 17-4 PH Stainless Steel?
17-4 PH stainless steel is a precipitation hardening martensitic stainless steel alloy known for delivering high strength, moderate corrosion resistance, and excellent mechanical performance across demanding engineering applications. The designation "17-4" directly references its nominal chemical composition, where 17 illustrates 17% chromium content, and 4 illustrates 4% nickel content. Copper additions ranging from 3% to 5%, alongside niobium (columbium), complete the alloy's core chemistry and enable its age-hardening response.
Precipitation hardening distinguishes 17-4 PH from conventional stainless steels through its heat treatment mechanism. Standard austenitic stainless steels (304 and 316) rely on cold working to increase strength, achieving yield strengths of 30 ksi to 45 ksi in annealed conditions. Precipitation hardening, by contrast, strengthens the alloy through a controlled aging process at temperatures ranging from 900°F to 1,150°F, allowing yield strengths to reach 170 ksi to 200 ksi. The aging process precipitates copper-rich phases within the martensitic matrix, producing a measurable increase in hardness and tensile strength without significantly compromising the alloy's corrosion resistance.
What Is the Chemical Composition of 17-4 PH Stainless Steel?
17-4 PH stainless steel consists of a precisely balanced combination of alloying elements that collectively define its mechanical and corrosion-resistant properties. Chromium forms the largest portion at 15.5% to 17.5%, establishing the foundational corrosion resistance of the alloy. Nickel content ranging from 3% to 5% stabilizes the martensitic structure, while copper additions from 3% to 5% drive the precipitation hardening response during aging heat treatments. Niobium and columbium, present from 0.15% to 0.45%, refine grain structure and prevent sensitization. Carbon is intentionally kept below 0.07% to preserve toughness and weldability.
The chemical composition of 17-4 PH stainless steel is shown in the table below.
What Are the Main 17-4 PH Stainless Steel Properties?
The main 17-4 PH stainless steel properties are listed below.
  • Yield Strength: 17-4 PH stainless steel achieves yield strength ranging from 170 ksi to 185 ksi in its H900 condition. The value adjusts across aging temperatures, dropping to 105 ksi in the H1150 condition.
  • Hardness: The alloy reaches a maximum hardness of 44 HRC in its H900 condition. Hardness decreases progressively as aging temperature increases toward 1,150°F.
  • Corrosion Resistance: 17-4 PH stainless steel performs comparably to 304 stainless steel in atmospheric and mildly corrosive environments. The 15.5% to 17.5% chromium content forms a stable passive oxide layer on the surface.
  • Machinability: The alloy registers a machinability rating of 45% to 50% relative to free-machining steels. Carbide tooling at controlled cutting speeds produces the most precise results.
  • Heat Treatment Capability: Aging temperatures ranging from 900°F to 1,150°F allow manufacturers to adjust mechanical properties. The process does not alter the alloy's core chemical composition.
What Mechanical Properties Does 17-4 Stainless Steel Have?
17-4 PH stainless steel demonstrates a broad range of mechanical properties that vary depending on the heat treatment condition applied. The H900 condition delivers the highest strength values, while conditions from H1025 to H1150 progressively trade strength for improved ductility and toughness. Tensile strength peaks at 190 ksi to 200 ksi in the H900 condition, while elongation values increase from 10% at H900 to 16% at H1150. Fatigue resistance reaches an endurance limit of 75 ksi to 80 ksi under fully reversed bending conditions, making the alloy reliable in cyclic loading environments (aerospace brackets, pump shafts, and valve components).
The mechanical properties that 17-4 PH stainless steel has are shown in the table below.
What Thermal Properties Affect 17-4 PH Stainless Steel Performance?
The thermal properties that affect 17-4 PH stainless steel performance are listed below.
  • Thermal Conductivity: 17-4 PH stainless steel registers a thermal conductivity of 17.8 W/m·K at room temperature. The value remains relatively stable across moderate temperature ranges, supporting consistent heat dissipation in structural components (aerospace brackets and pump housings).
  • Thermal Expansion: The alloy exhibits a coefficient of thermal expansion of 10.8 µm/m·°C from 0°C to 100°C. Dimensional changes from thermal cycling must be accounted for in precision assemblies (turbine seals and close-tolerance valve components).
  • Melting Point: 17-4 PH stainless steel melts at a temperature ranging from 1,400°C to 1,440°C. The melting range reflects the influence of its multi-element alloying composition.
  • Maximum Service Temperature: The alloy retains adequate mechanical properties at service temperatures to 316°C (600°F). Prolonged exposure beyond the temperature limit causes over-aging and strength reduction (fasteners and structural frames in high-temperature enclosures).
  • Specific Heat Capacity: 17-4 PH stainless steel carries a specific heat capacity of 486 J/kg·K. The value governs the rate at which the alloy absorbs and releases heat during thermal cycling (heat exchangers and thermally loaded structural parts).
What Corrosion Resistance Properties Does 17-4 PH Stainless Steel Provide?
17-4 PH stainless steel provides moderate to good corrosion resistance across a range of environments, driven by its 15.5% to 17.5% chromium content, which forms a stable passive oxide layer on the alloy surface. The passive layer regenerates when damaged, offering continuous protection against oxidation and moisture-induced degradation. Resistance to atmospheric corrosion places 17-4 PH stainless steel in a performance range comparable to 304 stainless steel, making it reliable in outdoor structural and industrial environments. In chemical environments, 17-4 PH stainless steel resists mild acids and alkaline solutions but exhibits reduced resistance in chloride-rich conditions (hydrochloric acid and sulfuric acid environments). Against carbon steel, 17-4 PH stainless steel demonstrates significantly superior corrosion resistance, as carbon steel lacks a passive chromium oxide layer entirely. Compared to standard martensitic stainless steels (410 and 420 grades), 17-4 PH stainless steel outperforms due to its higher chromium content and copper additions, which stabilize the passive layer across a broader range of corrosive conditions.
What Magnetic Properties Does 17-4 PH Stainless Steel Have?
17-4 PH stainless steel is a ferromagnetic alloy, exhibiting measurable magnetic response in heat treatment conditions. The magnetic behavior originates from its martensitic crystal structure, which contains a body-centered tetragonal (BCT) lattice arrangement that aligns magnetic domains under an applied field. Unlike austenitic stainless steels (304 and 316), which carry a face-centered cubic (FCC) structure and remain largely non-magnetic, the martensitic structure of 17-4 PH stainless steel produces a relative magnetic permeability ranging from 60 to 100, depending on condition and applied field strength. The H900 condition applies aging at 900°F, producing the highest hardness and the strongest magnetic response due to the fully developed martensitic matrix. Aging temperature increases toward the H1150 condition at 1,150°F, causing the matrix to undergo partial relaxation, slightly increasing magnetic permeability. The ferromagnetic nature of the alloy makes it applicable in magnetic retention components (sensor housings and actuator parts) but restricts its use in magnetically sensitive environments (MRI-adjacent equipment and precision navigation instruments).
Does 17-4 PH Stainless Steel Exhibit Martensitic Magnetic Properties?
Yes, 17-4 PH stainless steel exhibits martensitic magnetic properties. The alloy's body-centered tetragonal (BCT) crystal structure arranges iron atoms in a configuration that supports magnetic domain alignment, producing a consistently ferromagnetic response. The chromium content of 15.5% to 17.5% and nickel content of 3% to 5% do not suppress the martensitic change, preserving the magnetic behavior across aging conditions. Relative magnetic permeability ranges from 60 to 100, depending on the heat treatment condition applied. The H900 condition produces the strongest magnetic response, registering hardness values to 44 HRC alongside peak permeability. Higher aging temperatures (H1025 and H1150) reduce permeability incrementally due to matrix relaxation. The martensitic magnetic behavior makes 17-4 PH stainless steel applicable in components requiring magnetic retention (actuator housings and sensor brackets) but unsuitable for magnetically neutral environments.
How Does Heat Treatment Affect 17-4 PH Stainless Steel?
Heat treatment affects 17-4 PH stainless steel by controlling the precipitation of copper-rich phases within the martensitic matrix, directly determining its mechanical performance. The process begins with solution annealing at 1,038°C (1,900°F), where the alloy reaches a fully austenitic state before quenching to room temperature, which forms the martensitic structure. Aging follows at temperatures ranging from 900°F to 1,150°F, precipitating copper-rich particles that block dislocation movement and increase strength. The duration of aging at each condition ranges from one hour to four hours, depending on the target mechanical properties.
The H900 condition, applied at 900°F for one hour, delivers the highest yield strength at 170 ksi to 185 ksi and hardness to 44 HRC. The H1025 condition, aged at 1,025°F, reduces yield strength to 155 ksi while improving toughness and ductility for structural applications (marine hardware and chemical processing components). The H1150 condition, applied at 1,150°F, further reduces strength to 105 ksi but maximizes elongation at 16%, making it preferable for forming operations. Manufacturers select aging conditions based on the mechanical property balance required, demonstrating the precision offered by heat treatment.
What Are Common Heat Treatment Conditions for 17-4 PH Stainless Steel?
17-4 PH stainless steel undergoes aging at defined temperature conditions, each producing a distinct balance of strength, ductility, and toughness. Lower aging temperatures (H900) favor maximum strength and hardness, while higher temperatures (H1025 to H1150) progressively improve ductility and impact toughness at the cost of yield strength. The copper-rich precipitates formed during aging directly control the degree of strengthening achieved at each condition. Grain boundary coherency of the precipitates diminishes at higher aging temperatures, reducing hardness but increasing resistance to fracture. The selection of a specific condition depends on the mechanical demands and environmental exposure of the target application.
The common heat treatment conditions for 17-4 PH stainless steel are shown in the table below.
How does Aging Improve 17-4 Stainless Steel Properties?
Aging improves 17-4 PH stainless steel properties by triggering the precipitation of copper-rich particles within the martensitic matrix, directly increasing strength and hardness. The copper atoms, supersaturated within the matrix after solution annealing, nucleate into coherent epsilon-copper particles during aging. The particles obstruct dislocation movement across the matrix, producing measurable increases in yield strength and hardness without requiring additional cold working. Yield strength increases from 100 ksi in the solution-annealed condition to 170 ksi to 185 ksi after aging at 900°F. Hardness rises correspondingly from 30 HRC to a peak of 44 HRC at the H900 condition. Fatigue resistance reaches an endurance limit of 75 ksi to 80 ksi under fully reversed bending conditions, making the alloy reliable in cyclic loading applications (aerospace shafts and pump impellers). The degree of improvement diminishes at higher aging temperatures (H1025 to H1150), where coarsening of copper precipitates reduces their effectiveness as dislocation barriers.
Can 17-4 PH Stainless Steel be Heat Treated multiple times?
Yes, 17-4 PH stainless steel can be heat-treated multiple times. The process requires re-solution annealing at 1,038°C (1,900°F) before each subsequent aging cycle to dissolve previously formed precipitates and restore the supersaturated martensitic matrix. Repeated re-solution annealing cycles carry engineering limitations, as prolonged exposure at annealing temperatures promotes austenitic grain growth, reducing toughness and fatigue resistance. Each additional cycle risks dimensional changes due to thermal expansion and contraction, affecting tight-tolerance components (precision shafts and aerospace fasteners). Repeated aging without prior re-solution annealing causes precipitate coarsening, reducing yield strength below the target condition values. Industry practice limits re-heat treatment cycles to two to three repetitions, beyond which grain boundary degradation becomes measurable. Manufacturers conduct hardness testing after each cycle to verify that mechanical properties remain within the specification range of the target heat treatment condition.
What is the Yield Strength of 17-4 PH Stainless Steel?
The yield strength of 17-4 PH stainless steel ranges from 115 ksi to 200 ksi, depending on the heat treatment condition applied. The H900 condition delivers the highest yield strength at 170 ksi to 200 ksi, achieved through aging at 900°F for one hour. The H1025 condition reduces yield strength to 145 ksi to 155 ksi, balancing strength with improved toughness. The H1150 condition further reduces yield strength to 115 ksi to 125 ksi, maximizing ductility and formability for complex part geometries.
Aging temperature directly governs the size and coherency of copper-rich precipitates within the martensitic matrix, controlling the degree of yield strength achieved. Lower aging temperatures produce finer, coherent precipitates that obstruct dislocation movement more effectively, generating higher yield strength values. Higher aging temperatures coarsen the precipitates, reducing their effectiveness as dislocation barriers and lowering yield strength. Processing variables (cold working before aging and solution annealing duration) introduce additional yield strength variation of 5% to 10% from nominal condition values.
Which Factors Affect the Yield Strength of 17-4 PH Stainless Steel?
The factors that affect the yield strength of 17-4 PH stainless steel are listed below.
  • Aging Temperature: Lower aging temperatures (900°F to 1,025°F) produce finer copper-rich precipitates that obstruct dislocation movement more effectively. Higher temperatures (1,075°F to 1,150°F) coarsen the precipitates, reducing yield strength from 200 ksi to 115 ksi.
  • Aging Duration: Prolonged aging beyond the recommended one hour to four hours causes over-aging, where precipitate coarsening reduces yield strength below target condition values. Insufficient aging duration leaves copper atoms partially supersaturated, preventing a full precipitation hardening response.
  • Cold Working: Cold working before aging introduces additional dislocations into the martensitic matrix, increasing yield strength by 5% to 15% above nominal aged condition values. The degree of cold work applied determines the magnitude of the additional strength contribution.
  • Solution Annealing Quality: Incomplete dissolution of copper atoms during solution annealing at 1,038°C reduces the volume fraction of precipitates formed during aging, lowering achievable yield strength. Proper annealing ensures full supersaturation of the matrix before the aging cycle begins.
  • Chemical Composition Variation: Copper content deviating from the 3% to 5% nominal range directly reduces the precipitation hardening response, affecting final yield strength by 5% to 10%. Nickel content variation from the 3% to 5% range further influences martensitic stability and strength response.
  • Surface Condition: Surface defects (scratches and machining marks) act as stress concentration points, reducing the effective yield strength of finished components under applied loads. Smooth surface finishes achieved through grinding or polishing maintain yield strength integrity across the component cross-section.
How Does 17–4 PH Stainless Steel Compare to Other Stainless Steels in Strength?
17-4 PH stainless steel delivers significantly higher yield strength compared to standard austenitic and duplex stainless steel grades. The precipitation hardening mechanism produces yield strengths from 170 ksi to 200 ksi in the H900 condition, far exceeding the 30 ksi to 45 ksi range of annealed 304 stainless steel. Duplex grades (2205) achieve yield strengths of 65 ksi to 90 ksi, placing them between austenitic and precipitation hardening grades in terms of strength performance.
The comparison between 17-4 PH stainless steel and other stainless steels in terms of strength is shown in the table below.
Does 17-4 PH Stainless Steel Maintain Strength at Elevated Temperatures?
Yes, 17-4 PH stainless steel maintains strength at elevated temperatures. The alloy retains adequate mechanical properties at continuous service temperatures to 316°C (600°F), making it reliable in moderately high-temperature applications (exhaust components and pressurized valve assemblies). Yield strength remains relatively stable from room temperature to 260°C (500°F), with minimal reduction in mechanical performance. Exposure beyond 316°C initiates over-aging of copper-rich precipitates, causing progressive yield strength reduction below condition-specific values. Prolonged service at temperatures exceeding 370°C (700°F) accelerates precipitate coarsening, dropping yield strength toward solution-annealed condition values of 100 ksi. Cryogenic performance remains acceptable, with the alloy retaining toughness at temperatures as low as minus 73°C (minus 100°F), making it applicable in low-temperature structural components (cryogenic valve bodies and aerospace brackets).
What Are the Main Advantages of 17-4 PH Stainless Steel?
17-4 PH stainless steel offers a combination of high yield strength, moderate corrosion resistance, and reliable machinability that distinguishes it from conventional stainless steel grades. Yield strength ranging from 170 ksi to 185 ksi in the H900 condition surpasses standard austenitic grades (304 and 316) by a factor of 4 to 5 times. Corrosion resistance, driven by 15.5% to 17.5% chromium content, performs comparably to 304 stainless steel across atmospheric and mildly corrosive environments. Machinability ratings of 45% to 50% relative to free-machining steels allow precise component fabrication using carbide tooling.
Heat treatment further extends the performance advantages of 17-4 PH stainless steel by allowing manufacturers to tailor mechanical properties to specific application demands. The aging process at temperatures ranging from 900°F to 1,150°F adjusts yield strength, hardness, and ductility without altering the alloy's core chemical composition. Components aged to the H900 condition achieve hardness to 44 HRC, reducing wear in high-contact applications (aerospace bushings and valve seats). The ability to machine the alloy in its solution-annealed condition before aging minimizes tool wear and improves dimensional accuracy in finished components.
"Designing with 17-4 PH requires looking past the peak numbers of the H900 condition to consider real-world manufacturing tolerances and process limitations. True optimization happens when you balance part geometry with the proper aging temper (such as H1025 or H1150) to mitigate hydrogen embrittlement and stress corrosion cracking while keeping tool wear under control. Relying blindly on standard text-book values without accounting for post-weld microstructural changes or thermal expansion can easily break a tight-tolerance precision design."
What Limitations Should Engineers Consider when Using 17-4 PH Stainless Steel?
The limitations engineers should consider when using 17-4 PH stainless steel are listed below.
  • Chloride Susceptibility: 17-4 PH stainless steel exhibits reduced resistance to pitting and crevice corrosion in chloride-rich environments (seawater and coastal industrial atmospheres). Protective coatings or alternative alloy selection are necessary for fully submerged saltwater applications.
  • Limited High-Temperature Performance: The alloy loses mechanical strength at continuous service temperatures exceeding 316°C (600°F) due to over-aging of copper-rich precipitates. Applications requiring sustained elevated temperature performance demand alternative alloy grades (Inconel 718 and A286).
  • Hydrogen Embrittlement Risk: 17-4 PH stainless steel in the H900 condition exhibits susceptibility to hydrogen embrittlement under high-stress and hydrogen-rich environments. Higher aging conditions (H1025 and H1150) reduce embrittlement risk at the cost of yield strength.
  • Welding Complexity: Welding 17-4 PH stainless steel requires post-weld heat treatment to restore mechanical properties in the heat-affected zone. Improper welding procedures reduce toughness and corrosion resistance in weld regions.
  • Cost Consideration: 17-4 PH stainless steel carries a material cost ranging from [$3 to $8] per pound, exceeding standard austenitic grades (304 and 316) by 20% to 40%.
  • Magnetic Restrictions: The ferromagnetic nature of 17-4 PH stainless steel restricts its use in magnetically sensitive environments (MRI-adjacent assemblies and precision navigation instruments).
Is 17-4 PH Stainless Steel Susceptible to Stress Corrosion Cracking?
Yes, 17-4 PH stainless steel is susceptible to stress corrosion cracking (SCC). The H900 condition, delivering yield strength of 170 ksi to 185 ksi, presents the highest SCC susceptibility due to its fully hardened martensitic matrix and elevated residual stress levels. Chloride-rich environments (coastal atmospheres and seawater exposure) accelerate SCC initiation at stress concentrations (notches, threads, and weld toes). Higher aging conditions (H1025 and H1150) reduce SCC susceptibility by lowering residual stress levels and improving matrix toughness, at the cost of yield strength. Threshold stress intensity values for SCC in 17-4 PH stainless steel range from 20 ksi to 50 ksi, depending on the heat treatment condition and environment. Engineers mitigate SCC risk through surface treatments (shot peening and electropolishing), protective coatings, and selecting higher aging conditions for chloride-exposed components.
How Does 17-4 PH Stainless Steel Compare with Carbon Steel (CS)?
17-4 PH stainless steel and Carbon Steel (CS) differ fundamentally in mechanical performance, corrosion resistance, and application suitability. 17-4 PH stainless steel achieves a yield strength ranging from 170 ksi to 185 ksi in the H900 condition, while carbon steel (1045 grade) delivers a yield strength of 60 ksi to 90 ksi in the normalized condition. The chromium content of 15.5% to 17.5% in 17-4 PH stainless steel forms a passive oxide layer absent in carbon steel, providing superior atmospheric and chemical corrosion resistance. Material cost differentiates the two grades significantly, with carbon steel ranging from [$0.50 to $1.50] per pound against 17-4 PH stainless steel at [$3 to $8] per pound.
The comparison between 17-4 PH stainless steel and Carbon Steel (CS) is shown in the table below.
What Are the Differences between 17-4 PH Stainless Steel and Conventional Stainless Steel (SS)?
17-4 PH stainless steel differs from conventional Stainless Steel (SS) grades through its precipitation hardening mechanism, magnetic behavior, and superior strength capability. Standard austenitic grades (304 and 316) rely on cold working to increase strength, reaching yield strengths of 30 ksi to 45 ksi in annealed conditions. Standard martensitic grades (410 and 420) achieve higher strength through quench hardening but lack the aging capability that allows 17-4 PH to reach 170 ksi to 185 ksi. The ferromagnetic nature of 17-4 PH stainless steel further distinguishes it from non-magnetic austenitic grades.
The difference between 17-4 PH Stainless Steel and Conventional Stainless Steel (SS) is shown in the table below.
Does Conventional Stainless Steel Offer Better Weldability than 17-4 PH?
Yes, conventional stainless steel offers better weldability than 17-4 PH stainless steel. Austenitic grades (304 and 316) weld readily without pre-heating or post-weld heat treatment, maintaining corrosion resistance and toughness across the weld zone. The face-centered cubic (FCC) structure of austenitic grades accommodates thermal stress during welding without martensitic change or hardness increase in the heat-affected zone. 17-4 PH stainless steel requires post-weld solution annealing at 1,038°C (1,900°F) followed by re-aging to restore mechanical properties in the heat-affected zone. Skipping post-weld heat treatment leaves the weld region in a partially hardened and embrittled condition, reducing toughness by 20% to 30%. Martensitic grades (410 and 420) present comparable weldability challenges to 17-4 PH, requiring pre-heating at 200°C to 300°C to minimize cracking risk during welding operations.
