Metal Fatigue: Causes, Effects, and Prevention in Engineering Materials
Metal Fatigue: Causes, Effects, and Prevention in Engineering Materials defines metal fatigue as progressive structural damage caused by repeated cyclic loading below ultimate tensile strength. Metal Fatigue: Causes, Effects, and Prevention in Engineering Materials explains how fatigue failure develops through crack initiation, crack propagation, and final sudden fracture. ASM describes fatigue failure as a result of fluctuating stresses lower than the stress needed for one-time overload failure. Fatigue starts at stress concentration points (notches, holes, welds, threads, and scratches), where repeated loading creates local damage.
Metal fatigue is a major engineering concern because rotating shafts, aircraft structures, bridges, automotive suspension parts, and industrial machines operate under repeated load cycles. Crack growth continues until the remaining cross section no longer carries the applied load. Fatigue prevention depends on better geometry, smoother surfaces, controlled stress levels, suitable material selection, residual stress control, and scheduled inspection. Aerospace structures, automotive systems, rotating machinery, bridges, industrial equipment, and structural engineering applications rely on fatigue analysis because sudden fracture creates safety and service life risks. Xometry-relevant manufacturing decisions connect material choice, heat treatment, machining quality, and surface finish with metal fatigue.
What is Metal Fatigue?
Metal fatigue is the weakening and eventual failure of a metal caused by repeated cyclic stresses over time. Fatigue failure develops when a part experiences repeated tension, compression, bending, torsion, or vibration during service. The applied stress level typically stays below the material’s yield strength, but microscopic damage accumulates at stress concentration points. Cracks start at surface defects, sharp corners, holes, welds, threads, or machining marks.
Fatigue failure progresses through crack initiation, crack propagation, and final fracture. The final break happens suddenly when the remaining cross-section becomes too small to carry the applied load. Shafts, springs, aircraft frames, bridges, gears, and rotating machinery face fatigue risk because repeated loading creates thousands or millions of stress cycles. Material selection, surface finish, geometry control, heat treatment, and inspection planning reduce the risk of metal fatigue.
Why Does Repeated Stress Cause Fatigue Failure?
Repeated stress causes fatigue failure because cyclic loading creates microscopic structural damage that accumulates across repeated stress cycles. Each load cycle produces small plastic strain at weak points in the metal, even when the applied stress stays below yield strength. Stress concentration points (notches, holes, weld toes, threads, and machining marks) collect the highest local stress. Microcracks form when the local damage exceeds the metal’s ability to resist slip and separation.
Crack propagation begins after the first microcrack forms, then each cycle extends the crack by a small amount. The remaining cross section becomes smaller as the crack grows through the part. Final fracture occurs suddenly when the reduced section no longer carries the applied load. Shafts, springs, aircraft frames, gears, and bridge members face fatigue failure when repeated stress cycles continue without inspection or design control.
Can Metal Fatigue Occur Without Visible Deformation?
Yes, metal fatigue occurs without visible deformation because fatigue damage develops through microscopic cracks before a part shows an obvious shape change. The applied cyclic stress can stay below the yield strength, so the metal does not bend, stretch, or visibly distort before failure. Crack initiation starts at weak points (surface scratches, sharp corners, weld toes, holes, and threads). Crack growth continues under repeated loading until the remaining cross section becomes too small to carry the load. The final fracture can look sudden because most fatigue damage remains hidden inside or near the surface. Inspection methods (dye penetrant testing, magnetic particle testing, ultrasonic testing, and eddy current testing) help detect fatigue cracks before visible deformation appears. Fatigue fractures often show beach marks or striations that record crack growth across repeated loading cycles. Preventive maintenance relies on scheduled inspection because early fatigue damage remains difficult to identify by sight alone.
How Does Metal Fatigue Develop?
Metal fatigue develops through repeated cyclic stress, crack initiation, progressive crack propagation, and final fracture. Cyclic stress starts when a metal part experiences repeated tension, compression, bending, torsion, or vibration during service. The stress level stays below yield strength in many fatigue failures, but repeated loading still creates microscopic structural damage. Stress concentration points (holes, notches, weld toes, threads, scratches, and sharp corners) collect higher local stress than surrounding areas.
Crack initiation begins when microscopic damage forms at a surface defect or internal weakness. Progressive crack propagation follows as each load cycle extends the crack through a small distance. The remaining cross section becomes smaller as the crack grows deeper into the part. Final fracture occurs suddenly when the remaining material can no longer carry the applied load. Shafts, springs, gears, aircraft structures, bridges, and rotating machinery require fatigue control because repeated stress cycles create hidden damage before visible failure.
What Happens During Fatigue Crack Initiation?
During fatigue crack initiation, microscopic discontinuities, inclusions, scratches, or stress risers become starting points for small cracks. Local stress increases around sharp geometry, weld toes, holes, threads, keyways, and machining marks because the load concentrates at narrow or irregular areas. Repeated loading creates tiny slip bands in the metal grain structure, then the damaged region begins to separate at the surface or near an internal flaw.
Surface cracks usually form first because surface defects face direct cyclic stress, friction, corrosion, and tensile loading. Nonmetallic inclusions, pores, and voids create internal weak points when the surrounding metal carries repeated stress. The first crack starts very small, but each load cycle extends the damaged zone until measurable crack growth begins. Early fatigue cracks need inspection methods (dye penetrant testing, magnetic particle testing, ultrasonic testing, and eddy current testing) because visual inspection misses many initiation-stage defects.
Why Does Fatigue Crack Growth Accelerate Over Time?
Fatigue crack growth accelerates over time because the crack reduces the remaining load-bearing cross-section. Stress becomes concentrated at the crack tip as the crack grows deeper into the metal. Each repeated load cycle opens and extends the crack by a larger amount than earlier cycles. The remaining material carries higher local stress, which increases the crack growth rate. Surface corrosion, vibration, variable high-amplitude cyclic loading, and tensile residual stress speed up crack propagation. The final fracture happens suddenly when the remaining cross-section no longer supports the applied load. Crack growth becomes harder to stop once the crack reaches a critical size. Inspection intervals help identify growing cracks before rapid fracture occurs.
What Are the Main Causes of Metal Fatigue?
The main causes of metal fatigue are listed below.
- Repeated cyclic loading: Repeated cyclic loading causes metal fatigue by applying tension, compression, bending, torsion, or vibration across many stress cycles. Microscopic damage accumulates even when the applied stress stays below the yield strength.
- Stress concentration: Stress concentration raises local stress around holes, notches, weld toes, threads, sharp corners, and keyways. Crack initiation begins more easily at these high-stress areas because the load is not distributed evenly
- Surface defects: Surface defects create weak starting points for fatigue cracks. Scratches, machining marks, pits, burrs, and grinding burns act as small notches under repeated loading.
- Corrosion environments: Corrosion environments accelerate fatigue by creating pits and weakening the metal surface. Moisture, salt, chemicals, and high temperature exposure increase crack initiation risk.
- Residual stresses: Residual tensile stresses increase fatigue risk by adding internal stress to the applied service load. Welding, forming, grinding, and heat treatment create residual stress when process control is poor.
- Improper material selection: Improper material selection increases fatigue failure risk when strength, toughness, hardness, and corrosion resistance do not match service conditions. Shafts, springs, gears, bridges, and aircraft structures need materials selected for repeated loading performance.
"When designing parts for cyclic loading, the initial blueprint is only half the story: real-world survival depends entirely on the surface integrity left behind during manufacturing. A beautiful design will fail prematurely if the specifications lack precise geometric controls for roughness or overlook post-processing treatments like shot peening. True fatigue prevention happens on the shop floor, where managing local stress states matters far more than relying on ideal textbook material properties."
How Do Stress Concentrations Increase Fatigue Risk?
Stress concentrations increase fatigue risk because notches, holes, sharp corners, and abrupt geometry changes raise local stress above the surrounding metal. The applied load does not spread evenly through the section when the geometry changes suddenly. Local stress gathers at narrow radii, drilled holes, thread roots, keyways, weld toes, and machined grooves.
Repeated loading then creates microscopic slip, surface separation, and crack initiation at the highest stress point. A small crack grows faster when the crack tip carries concentrated stress during each cycle. Poor surface finish increases the effect because machining marks act as small notches. Corrosion pits create similar stress raisers and give cracks a faster starting point. Rounded transitions, smoother surfaces, proper fillets, and controlled machining marks reduce fatigue risk by lowering local stress concentrations. Thread roots and keyways need careful radius control because repeated torque loads concentrate stress at their base. Design reviews identify stress concentration zones before fatigue testing, machining, or final inspection.
Does Surface Roughness Affect Fatigue Strength?
Yes, surface roughness affects fatigue strength because rough surfaces create small stress raisers where fatigue cracks start. Machining marks, scratches, grooves, pits, and grinding burns concentrate local stress during repeated loading. A rough surface reduces fatigue life because cracks usually begin at the exposed surface under cyclic tension. Polished, shot-peened, or properly finished surfaces improve fatigue strength by reducing notch effects and surface crack initiation. Surface roughness matters most in shafts, springs, gears, bearings, aircraft parts, and rotating machinery. Inspection teams review surface finish when fatigue failure risk depends on repeated contact, vibration, or bending loads. Surface treatment selection affects fatigue strength because compressive residual stress helps resist crack opening during cyclic loading. Grinding, polishing, coating preparation, and cleaning need controlled process settings to avoid surface damage before service.
What Types of Fatigue Failures Exist?
The types of fatigue failures are listed below.
- High cycle fatigue: High cycle fatigue occurs under many repeated load cycles at lower stress levels. Rotating shafts, springs, gears, and aircraft parts face high-cycle fatigue during long service periods.
- Low-cycle fatigue: Low-cycle fatigue occurs under fewer cycles with higher plastic strain. Pressure vessels, turbine parts, and heavy equipment components face low-cycle fatigue during overload events or repeated start-stop operation.
- Thermal fatigue: Thermal fatigue occurs when repeated heating and cooling create expansion and contraction stress. Engine parts, molds, exhaust systems, and turbine blades face thermal fatigue under changing temperature conditions.
- Corrosion fatigue: Corrosion fatigue occurs when cyclic stress combines with a corrosive environment. Saltwater, chemicals, moisture, and acidic exposure create pits that accelerate crack initiation.
- Contact fatigue: Contact fatigue occurs under repeated rolling or sliding contact stress. Bearings, gears, cams, and rail wheels face pitting, spalling, and surface cracking from contact fatigue.
- Vibration fatigue: Vibration fatigue occurs when repeated oscillation creates cyclic stress in a component. Brackets, fasteners, piping, engine mounts, and rotating machinery face vibration fatigue when resonance or imbalance increases stress cycles.
How Does High-Cycle Fatigue Differ From Low-Cycle Fatigue?
High-cycle fatigue differs from low-cycle fatigue because high-cycle fatigue occurs under lower stress over many cycles, while low-cycle fatigue occurs under higher stress over fewer cycles. High-cycle fatigue usually stays within elastic deformation, so the metal returns close to its original shape after each load cycle. Low-cycle fatigue involves plastic deformation, which creates permanent strain during repeated loading. Rotating shafts, springs, gears, and aircraft structures commonly face high-cycle fatigue during long service periods. Pressure vessels, turbine parts, engine components, and heavy machinery commonly face low-cycle fatigue during overloads or start-stop operation. High-cycle fatigue usually develops slowly through crack initiation and crack growth. Low-cycle fatigue progresses faster because higher strain produces greater microscopic damage per cycle. Cycle count, stress amplitude, and strain level separate the 2 fatigue categories during design analysis. Material selection, surface finish, heat treatment, and inspection intervals depend on whether high-cycle fatigue or low-cycle fatigue controls failure risk.
Is Corrosion Fatigue More Severe Than Ordinary Fatigue?
Yes, corrosion fatigue is more severe than ordinary fatigue because cyclic stress and chemical attack damage the metal at the same time. Corrosion creates pits that act as sharp stress raisers on the surface. Repeated loading turns the pits into crack initiation points faster than dry mechanical fatigue. Crack growth speeds up when moisture, saltwater, acids, or industrial chemicals attack the crack tip. Corrosion fatigue reduces fatigue strength because the environment continuously weakens the surface during service. Bridges, marine shafts, aircraft parts, pipelines, and fasteners face a higher risk when cyclic loading occurs in corrosive conditions. Corrosion fatigue crack surfaces often show rust, oxide deposits, or chemical attack marks near the fracture path. Protective coatings, corrosion-resistant alloys, drainage design, and surface cleaning reduce environmental damage during repeated loading. Inspection intervals need tighter control when a part faces combined cyclic stress and corrosive exposure.
What Materials Are Affected by Metal Fatigue?
The materials that are affected by metal fatigue are listed below.
- Carbon steels: Carbon steels are affected by metal fatigue when repeated bending, torsion, or vibration creates cracks at welds, holes, threads, and machined surfaces. Shafts, gears, beams, and brackets need proper surface finish, heat treatment, and stress control.
- Alloy steels: Alloy steels resist fatigue better than plain carbon steels when strength, toughness, and hardenability match the load case. Automotive drivetrains, bearings, springs, and aerospace fasteners use alloy steels for repeated stress applications.
- Aluminum alloys: Aluminum alloys are affected by fatigue because the material does not have a true endurance limit. Aircraft skins, frames, wheels, and lightweight structures need careful fatigue testing and crack inspection.
- Titanium alloys: Titanium alloys handle fatigue well in high-strength and low-weight applications, but surface defects reduce performance. Aerospace structures, implants, and engine components need polished surfaces and controlled machining damage.
- Stainless steels: Stainless steels are affected by fatigue when cyclic stress combines with corrosion, surface roughness, or residual tensile stress. Marine parts, pressure equipment, fasteners, and welded structures need corrosion control and fatigue inspection.
- Nickel-based alloys: Nickel-based alloys resist fatigue in high-temperature environments, but cracks still form under thermal cycling and vibration. Turbine blades, exhaust parts, and aerospace engine components need a heat-resistant fatigue design.
Why Are Aluminum Alloys Sensitive to Fatigue?
Aluminum alloys are sensitive to fatigue because many aluminum alloys lack a well-defined endurance limit and continue accumulating damage under cyclic loading. Steel grades often show a fatigue limit under specific test conditions, but aluminum alloys keep losing fatigue life as stress cycles increase. Small surface scratches, drilled holes, rivet holes, corrosion pits, and machining marks become common crack initiation points. Aircraft skins, frames, wheels, and lightweight structural parts need careful stress control because repeated vibration and bending create hidden crack growth. Surface finish, alloy temper, residual stress, corrosion exposure, and load spectrum strongly affect fatigue performance. Regular inspection and conservative design limits help reduce fatigue failure risk in Aluminum Alloys.
Can Brittle Materials Experience Fatigue Failure?
Yes, brittle materials experience fatigue failure when repeated cyclic stress creates cracks that grow from small defects. Brittle materials have limited plastic deformation, so crack tips do not blunt easily under repeated loading. Ceramics, cast irons, hardened steels, and glass-like materials fail when cracks grow from pores, inclusions, machining damage, or surface flaws. Fatigue cracks in brittle materials progress with less visible warning than cracks in ductile metals. The final fracture occurs suddenly when the crack reaches a critical size. Surface finish, flaw size, tensile stress, and environment strongly affect fatigue resistance in brittle materials.
Repeated stress testing helps identify flaw sensitivity before brittle components enter service. Design control reduces tensile stress concentration by using smoother geometry, compressive surface treatments, and strict quality inspection.
How is Metal Fatigue Measured and Evaluated?
To measure and evaluate Metal fatigue, follow the five steps below.
- Use S-N curves. S N curves measure fatigue performance by comparing stress amplitude against the number of cycles to failure. Engineers use stress-life data to estimate safe loading ranges for shafts, springs, gears, and structural parts.
- Run fatigue testing machines. Fatigue testing machines apply repeated tension, bending, torsion, or rotating loads to a material specimen. The test records the cycle count where cracking or fracture begins under controlled stress levels.
- Analyze crack growth. Crack growth analysis measures how fast a fatigue crack extends during repeated loading. Engineers compare crack size, stress intensity, and inspection intervals to predict safe remaining service life.
- Inspect fracture surfaces. Fractography inspection studies the broken surface after fatigue failure. Beach marks, striations, crack origins, and final overload zones reveal how the crack started and spread.
- Perform finite element stress analysis. Finite element stress analysis identifies high stress areas before fatigue testing or production. The method helps locate notches, holes, weld toes, sharp corners, and load paths that need design improvement.
What is an S-N Curve in Fatigue Analysis?
An S N curve in fatigue analysis relates cyclic stress levels to the number of cycles required for failure. The curve shows how a material responds when repeated loading continues under controlled stress amplitudes. Higher stress levels usually produce failure after fewer cycles, while lower stress levels extend fatigue life. Test data comes from specimens loaded in repeated tension, bending, torsion, or rotating beam conditions. Engineers use S N curves to estimate safe stress ranges for shafts, springs, gears, aircraft parts, and bridge members. The curve helps compare materials, surface finishes, heat treatments, and design changes under repeated loading. Fatigue design uses S-N data to reduce crack initiation risk before service loads damage the part. Logarithmic cycle scales are commonly used because fatigue life spans thousands to millions of cycles. Steel materials may show an endurance limit, while aluminum alloys usually continue losing fatigue life as cycles increase. S N curve results support material selection, safety factors, inspection intervals, and component life estimates.
Does Fatigue Testing Simulate Real Operating Conditions?
Yes, fatigue testing simulates real operating conditions when the test setup matches the service load, environment, temperature, and cycle pattern. Test machines apply repeated tension, compression, bending, torsion, or rotating loads to reproduce cyclic stress. Laboratory tests simplify some field conditions, so results need engineering judgment before final design use. Variable amplitude loading gives better service simulation than constant amplitude loading when equipment faces changing loads. Environmental chambers add corrosion, humidity, heat, or cold exposure when service conditions require it. Fatigue testing supports safer design by showing how materials and components respond before full service use. Component-level fatigue tests improve accuracy when full geometry, surface finish, fasteners, and manufacturing effects are included. Field data from sensors or service inspections helps confirm whether laboratory fatigue results match real operating behavior.
What Are the Effects of Metal Fatigue on Components?
The effects of metal fatigue on components are listed below.
- Crack formation: Metal fatigue causes crack formation when repeated stress creates microscopic damage at weak points. Cracks usually start at holes, weld toes, scratches, threads, notches, and corrosion pits.
- Loss of structural integrity: Metal fatigue reduces structural integrity as cracks grow through the load-bearing section. The component loses stiffness, strength, and resistance against bending, torsion, or vibration.
- Sudden mechanical failure: Metal fatigue creates sudden mechanical failure when the remaining cross section no longer supports the applied load. The final fracture happens quickly after long hidden crack growth.
- Reduced service life: Metal fatigue shortens service life because each stress cycle adds damage to the component. Shafts, gears, springs, bridges, and aircraft structures need inspection before cracks reach a critical size.
- Safety risks in dynamic systems: Metal fatigue creates safety risks in dynamic systems that experience repeated motion or vibration. Automotive suspension parts, rotating machinery, aircraft frames, and industrial equipment require fatigue control to prevent fracture during operation.
Why Are Fatigue Failures Often Sudden and Dangerous?
Fatigue failures are often sudden and dangerous because cracks grow slowly before the final fracture occurs rapidly. Early crack growth remains hidden inside the component or along small surface flaws. The remaining cross section becomes smaller as the crack moves through the material. The intact section carries higher stress until it reaches the fracture limit. Final failure occurs when the remaining metal no longer supports the applied load. Shafts, gears, aircraft frames, bridges, and rotating machinery face a high risk because repeated loads continue during normal operation. Visual inspection may miss early cracks, so nondestructive testing becomes necessary for critical parts. Fatigue failure creates safety risks because the component can break without visible bending, warning, or gradual loss of function. Crack growth rate accelerates near the final stage because the remaining load path becomes too small. Dynamic systems create greater danger because fractures occur during motion, rotation, vibration, or load transfer. Scheduled inspection and fatigue life prediction reduce failure risk before cracks reach critical size.
Can Metal Fatigue Cause Catastrophic Structural Failure?
Yes, metal fatigue can cause catastrophic structural failure when a crack reaches critical size, and the remaining section no longer supports the load. Bridges, aircraft structures, pressure equipment, rotating shafts, and heavy machinery face serious risk when fatigue cracks grow unnoticed. Repeated loading keeps extending the crack until the final fracture occurs suddenly. Dynamic systems increase danger because failure happens during motion, vibration, or load transfer. Catastrophic failure can damage connected parts, stop equipment, or create safety hazards for operators and nearby structures. Regular inspection, fatigue life analysis, stress reduction, and crack monitoring reduce the risk before the final fracture occurs.
How Can Fatigue in Metals Be Prevented?
Fatigue in metals is prevented by reducing crack initiation risks before repeated loading damages the component. Stress concentration, rough surfaces, corrosion exposure, residual tensile stress, and poor material selection increase fatigue failure risk. Engineering teams prevent fatigue by improving geometry, surface quality, material choice, surface treatment, corrosion protection, and load distribution. Shafts, gears, bridges, aircraft structures, and rotating machinery need fatigue prevention because repeated stress cycles create hidden crack growth before final fracture.
Fatigue in metals can be prevented by following the six steps below.
- Reduce stress concentration. Reduce stress concentration by smoothing holes, notches, threads, weld toes, keyways, and sharp corners. Larger fillet radii, cleaner transitions, and improved geometry lower the crack initiation risk under repeated loading.
- Improve surface finish. Improve surface finish by removing scratches, grooves, burrs, pits, and machining marks from fatigue-critical areas. Polishing, controlled grinding, deburring, and surface inspection help delay crack formation.
- Select fatigue-resistant materials. Select fatigue-resistant materials by matching strength, toughness, hardness, and corrosion resistance to repeated load conditions. Alloy steels, titanium alloys, stainless steels, and nickel-based alloys support fatigue control when service loads and environments match the material properties of the metal.
- Apply compressive surface treatments. Apply compressive surface treatments to resist crack opening at the surface. Shot peening, burnishing, and carburizing create compressive residual stress that delays fatigue crack initiation.
- Control corrosion exposure. Control corrosion exposure by reducing moisture, salt, chemical contact, and heat-related surface attack. Coatings, plating, drainage design, sealing, and scheduled cleaning reduce pits that become fatigue crack starting points.
- Optimize load distribution. Optimize load distribution by avoiding repeated stress peaks at one section of the component. Balanced geometry, aligned fasteners, proper bearing support, and stable load paths reduce fatigue risk in metal components.
How Do Surface Treatments Improve Fatigue Resistance?
Surface treatments improve fatigue resistance by creating compressive residual stress that slows crack initiation at the surface. Shot peening strikes the surface with small media, which plastically compresses the outer layer. Surface hardening processes (carburizing, nitriding, and induction hardening) raise surface hardness and improve resistance against wear, indentation, and crack formation. Compressive residual stress helps keep small surface cracks closed during cyclic loading. A smoother and harder surface reduces notch effects from scratches, machining marks, and minor defects. Shafts, gears, springs, bearings, and aircraft parts benefit from surface treatments when fatigue cracks usually start at exposed surfaces. Shot peened surfaces resist tensile crack opening better under bending, torsion, and vibration. Hardened cases improve load support beneath contact zones on gears, bearings, cams, and shafts. Process control matters because excessive peening, overheating, or grinding damage reduces fatigue resistance.
Does Proper Design Reduce Fatigue Failure Risk?
Yes, proper design reduces fatigue failure risk by lowering stress concentration and controlling repeated load paths. Rounded fillets, smooth transitions, adequate section thickness, and aligned fasteners reduce local stress peaks. Sharp corners, undersized holes, poor weld details, and abrupt geometry changes increase crack initiation risk. Load distribution improves when the design spreads cyclic stress across a larger section instead of one weak area. Material selection, surface finish, heat treatment, and corrosion protection support the design strategy. Fatigue analysis and testing confirm whether the component survives the required service cycles. Design reviews identify fatigue-sensitive areas before machining, welding, or final assembly. Service data and prototype testing help confirm that the design handles vibration, bending, torsion, and repeated load cycles.
What is the Difference Between Fatigue and Creep Failure?
The difference between fatigue and creep failure is that fatigue is driven by repeated cyclic loading, while creep occurs through slow deformation under sustained high temperature stress. Fatigue failure develops when repeated tension, compression, bending, torsion, or vibration creates crack initiation and crack growth over time. Creep failure develops when a material remains under constant load at elevated temperature, causing gradual strain and permanent shape change. Fatigue occurs at stress levels below yield strength, while creep depends on time, temperature, stress level, and material resistance. Rotating shafts, springs, gears, and aircraft structures face fatigue risk under repeated loading. Turbine blades, boiler tubes, pressure vessels, and engine exhaust parts face creep risk under high-temperature service. Fatigue leaves crack growth marks on fracture surfaces, while creep leaves elongation, grain boundary damage, voids, or rupture features. Engineers separate the two failure modes because fatigue control focuses on stress cycles, while creep control focuses on temperature exposure and long-term load duration in Creep Failure.
