Acrylic Fabric: Properties and Examples
Acrylic fabric is a synthetic textile made from polyacrylonitrile, a polymer derived from petrochemical processes, and it serves as a widely used alternative to natural fibers like wool and cotton. Acrylic fabric is recognized for its wool-like texture, lightweight structure, and resistance to moisture, making it a practical material across apparel, home textiles, and outdoor applications. The properties of acrylic fabric include colorfastness, durability, and low moisture absorption, which contribute to its versatility in manufacturing. Common uses range from sweaters, blankets, and carpets to outdoor furniture cushions and sportswear fabrics.
Acrylic fabric examples span a broad range of consumer and industrial products, from knitted garments and faux fur to upholstery and craft yarn. The production of acrylic involves polymerization of acrylonitrile monomers, followed by spinning processes that shape the fiber into usable textile forms. Compared to natural fibers, acrylic fabric retains its shape, resists shrinkage, and performs well in both wet and dry conditions. Its adaptability across fashion, interior design, and performance textiles has established it as a staple material in modern manufacturing and consumer goods production.
What Is Acrylic Fabric?
Acrylic fabric is a synthetic textile fiber produced from polyacrylonitrile, a petroleum-based polymer composed of at least 85% acrylonitrile monomer by weight, as defined by the U.S. Federal Trade Commission. The fiber is engineered to replicate the softness and insulating qualities of natural wool while offering greater resistance to environmental conditions and reduced production costs. Acrylic fabric is primarily used in apparel, home furnishings, and industrial textiles due to its lightweight nature and dimensional stability. The fiber does not absorb moisture readily, with a moisture regain rate of approximately 1% to 2%, which allows garments to dry faster than wool or cotton alternatives. Acrylic fabric maintains its shape under repeated washing and resists pilling when produced in high-denier formats. The material is also receptive to dye, producing vivid, long-lasting color across a wide spectrum. Its thermal retention properties make it a preferred choice for cold-weather accessories, blankets, and knitted outerwear in consumer and commercial textile markets.
What Is Acrylic Fabric Made Of?
Acrylic fabric is made from polyacrylonitrile (PAN), a synthetic polymer derived from acrylonitrile monomers that are sourced from petroleum and natural gas refining byproducts. The finished fiber must contain a minimum of 85% acrylonitrile by weight to qualify as acrylic under regulatory standards established by the U.S. Federal Trade Commission. The remaining composition (up to 15%) consists of co-monomers such as vinyl acetate or methyl acrylate, which are introduced during polymerization to modify the fiber's dyeability, flexibility, and tactile properties. Acrylonitrile itself is a colorless, flammable liquid chemical with the molecular formula C₃H₃N, produced through the ammoxidation of propylene. After polymerization, the resulting PAN solution is processed through either wet spinning or dry spinning methods to form continuous filaments or staple fibers. The fiber is then cut, crimped, and finished to produce a material with a soft hand feel and a structure that closely resembles the texture and bulk of natural wool fiber.
Where Does Acrylic Fabric Come From?
Acrylic fabric came from the petrochemical industry, where acrylonitrile, its primary raw material, is manufactured through a chemical process called the SOHIO process (also known as ammoxidation), developed commercially in the 1950s. Propylene, ammonia, and oxygen are reacted at high temperatures over a catalyst to produce acrylonitrile, which then undergoes polymerization to form polyacrylonitrile. The commercial development of acrylic fiber began with DuPont, which introduced the first acrylic fiber under the trade name Orlon in 1950. From its origins in the United States, acrylic fiber production expanded globally, with major manufacturing centers now located in China, India, Japan, and Turkey. China currently accounts for a dominant share of global acrylic fiber output, producing millions of metric tons annually for export to textile markets worldwide. The raw petroleum feedstocks used in acrylonitrile production are extracted primarily from crude oil refining and natural gas processing operations. The fiber's synthetic origin means its availability is tied directly to petroleum supply chains and global petrochemical production capacity.
Is Acrylic A Synthetic Fiber?
Acrylic is a synthetic fiber. The classification is confirmed by the U.S. Federal Trade Commission, which defines acrylic as a manufactured fiber in which the fiber-forming substance is any long-chain synthetic polymer composed of at least 85% by weight of acrylonitrile units. No natural biological source contributes to its formation, distinguishing it from fibers like cotton, silk, or wool. The fiber is produced entirely through industrial chemical processes beginning with petrochemical extraction and ending with mechanical spinning. Unlike natural fibers that grow or are harvested from plants or animals, acrylic fiber is assembled at the molecular level through free-radical polymerization of acrylonitrile monomers. The resulting polymer chains are dissolved in solvents, extruded through spinnerets, and solidified into fiber form. Acrylic fiber belongs to the broader category of synthetic fibers, which includes nylon, polyester, and spandex, all of which are derived from petroleum-based chemical compounds and engineered to deliver specific performance characteristics.
What Are the Properties Of Acrylic Fabric?
The properties of acrylic fabric are listed below.
- Lightweight Structure: Acrylic fabric has a low density, typically ranging from 1.17 to 1.18 g/cm³, making it one of the lighter synthetic fibers available in textile manufacturing. The low mass allows garments to provide insulation without adding significant weight to the wearer.
- Colorfastness: Acrylic fiber accepts basic dyes with high retention, producing colors that resist fading under UV exposure and repeated washing. The color retention rate is measured at above 4 on the Grey Scale in standard ISO colorfastness tests.
- Low Moisture Absorption: The moisture regain of acrylic fiber sits at approximately 1% to 2% under standard atmospheric conditions (65% relative humidity at 20°C), enabling faster drying times compared to cotton (8%) or wool (17%).
- Thermal Insulation: Acrylic fiber traps air within its crimped structure, generating an insulating effect similar to wool. The fiber provides a warmth-to-weight ratio competitive with natural wool alternatives.
- Dimensional Stability: Acrylic fabric resists shrinkage in both wet and dry conditions, retaining its original dimensions after repeated laundering when processed correctly.
- Resistance to Biological Degradation: Acrylic fiber resists mold, mildew, and moth damage, as its synthetic polymer structure does not provide a food source for organisms that degrade natural fibers.
What Characteristics Does Acrylic Fabric Have?
Characteristics of acrylic fabier have are listed below.
- Soft Hand Feel: Acrylic fiber, particularly in its staple form, produces a texture that closely resembles the softness of wool. Fine-denier acrylic (1 to 3 denier per filament) delivers the smoothest tactile surface, making it suitable for next-to-skin garment applications.
- Pill Resistance (Variable): Acrylic fabric has a tendency to pill under friction, though specialized low-tenacity acrylic fibers with tensile strength below 2.0 grams per denier (g/d) are engineered to reduce pilling and extend surface integrity over time.
- UV Resistance: Acrylic fabric retains its color and structural integrity under prolonged sun exposure better than most synthetic fibers. The UV resistance makes it a preferred material for outdoor cushions, awnings, and marine textiles.
- Chemical Resistance: Acrylic fiber resists damage from dilute acids and alkalis, maintaining fiber strength through exposure to common cleaning agents and atmospheric pollutants.
- Electrical Conductivity (Low): Acrylic fabric generates static electricity due to its low moisture absorption and electrical insulating properties, a characteristic common across synthetic fibers with moisture regain below 4%.
- Elasticity (Moderate): Acrylic fiber has an elongation at break of approximately 20% to 50%, providing moderate stretch without the recovery performance of elastane or rubber-based fibers.
Is Acrylic Fabric Warm And Lightweight?
Acrylic fabric is warm and lightweight. The fiber achieves thermal insulation through a crimped, bulked structure that traps air pockets within the textile matrix, generating heat retention comparable to wool at a fraction of the fiber density. Acrylic fiber density measures approximately 1.17 to 1.18 g/cm³, placing it among the lightest insulating fibers used in cold-weather textile production. The warmth-to-weight ratio of acrylic makes it a practical material for winter accessories (hats, scarves, and gloves), blankets, and outerwear linings. A standard acrylic blanket fabric weighing 200 to 300 grams per square meter (GSM) delivers insulation performance comparable to heavier wool blankets at 400 to 500 GSM. The fiber's low moisture absorption further contributes to thermal consistency, as wet fibers lose insulating capacity. Acrylic fabric retains its loft and warmth even in humid conditions, a property that reinforces its use in outdoor and cold-climate textile applications where consistent thermal performance is required.
How Is Acrylic Fabric Produced In Manufacturing
Acrylic fabric is produced in manufacturing through a multi-stage industrial process that begins with the chemical synthesis of acrylonitrile and concludes with mechanical fiber spinning and textile finishing. The production sequence is driven by precision polymerization and controlled spinning conditions that determine the final fiber's density, denier, and surface texture. Acrylonitrile monomer, derived from the ammoxidation of propylene, undergoes free-radical polymerization in an aqueous or solvent-based medium to form polyacrylonitrile (PAN). The resulting polymer, with a molecular weight ranging from 40,000 to 200,000 g/mol depending on the application, is dissolved in a polar solvent such as dimethylformamide (DMF) or dimethylacetamide (DMAc). The dissolved polymer solution is then extruded through a spinneret, a metal plate with fine holes ranging from 0.05 to 0.5 mm in diameter, to form continuous filaments. The filaments are solidified through either wet spinning (coagulated in a liquid bath) or dry spinning (solidified in a heated air column). After spinning, the fibers are drawn, crimped, and cut into staple lengths or left as continuous tow for downstream textile processing.
What Is The Process Of Making Acrylic Fiber?
The process of making acrylic fiber involves five sequential manufacturing stages. Polymerization, dissolution, spinning, drawing, and finishing. Each stage determines specific performance attributes of the final fiber. Follow the five steps. First, acrylonitrile monomer is polymerized using free-radical initiators (peroxides or azo compounds) in a continuous or batch reactor, producing polyacrylonitrile with the required molecular weight distribution. Second, the PAN polymer is dissolved in a solvent at concentrations of 15% to 30% by weight to form a viscous dope solution suitable for extrusion. Third, the dope is filtered and pumped through spinnerets into either a coagulation bath (wet spinning) or a hot air chamber (dry spinning). Wet spinning is the dominant method, accounting for approximately 90% of global acrylic fiber production. Fourth, the coagulated filaments are drawn to ratios of 3:1 to 12:1, which orients the polymer chains along the fiber axis and increases tensile strength. Fifth, the drawn fibers are crimped mechanically to introduce bulk and texture, then heat-set, dried, and cut into staple lengths of 38 mm to 150 mm for yarn spinning or left as continuous filament tow for textile processing.
Is Polymerization Used In Acrylic Production?
Polymerization is used in acrylic production. The process is the foundational step through which acrylonitrile monomers are chemically linked into long-chain polyacrylonitrile (PAN) polymers that form the structural basis of acrylic fiber. Without polymerization, the monomeric acrylonitrile cannot be converted into a fiber-forming material. Free-radical polymerization is the most widely applied method in commercial acrylic fiber manufacturing. The reaction is initiated by adding a chemical initiator (a peroxide or an azo compound) to the acrylonitrile monomer in an aqueous or solvent medium under controlled temperature conditions, typically from 40°C to 70°C. Co-monomers such as methyl acrylate or vinyl acetate are introduced during the polymerization stage at concentrations of 5% to 15% to modify the dyeability and mechanical properties of the resulting polymer. The degree of polymerization directly determines the molecular weight of the PAN product, which in turn governs the fiber's tensile strength, solubility, and processing behavior in subsequent spinning and drawing stages.
How Does Acrylic Compare to Other Plastics Like Polycarbonate?
Acrylic compares to other plastics like polycarbonate in terms of clarity, strength, and impact resistance. Acrylic and polycarbonate are transparent thermoplastic materials widely used in plastic sheeting, optical components, and industrial fabrication, but the two differ substantially in mechanical performance, optical clarity, and processing behavior. Acrylic (polymethyl methacrylate, or PMMA) offers superior optical clarity with a light transmittance of approximately 92%, compared to polycarbonate's transmittance of 85% to 88%. Polycarbonate delivers significantly higher impact resistance, rated at approximately 250 times greater than standard glass and 30 times greater than acrylic at equivalent thicknesses. Acrylic, in contrast, is more brittle under high-impact conditions but offers better surface hardness, with a Vickers hardness of approximately 18 to 20 HV compared to polycarbonate's 14 to 16 HV. Acrylic is easier to machine, polish, and laser-cut to precise tolerances without the thermal deformation issues that affect polycarbonate under high-speed cutting. Polycarbonate retains structural integrity at temperatures up to 135°C, while acrylic begins to soften at approximately 80°C to 100°C. For applications requiring high transparency and optical precision, acrylic performs at a higher standard, while polycarbonate serves applications where impact resistance takes priority.
What Are the Key Differences Between Acrylic And Polycarbonate?
The key differences between acrylic and polycarbonate are listed below.
- Impact Resistance: Polycarbonate withstands impact forces approximately 30 times greater than acrylic of the same thickness. Acrylic fractures under sharp impact, while polycarbonate deforms without shattering, making it suitable for safety glazing and protective covers.
- Optical Clarity: Acrylic transmits approximately 92% of visible light, outperforming polycarbonate's 85% to 88% light transmittance. Acrylic is preferred in optical lenses, display panels, and signage where maximum clarity is required.
- Surface Hardness: Acrylic has a higher surface hardness rating, measuring approximately 18 to 20 HV on the Vickers scale, which gives it better scratch resistance compared to polycarbonate at 14 to 16 HV.
- Heat Resistance: Polycarbonate maintains structural integrity at continuous use temperatures up to 135°C. Acrylic softens at approximately 80°C to 100°C, limiting its use in high-heat environments.
- Machinability: Acrylic cuts, drills, and polishes more cleanly than polycarbonate, producing smooth edges without the gummy residue that polycarbonate generates during high-speed machining.
- Chemical Resistance: Acrylic resists dilute acids but is attacked by ketones, esters, and chlorinated solvents. Polycarbonate resists a narrower range of chemicals than acrylic and degrades under prolonged UV exposure without UV-stabilizing additives.
- Cost: Acrylic sheet is generally priced lower than polycarbonate, with standard cast acrylic sheet ranging from [$3 to $10] per square foot compared to polycarbonate at [$5 to $15] per square foot, depending on thickness and grade.
Is Polycarbonate Stronger than Acrylic For Impact Resistance?
Polycarbonate is stronger than acrylic for impact resistance. Polycarbonate absorbs and distributes impact energy through its molecular structure, allowing it to bend and flex without fracturing, while acrylic tends to crack or shatter under sudden high-force impact. The impact strength of polycarbonate measures approximately 600 to 850 J/m on the Izod notched impact test, compared to acrylic's impact strength of 15 to 25 J/m under the same testing standard. Polycarbonate is rated for use in ballistic glazing at standard sheet thicknesses (3 mm to 6 mm), machine guards, and safety shields where impact tolerance is a critical design requirement. Acrylic at the same thickness performs adequately under low-impact loads but fails abruptly under concentrated force. The trade-off for polycarbonate's superior impact resistance is a lower surface hardness, which makes it more prone to scratching than acrylic. For fabrication environments where impact resistance takes priority over surface clarity and scratch resistance, polycarbonate consistently outperforms acrylic across standardized mechanical testing benchmarks.
What Are the Uses Of Acrylic In Plastic Applications And Manufacturing?
The uses of acrylic plastic applications and manufacturing are listed below.
- Optical Glazing and Displays: Acrylic sheet is used in retail display cases, museum exhibit panels, and point-of-sale displays where optical clarity at 92% light transmittance is required without the weight of glass. Standard acrylic glazing sheet is available in thicknesses from 1.5 mm to 50 mm.
- Signage and Lighting Diffusers: Acrylic is a primary material for illuminated signs, channel letters, and LED light diffuser panels, valued for its ability to transmit and scatter light evenly across a surface.
- Aquarium Construction: Large-scale aquarium tanks use cast acrylic panels up to 300 mm thick, capable of withstanding water pressure loads exceeding 1,000 kilograms per square meter.
- Architectural Glazing: Acrylic is used in skylights, noise barriers, and canopy panels as a lighter and more impact-tolerant alternative to glass, with a weight approximately 50% less than equivalent glass panels.
- Medical Devices: Acrylic is used in intraocular lenses, dental prosthetics, and orthopedic bone cement formulations due to its biocompatibility and dimensional stability.
- Automotive Components: Acrylic is used in taillight lenses, instrument panel covers, and interior trim elements where clarity and UV resistance are required.
Where Is Acrylic Commonly Used In Industrial and Consumer Products?
The commonly used acrylic in industrial and consumer products is listed below.
- Industrial Machinery Guards: Acrylic sheet panels are installed as machine safety guards and protective enclosures in manufacturing facilities, providing operators with clear visibility of moving components while containing debris and reducing noise.
- Consumer Electronics: Acrylic is used in television screen protective panels, smartphone protective covers, and monitor bezels, leveraging its high clarity and surface finish quality.
- Retail Fixtures: Acrylic is a standard material for product display stands, brochure holders, and countertop organizers in retail environments due to its clarity, lightweight, and ease of fabrication.
- Marine Applications: Acrylic is used in portlights, hatches, and windshields on recreational and commercial watercraft, valued for its UV resistance and saltwater weathering performance.
- Construction and Architecture: Acrylic domes, barrel vaults, and translucent wall panels are produced from thermoformed acrylic sheet for use in commercial buildings, transit stations, and sports facilities.
- Household Products: Acrylic is found in picture frames, bathtubs, shower enclosures, and kitchen splashbacks, providing a glass-like appearance at reduced cost and weight.
- Laboratory Equipment: Acrylic is used to fabricate laboratory enclosures, desiccator cabinets, and fume hood panels where chemical resistance to aqueous solutions and optical transparency are required simultaneously.
Is Acrylic Used In Laser Cutting And 3D Printing Applications?
Acrylic is used in laser cutting and 3D printing applications. Cast acrylic sheet is one of the most compatible materials for CO₂ laser systems in laser cutting, which operate at wavelengths of 10.6 micrometers, producing clean, polished edges without the need for post-processing. Laser-cut acrylic achieves tolerances as tight as ±0.1 mm, making it suitable for precision signage, enclosures, and decorative panels. Acrylic-based photopolymers are used in stereolithography (SLA) and digital light processing (DLP) processes in 3D printing, where ultraviolet light cures liquid resin into solid parts with fine surface detail. PMMA-based filaments are available for fused deposition modeling (FDM) printers, though their brittleness and high printing temperature requirements (230°C to 250°C) limit adoption compared to PLA or ABS. Acrylic resin 3D printing produces optically clear parts used in dental models, jewelry casting patterns, and prototype optical components.
Is Acrylic Fabric used In Clothing And Blankets?
Acrylic fabric is used in both clothing and blankets. Acrylic fiber is knitted or woven into sweaters in apparel, cardigans, hoodies, hats, scarves, and gloves, where its wool-like texture and thermal retention make it a cost-effective alternative to natural wool. A standard acrylic sweater retails at approximately [$15 to $60], depending on weight and construction, compared to wool sweaters priced from [$50 to $200] or higher for premium grades. Acrylic fabric is produced as plush in blankets, fleece, or woven structures weighing from 200 to 400 GSM, delivering a soft tactile feel and thermal insulation without the heaviness of wool or the moisture-holding tendency of cotton. Acrylic blankets resist shrinkage through machine washing, making them low-maintenance compared to wool alternatives that require hand washing or dry cleaning. The fiber's resistance to mold, mildew, and insect damage extends the usable life of acrylic blankets in humid storage environments where natural fiber blankets degrade more rapidly.
What Are the Examples of Acrylic Fabric?
The examples of acrylic fabric are listed below.
- Acrylic Sweaters: Knitted garments that replace wool in cold-weather apparel production
- Acrylic Blankets: Soft thermal bedding materials used in residential and commercial settings
- Acrylic Carpets and Rugs: Synthetic floor coverings for interior residential and commercial flooring
- Acrylic Outdoor Furniture Cushions: Weather-resistant upholstery for outdoor seating applications
- Acrylic Knitted Hats and Scarves: Winter accessories produced from knitted acrylic yarn
- Acrylic Upholstery Fabrics: Textile coverings for sofas, chairs, and interior furniture
- Acrylic Tents and Outdoor Covers: Water-resistant textile sheets for outdoor shelter and equipment protection
- Acrylic Yarn for Knitting and Crochet: Craft and textile production material used in handmade and machine-made goods
- Acrylic Sportswear Fabrics: Lightweight performance clothing for athletic and activewear applications
- Acrylic Faux Fur Fabrics: Synthetic imitation fur for fashion garments and home décor products
1. Acrylic Sweaters (Knitted garments replacing wool)
Acrylic sweaters are knitted garments constructed from acrylic staple fiber yarn, engineered to replicate the thermal insulation and soft hand feel of wool at a significantly lower price point. The yarn used in acrylic sweater production ranges from 2-ply to 4-ply construction, with fiber deniers of 1.5 to 3 denier per filament (dpf) providing the fine texture associated with quality knitwear. Acrylic sweaters retail at a price range of [$15 to $60] for standard consumer grades, compared to merino wool sweaters priced from [$80 to $300] for comparable weight and construction. Machine-knit acrylic sweaters are produced on industrial flat or circular knitting machines operating at gauges of 7 to 14 needles per inch, with finer gauges producing lighter, more refined fabrics. The moisture regain of acrylic fiber (1% to 2%) keeps acrylic sweaters lighter when wet compared to wool (17% moisture regain), reducing the discomfort associated with wet outerwear in rain or high-humidity conditions.
2. Acrylic Blankets (Soft thermal bedding materials)
Acrylic blankets are soft, thermally insulating bedding products manufactured from bulked acrylic staple fiber in plush, fleece, or woven textile constructions. The fabric weight of acrylic blankets ranges from 200 to 400 GSM, with heavier weights providing greater thermal retention suitable for colder climates or winter (December to February) season use. The fiber used in acrylic blankets is often processed as high-bulk acrylic (HBA), where the crimped structure of the fiber creates air pockets that trap heat and increase loft. A standard queen-size acrylic blanket measuring 90 x 90 inches weighs approximately 1.5 to 2.5 kilograms, depending on GSM and pile depth. Acrylic blankets are machine washable at temperatures up to 40°C without significant shrinkage, a practical advantage over wool blankets that require gentle hand washing or professional dry cleaning. Retail prices for acrylic blankets range from [$12 to $45] for standard consumer grades, making them among the most cost-accessible insulating bedding materials in the textile market.
3. Acrylic Carpets and Rugs (Synthetic floor coverings)
Acrylic carpets and rugs are synthetic floor coverings produced from acrylic pile fiber, tufted, woven, or bonded onto a backing substrate. Acrylic fiber in carpet construction is valued for its wool-like appearance, vibrant color retention, and resistance to soil and fading, making it a practical material for residential and light commercial flooring applications. The pile fiber in acrylic carpets is typically produced at deniers of 15 to 30 dpf, with higher denier fibers generating a denser, more durable pile surface. Acrylic carpets resist UV fading more effectively than polypropylene alternatives, retaining color saturation after prolonged exposure to indirect sunlight in interior settings. Standard acrylic area rugs retail at [$30 to $250] depending on pile density, dimensions, and weave construction. Acrylic carpets are susceptible to pilling under heavy foot traffic, so their application is generally limited to low-to-medium traffic areas (bedrooms, dining rooms, and decorative spaces) rather than high-traffic corridors or commercial entryways.
4. Acrylic Outdoor Furniture Cushions (Weather-resistant upholstery)
Acrylic outdoor furniture cushions are upholstery textile products manufactured from solution-dyed acrylic fabric specifically engineered to resist UV radiation, moisture, mold, and mildew in exposed outdoor environments. Solution-dyed acrylic, where pigment is introduced into the fiber before spinning, retains color saturation significantly longer than surface-dyed alternatives under direct sun exposure. Outdoor-grade acrylic fabric (Sunbrella being a well-known example of the category) achieves a UV resistance rating that limits color fading to within acceptable limits for up to 5 years of continuous outdoor use in temperate climates. The fabric surface repels water, allowing cushions to dry rapidly after rain without retaining moisture that promotes mold or mildew growth. Acrylic outdoor cushion fabric weights range from 250 to 450 GSM, with heavier weights providing greater structural support and durability in commercial outdoor furniture applications. Retail cushion covers made from outdoor acrylic fabric are priced at [$20 to $80] per unit, depending on size, fabric weight, and filling material.
5. Acrylic Knitted Hats and Scarves (Winter accessories)
Acrylic knitted hats and scarves are cold-weather accessories produced from acrylic yarn on industrial circular or flat knitting machines at gauges of 7 to 12 needles per inch. The acrylic fiber used in hat and scarf production is typically crimped bulked acrylic staple yarn at weights of 50 to 200 grams per skein, chosen for its softness, elasticity, and thermal retention. Acrylic yarn for hat and scarf knitting is produced at yarn counts from 2/28 Nm to 2/48 Nm (metric count), with finer counts producing lighter, smoother accessories and coarser counts generating thicker, bulkier winter-weight products. Retail prices for machine-knit acrylic hats range from [$5 to $30], and acrylic scarves retail from [$8 to $40] depending on length, weight, and construction complexity. Acrylic accessories resist shrinkage during machine washing, a practical advantage for winter season (November to February) products that are washed frequently throughout the wearing season.
6. Acrylic Upholstery Fabrics (Used for sofas and chairs)
Acrylic upholstery fabrics are textile coverings woven or knitted from acrylic fiber for application on sofas, armchairs, dining chairs, and interior furniture. Acrylic upholstery is valued for its resistance to fading, abrasion, and staining, which extends the service life of furniture in residential and light commercial settings. Woven acrylic upholstery fabrics are constructed in plain, twill, or jacquard weave structures at weights from 300 to 600 GSM, with heavier constructions providing greater abrasion resistance for high-contact seat surfaces. Acrylic upholstery achieves abrasion resistance ratings of 20,000 to 50,000 cycles on the Martindale test, indicating moderate-to-good durability for residential furniture use. Fabric prices for acrylic upholstery range from [$5 to $20] per yard, depending on weave complexity and weight. Acrylic upholstery fabric resists pilling better than standard acrylic knit when low-tenacity fiber (below 2.0 g/d tensile strength) is selected, maintaining surface appearance over extended periods of regular use.
7. Acrylic Tents and Outdoor Covers (Water-resistant textile sheets)
Acrylic tents and outdoor covers are water-resistant textile products woven from high-tenacity acrylic fiber and treated with durable water repellent (DWR) or polyurethane (PU) coatings to achieve weather resistance suitable for outdoor shelter applications. Canvas awnings, shade sail fabrics, and tent panels are among the primary product categories manufactured from outdoor-grade acrylic textile. Outdoor acrylic fabric used in tent and cover applications is produced at weights from 300 to 600 GSM, with denser constructions providing greater tear resistance and water column pressure ratings. A PU-coated acrylic cover fabric achieves hydrostatic head ratings of 1,000 to 3,000 mm, indicating resistance to rain penetration under moderate-to-heavy precipitation. Acrylic outdoor covers resist UV degradation for up to 5 years in direct sun exposure, performing longer than polypropylene covers that degrade within 1 to 3 years under continuous UV exposure. Retail pricing for acrylic outdoor cover fabric runs from [$8 to $25] per yard, depending on weight, coating type, and width.
8. Acrylic Yarn for Knitting and Crochet (Craft and textile production material)
Acrylic yarn for knitting and crochet is a plied staple fiber yarn produced from crimped acrylic staple fiber spun into continuous strand form for use in hand and machine textile craft production. Acrylic yarn accounts for a significant portion of global craft yarn sales due to its low cost, wide color availability, and machine-washable performance compared to natural fiber yarns. Standard consumer acrylic yarn is sold in skeins of 100 to 400 grams, with yarn weights ranging from lace weight (0) to super bulky weight (6) on the Craft Yarn Council standardized weight system. Retail prices for acrylic craft yarn range from [$3 to $15] per 100-gram skein, compared to wool yarn at [$10 to $40] or alpaca yarn at [$20 to $60] per equivalent weight. Acrylic yarn is spun at staple lengths of 38 to 76 mm and twist levels of 300 to 600 turns per meter (TPM), with higher twist producing firmer, more stitch-definition-friendly yarn for structured crochet and colorwork knitting patterns.
9. Acrylic Sportswear Fabrics (Lightweight performance clothing)
Acrylic sportswear fabrics are lightweight knitted or woven textiles produced from fine-denier acrylic fiber for use in athletic apparel, activewear, and performance clothing applications. The fiber's low moisture absorption (1% to 2% regain) contributes to faster drying and reduced fabric weight during physical activity compared to cotton sportswear fabrics with a moisture regain of 7% to 8%. Acrylic sportswear fabric is produced at weights from 120 to 250 GSM for jersey, interlock, and mesh knit structures, providing a range of breathability and coverage options for athletic garments. The fiber's UV resistance makes acrylic sportswear suitable for outdoor athletic activities (running, cycling, and training) where prolonged sun exposure is anticipated. Acrylic sportswear fabric is often blended with spandex (5% to 10% by weight) to introduce stretch recovery and improve fit retention during dynamic movement. Retail prices for acrylic sportswear garments range from [$15 to $55] depending on construction, blend composition, and brand market positioning.
10. Acrylic Faux Fur Fabrics (Synthetic imitation fur for fashion and décor)
Acrylic faux fur fabrics are synthetic textile materials constructed from high-pile acrylic fiber to replicate the appearance and tactile feel of natural animal fur for use in fashion garments, accessories, and home décor products. The pile structure of faux fur fabric is produced by tufting or knitting long-staple acrylic fiber (25 mm to 100 mm pile height) onto a woven or knitted backing substrate. Acrylic faux fur is manufactured in a wide range of pile densities and textures, from short shearling-style piles at 10 to 15 mm to long-pile mink and fox imitations at 50 to 100 mm height. The fiber denier for faux fur ranges from 1.5 dpf for fine, silky pile to 6 dpf for coarser, structured pile constructions. Retail pricing for acrylic faux fur fabric ranges from [$8 to $35] per yard, depending on pile height, density, and surface treatment. Acrylic faux fur is used in coat linings, throw pillows, blankets, stuffed toys, and theatrical costume production as an ethical and cost-effective alternative to genuine animal fur.
"Successful product integration relies on understanding how manufacturing history alters polymer behavior under real-world stress. For instance, specifying cell-cast acrylic over extruded stock eliminates edge crazing during laser processing (due to its isotropic, stress-free molecular matrix), while selecting low-tenacity grades in synthetic textiles purposefully mitigates pilling failure modes under cyclic friction. Designing for production means looking past the nominal datasheet and engineering for the chemical, thermal, and physical environments your assembly will actually face."
What Are the Best Plastics For Laser Cutting And Acrylic Applications?
The best plastics for laser cutting and acrylic applications are listed below.
- Acrylic (PMMA): Cast acrylic is the top-performing plastic for laser cutting, producing flame-polished edges with optical clarity directly from the cut without secondary finishing. Cast acrylic sheets are cut at speeds of 10 to 30 mm/second on standard CO₂ laser systems at power settings of 25 to 80 watts, depending on thickness.
- Delrin (Acetal/POM): Delrin cuts cleanly with minimal edge discoloration and is preferred for precision mechanical parts (gears, bushings, and cams) where tight dimensional tolerances are required. Delrin sheets produce a low odor during cutting and do not release chlorine-based fumes.
- PETG (Polyethylene Terephthalate Glycol): PETG laser cuts with moderate edge quality and is valued for its chemical resistance and food-safe properties in packaging and laboratory equipment applications.
- HDPE (High-Density Polyethylene): HDPE laser cuts with some edge melting, but is used for cutting boards, gaskets, and chemical-resistant panels where surface finish precision is secondary to material performance. For more information on the best plastics for laser cutting.
What Plastics Are Commonly Used for Laser Cutting Projects?
Plastics that are commonly used for laser cutting projects are listed below.
- Cast Acrylic (PMMA): Cast acrylic is the most commonly specified plastic for laser cutting due to its ability to produce flame-polished, optically clear edges directly from the cutting process. Available in thicknesses from 1.5 mm to 25 mm, cast acrylic cuts at speeds of 10 to 30 mm/second at power levels of 25 to 80 watts on standard CO₂ systems.
- Extruded Acrylic: Extruded acrylic cuts with slightly less edge clarity than cast acrylic and is more cost-effective for high-volume production runs where optical edge finish is not the primary requirement.
- Polypropylene (PP): Polypropylene laser cuts with some edge roughness but is used in food-safe packaging, medical device housings, and living hinge applications where its flex fatigue resistance is valued.
- ABS (Acrylonitrile Butadiene Styrene): ABS cuts with acceptable edge quality but releases styrene fumes during cutting, requiring ventilated laser enclosures or exhaust filtration systems for safe operation.
- Polyimide (Kapton): Polyimide film (25 to 500 micrometers thick) laser cuts to precision tolerances for flexible circuit substrates, gaskets, and electrical insulation components in aerospace and electronics manufacturing.
Is Acrylic One Of the Best Plastics for Laser Cutting Precision And Clarity?
Acrylic is one of the best plastics for laser cutting precision and clarity. Cast acrylic (PMMA) responds to CO₂ laser energy by vaporizing through depolymerization at the cut line, producing a flame-polished surface with optical clarity equivalent to the original material without secondary buffing or polishing. The cut edge transmits light at approximately 92% transmittance, identical to the base material's optical performance. Laser-cut acrylic achieves dimensional tolerances of ±0.1 mm to ±0.25 mm on standard CO₂ systems, making it the preferred material for precision signage, display components, optical diffusers, and decorative panels where edge quality and dimensional accuracy are critical. Extruded acrylic produces slightly less polished edges than cast acrylic under laser cutting, as its high residual stress and directional molecular orientation cause minor stress fracturing at the cut line. Cast acrylic consistently delivers the best performance across standard laser cutting parameters for applications requiring the highest edge clarity and tightest tolerances, reinforcing its position as the reference material for precision laser cutting in plastic fabrication.
