Search
CapabilitiesCustom Die Casting ServicesWest Virginia
Die Casting Services for West Virginia
High Quality Die Casting serving West Virginia| ITAR Registered | 60+ Materials Available | Parts in as Fast as 24 Hours | Xometry doesn't guarantee that we can provide this service at any given time.
Die cast metal parts
Die Casting Process
Our project managers and experts personally review and manually quote each die casting project to ensure we meet your unique needs while providing a fast and easy manufacturing experience. Learn more about the process and our capabilities in the sections below.
    Xometry's Die Casting Service in West Virginia
    quote engine
    Start A Quote
    Parts
    Sample Approval
    Machine Hours
    Production Begins
    Hot Chamber Die Casting
    Cold Chamber Die Casting
    Die Cast Metal Materials Available Near West Virginia
    Aluminum Die Casting
    • Withstand high operating temperatures
    • Corrosion Resistance
    • Good stiffness
    • High thermal and electrical conductivity
    • A360.0
    • A380.0
    • A383.0 (ADC12)
    • A413.0
    Zinc Die Casting
    • Impact strength
    • High hardness
    • Great stability
    • High-quality surface finish and easily plated
    • Low melting point
    • Zamak 2 (ZA-2)
    • Zamak 3 (ZA-3)
    Available Die Casting Finishes near West Virginia
    Standard (As-Cast)
    Bead Blasted
    Powder Coating
    Wet Painting
    Plating
    Chemical Film
    Media Tumbled
    Custom
    Isometric illustration of the die casting process.
    Applications of Die Casting
    • Aerospace & Automotive Components
    • Connector Housings
    • Pumps and Plumbing Fixtures
    • Outdoor lighting
    • Gears
    • Appliances and Lighting
    Advantages of Die Casting
    Complex Geometry
    Strength
    Precision
    Custom Finishes
    Disadvantages of Die Casting
    Tooling Cost
    Not for Low Quantities
    Lead Times
    Die Casting Services near West Virginia
    Morgantown
    West Virginia
