Die Casting Services for Northern Mariana Islands
High Quality Die Casting serving Northern Mariana Islands| ITAR Registered | 60+ Materials Available | Parts in as Fast as 24 Hours | Xometry doesn't guarantee that we can provide this service at any given time.
Die Casting Process
Our project managers and experts personally review and manually quote each die casting project to ensure we meet your unique needs while providing a fast and easy manufacturing experience. Learn more about the process and our capabilities in the sections below.
Xometry's Die Casting Service in Northern Mariana Islands
Start A Quote
Sample Approval
Production Begins
Hot Chamber Die Casting
Cold Chamber Die Casting
Die Cast Metal Materials Available Near Northern Mariana Islands
Aluminum Die Casting
- Withstand high operating temperatures
- Corrosion Resistance
- Good stiffness
- High thermal and electrical conductivity
- A360.0
- A380.0
- A383.0 (ADC12)
- A413.0
Zinc Die Casting
- Impact strength
- High hardness
- Great stability
- High-quality surface finish and easily plated
- Low melting point
- Zamak 2 (ZA-2)
- Zamak 3 (ZA-3)
Applications of Die Casting
- Aerospace & Automotive Components
- Connector Housings
- Pumps and Plumbing Fixtures
- Outdoor lighting
- Gears
- Appliances and Lighting
Advantages of Die Casting
Complex Geometry
Strength
Precision
Custom Finishes
Disadvantages of Die Casting
Tooling Cost
Not for Low Quantities
Lead Times
