Medium-Carbon Steel: Uses, Composition, and Its Properties
Written byKat de Naoum
Aaron Lichtig
Updated byAaron Lichtig
11 min read
Published November 3, 2023Updated March 12, 2026
Get to know the middle ground material between high- and low-carbon steel
Medium carbon steel part.
With the right mixing and matching of elements, chemistry makes it possible for us to create variants of different materials, taking away certain properties and improving or increasing others. You could say that medium-carbon steel is the Goldilocks of the carbon steel world, in this regard, striking the perfect balance between high- and low-carbon steel.
This ultra-versatile alloy is what many Xometry customers need when they're part of an industry with machinery, parts, and tools that see immense wear and tear. We've seen everything from axles to gears to train wheels and other load-bearing objects that are made with this specific alloy. If you’re intrigued by this steel and how its properties differ from other alloys and metals out there, you can learn more below.
What is Medium-Carbon Steel?
Medium-carbon steel is made up of iron and a slew of other alloying elements, and in some places, you’ll hear it referred to as M2 steel. A closer look at its makeup and you’ll see that its carbon concentration ranges between 0.30% and 0.60% and its manganese between 0.60% and 1.65%. With a serious microscope or instrument, you could see M2’s atomic structure, which features a crystalline lattice of iron atoms with carbon and manganese atoms mixed in.
A pulley gear made of medium-carbon steel.
How Is Medium-Carbon Steel Made?
Like other forms of carbon steel, you’ll find that medium-carbon steel is made through the usual steel production process. What varies is how much carbon gets introduced into the alloy. With steelmaking, iron ores are mined and then broken down into iron and oxygen in a blast furnace, the former being the important part for steel. Once this happens, other elements can be thrown into the mix. To hit that medium-carbon sweet spot, a percentage between 0.30% and 0.60% carbon content is targeted. After the alloy is created, it is refined and shaped into various forms.
How Does Medium-Carbon Steel Differ From Stainless Steel?
High chromium concentration in stainless steel creates a barrier against rust and corrosion. On the other hand, carbon steel, which is rich in carbon, can rust and corrode when exposed to moisture. The corrosion resistance that chromium gives stainless steel makes a significant impact.
How Much Does Medium-Carbon Steel Cost?
Medium-carbon steel normally costs between $500 and 720 per ton. However, these costs can change depending on the grade, the shape, and the state of the market. It's advisable to speak with specific vendors to get the most precise and recent pricing information.
Is Medium-Carbon Steel a Medium-Alloy Steel?
No, medium-carbon steel is not considered a medium-alloy steel. Medium-carbon steel primarily contains iron and carbon (around 0.3–0.6% carbon) with minimal alloying elements, whereas medium-alloy steel contains a significant percentage of alloying elements like chromium, nickel, or molybdenum, enhancing its mechanical properties. In the classification of steel alloys, if a steel contains less than 8% alloying elements, it is typically labeled as low-alloy steel. Conversely, when a steel composition includes more than 8% alloying elements, it falls into the category of high-alloy steel.
What Are the Different Types of Medium-Carbon Steel?
When we refer to a material as a medium-carbon steel, it's actually more of a term that includes all types of alloys that fall under its umbrella. There are several variations that differ in carbon content, but are all considered medium-carbon steels:
1. 4140 Steel
One of Xometry's most popular medium-carbon steel alloys is 4140. This chromium-molybdenum alloy will have between 0.38% and 0.43% carbon content and is superb if you need steel that welds well. Because 4140 steel also has a high-wear resistance and remains strong in extremely cold temperatures, it may be a material you consider for things such as hydraulic cylinders, shafts, and other heavy machinery parts.
2. 1060 Steel
With 1060 steel, you’re getting a material with slightly higher carbon content, coming in at around 0.60%. It’s relatively brittle, especially in comparison to 1045, but it’s ideal if you need hard blades and knives for machinery and tools.
3. 1045 Steel
As indicated by its name, you’ll find 1045 steel has 0.45% carbon content. When machining it, you’ll notice it’s much more easily weldable and workable than 1060 or 4140, but it doesn’t possess the same corrosion- and wear-resistance as other versions. It’s a smart choice if you’re wanting to make sprockets, gears, axles, and shafts. Xometry offers various finishing solutions, such as black oxide or powder coating, that can help protect or enhance the surface of this material.
"Medium-carbon steel falls in the sweet spot between high-carbon and low-carbon. The higher the carbon, the stronger and more brittle the material. However, the lower the carbon is the more malleable (pliable) and typically cheaper the material is."
Jake ThompsonSenior Solutions Engineer
What Are the Uses and Applications of Medium-Carbon Steel?
There are many ways you can use and form medium-carbon steel, especially when you need parts and components that can handle heavy loads without breaking. Here are a few part examples and applications we've seen with our customers:
  • Railway tracks
  • Train wheels
  • Couplings
  • Forgings
  • Crankshafts for engines
  • Machinery parts
  • Automotive panels
  • Springs
  • Cables
  • Gears
What Is the Chemical Composition of Medium-Carbon Steel?
Iron is the main ingredient in medium-carbon steel, but you’ll see in its chemical composition that it also features 0.30% to 0.60% carbon. You may find in certain types that other elements are in the mix, such as silicon, phosphorus, sulfur, chromium, and nickel.
The table below shows you the different composition percentages of all the chemical elements that typically make up medium-carbon steel.
Table 1: Chemical Composition of Medium-Carbon Steel
What Is the Carbon Content of Medium-Carbon Steel?
The carbon content of medium-carbon steel typically falls within the range of 0.3–0.6%. According to the Iron-Carbon Phase Diagram, hypo-eutectoid steels like medium-carbon steel, when the carbon percentage is less than 0.76%, exhibit specific microstructural transformations. Initially, at 0.3% carbon and 940 ºC, the alloy consists of a gamma (austenite) microstructure. Upon slow cooling, ferrite forms, resulting in an alpha and gamma microstructure. The percentage of ferrite increases, leading to the formation of pro-eutectoid ferrite. Further cooling leads to the conversion of austenite into pearlite, a lamellar structure. Hypo-eutectoid steels are known for their softness and ductility due to the presence of pro-eutectoid ferrite. The specific properties depend on the exact carbon composition and heat treatment.
What Are the Properties of Medium-Carbon Steel?
The characteristics of medium-carbon steel are listed in Table 2 below:
Table 2: Properties of Medium-Carbon Steel
What Is the Machinability Rating of Medium-Carbon Steel?
Machinability ratings for medium-carbon steel, such as 1045, range from 28–60%. This grade is in contrast to 1112 carbon steel, which acts as the benchmark and has a rating of 100%. A smaller percentage means that medium-carbon steel is harder and more resistant to wear, making it harder to manufacture effectively.
What Are the Characteristics of Medium-Carbon Steel?
Medium-carbon steel exhibits notable characteristics:
  1. Good balance of strength and ductility.
  2. Suitable for heat treatment.
  3. Enhanced wear resistance.
  4. Moderate machinability.
Is Medium-Carbon Steel the Cheapest Carbon Steel?
No, medium-carbon steel is not the cheapest carbon steel. It tends to be more expensive than low-carbon steel because of the additional alloying elements present, which enhance its properties but also raise production costs.
Is Medium-Carbon Steel Rust-Resistant?
No, medium-carbon steel is not rust-resistant by nature. Since it isn’t as corrosion-resistant as stainless steel or other coatings, it might corrode when exposed to moisture and oxygen.
Can Medium-Carbon Steel Be Welded?
Yes, medium-carbon steel can be welded. When welding medium-carbon steel, precautions like preheating, using a similar chemical composition filler rod, and post-weld cleaning are essential. Gas metal arc welding (GMAW) is commonly preferred due to its flexibility and heat transfer properties.
Is Medium-Carbon Steel Corrosion-Resistant?
No, medium-carbon steel isn't intrinsically resistant to corrosion. When exposed to oxygen and moisture, it is vulnerable to corrosion. It can either be coated or alloyed to increase corrosion resistance.
Is Medium-Carbon Steel Brittle?
Medium-carbon steel can exhibit increased brittleness compared to low-carbon steel due to its higher carbon content. However, the degree of brittleness can vary based on factors like heat treatment and alloying elements.
Is Medium-Carbon Steel Stronger Than Stainless Steel?
Yes, medium-carbon steel can be stronger and more resilient than stainless steel. However, due to its greater susceptibility to rust and less ductility, it may not be suitable for many applications.
What Are the Thermal Properties of Medium-Carbon Steel?
Table 3 summarizes the thermal properties of medium-carbon steel:
Table 3: Thermal Properties of Medium-Carbon Steel
What Are the Common Forms of Medium-Carbon Steel Material?
Aside from selecting between different types of medium-carbon steel, you can also choose from several formats:
1. Medium-Carbon Steel Bars
Medium-carbon steel bars can come in both cylindrical and rectangular shapes and offer high strength, which is perfect if you’re manufacturing heavy-duty shafts, axles, and gears. You’ll also find that pearlite and ferrite are often blended into the mix of these steel bars for added robustness. We often use bar stock for CNC-machined components.
2. Medium-Carbon Steel Sheets
We often work with sheets of medium-carbon steel, which are great when constructing automotive panels and other structural components that need to be molded, formed, machined, or welded. These will also have certain levels of pearlite and ferrite in their makeup.
3. Medium-Carbon Steel Wire
The wire format of medium-carbon steel is exceptionally made if you’re interested in creating springs, cables, and other products that require a robust finish but are still machinable. Even under strain, you can bend, twist, and form these wires while maintaining their tensile strength.
Xometry X Logo
Get Quotes on Medium-Carbon Steel Parts and More
What Are the Equivalents of Medium-Carbon Steel?
If you look around the world, you’ll find that medium-carbon steel has various names. The below chart breaks it down by country and the name it goes by there:
Table 4: Equivalents of Medium-Carbon Steel
What Are the Advantages of Using Medium-Carbon Steel?
When you’re working out whether or not to incorporate medium-carbon steel into your project or facility, it’s worth understanding the main advantages.
  • Heat-treatable: You can heat-treat medium-carbon steel to boost its hardness and strength without risking its integrity. This is a standard finishing option we offer for parts made from these alloys.
  • Weldability: With a melting point of 1,500°C, this is a plus if you’re interested in welding with this kind of steel.
  • Machinable: If you’re interested in creating complex parts, you can rely on medium-carbon steel and its good machinability. Better machinability can also help reduce time on the machine and lower part costs.
  • Durable: When you’re parts require wear resistance and the ability to handle heavy loads, this material is well suited for the job.
What Are the Disadvantages of Using Medium-Carbon Steel?
  • Brittleness: Medium-carbon steel is far more brittle than some other metals, especially when you heat it to a particular temperature, so it’s best to heat-treat it properly.
  • Rusts easily: One downfall of medium-carbon steel is that it can rust quickly, but fortunately, you can fend off most rust if you choose to apply protective coatings, such as our powder coating option.
  • High cost: Because there are other alloying elements in medium-carbon steel, you’ll notice it’s more expensive than low-carbon steels.
What Is the Difference Between Medium-Carbon Steel and High-Carbon Steel?
As you might have guessed, medium-carbon steel sits right between high-carbon steel and low-carbon steel and is a great happy medium for many applications because of this. In comparison, you’ll see that high-carbon steel has a slightly higher percentage of carbon content (0.60% to 1.5% in comparison to medium-carbon steel’s 0.30% to 0.60%) and is even more brittle. When you look at low-carbon steel, you’ll notice it has a lower carbon content (up to 0.30%) but is not as strong as the other two. Still, it is cheaper and more malleable, if that’s something you’re after.
What Is the Difference Between Medium-Carbon Steel and Stainless Steel?
Interestingly, stainless steel comes from a mix of medium- and low-carbon steel, and is best if you like the properties of carbon steel save for the poor rust and corrosion resistance. The main difference you’ll discover is that stainless steel is processed and alloyed in such a way that makes it better capable of handling environments where moisture and oxygen can ruin its integrity.
Medium-carbon steel is a unique blend of carbon and alloying elements that’s worth exploring as an option when you’re in search of materials that can handle extreme wear and tear and heavy-duty loads.
At Xometry, we offer dozens of materials, including medium-carbon steels, for custom machined, sheet cut, and bent parts. If you're concerned about the aforementioned downside of rust or corrosion, we have finishing options to address that. Best of all this can all be automatically quoted with the Xometry Instant Quoting Engine®.
You can get your instant quote today by uploading your 3D CAD file. You'll find medium-carbon steel alloys such as 4140 and 1045 in our CNC and sheet cutting services, respectively.
