CapabilitiesNylon 3D Printing Service
Get instant online quotes on parts in nylon materials. Free shipping on all US orders. ISO 9001:2015, ISO 13485, IATF 16949:2016, and AS9100D certified.
Close-up of glass filed SLS PA12.
  • About Nylon
  • FDM Nylon Materials
  • MJF Nylon Materials
  • SLS Nylon Materials
  • Cost-Saving Tips
  • Finishes & Photos
About 3D Printing Nylon
3D printed nylon comes in many different forms, namely as a filament for FDM (fused deposition modeling) or as a powder for SLS (selective laser sintering) and MJF (HP Multi Jet Fusion) printing. 3D printing nylon creates parts with excellent properties but it’s important to understand that the type of 3D printing process will determine the final part capabilities. For example, FDM prints will have an anisotropic structure caused by the extruded layer lines. Even SLS-printed parts will have a level of anisotropy between layers. MJF parts tend to have isotropic properties, meaning the material will behave the same regardless of the direction of the load. However, with correct setups and part orientation, anisotropic effects can largely be negated and parts can benefit from the excellent properties of nylon.
Nylon is a high-performance engineering thermoplastic found in a wide range of industries. Its popular usage stems from its excellent abrasion resistance, high fatigue resistance, and high load-bearing capacity. Due to these properties, 3D printing in nylon is a great way to make lightweight industrial and medical implements that are just as capable as heavier metal ones.
3D Printed Nylon at a Glance
ApplicationsAdvantagesDisadvantagesComparitive CostLayer HeightBuild Envelope
Applications
  • Gears
  • Air Ducts
  • Snap fits
  • Brackets
  • Clips
Advantages
  • Low friction coefficient
  • Excellent toughness
  • High impact resistance
Disadvantages
  • Prone to moisture absorption
  • Prone to warp
Comparitive Cost
(Low-Medium)
Layer Height
MJF:
0.0031"
SLS:
0.0047"
FDM:
0.007" - 0.013"
Build Envelope
MJF:
15 x 11 x 15"
SLS:
26" x 15" x 23"
FDM:
24” x 36” x 36”
Information based on US-based services. Build envelopes listed represent the maximum available size; some materials may be limited to smaller platforms.
FDM Nylon Materials
We offer two distinct Nylon variants through our Fused Deposition Modeling (FDM) process, enabling you to select the ideal balance of performance and stability for demanding applications.
  • Stratasys Nylon 12 is suitable for large-scale parts demanding reliability and resilience. This high-grade formulation delivers exceptional dimensional stability, ensuring mechanical properties are retained over extended use. It is inherently resistant to shocks and fatigue, making it the perfect material for components that must endure repeated load/unload cycles and significant operational vibration.
  • Nylon 6 CF is an excellent choice when your design requires maximum strength and stiffness with minimal weight. This composite utilizes carbon fiber chop reinforcement to create incredibly strong, stiff, and lightweight parts. This versatile material has been popularized by industry leaders, including Markforged Onyx, as well as other carbon-filled filaments from Bambu Lab, Polymaker, and others. It's highly suited for printing light-weight fixtures, clamps, and structural components that require superior performance and heat resistance.
Note that FDM materials are inherently anisotropic. This means the orientation of the deposited layers strongly influences the resulting mechanical properties. Our experts carefully consider the build orientation to optimize strength and performance, providing you with reliable, high-integrity components.
FDM Nylon Material Properties
Material NameTensile Strength (MPa)Elongation at Break (XY, ZX %)Heat Deflection Temperature (℃) @ 66psiImpact Strength, NotchedNotes
Material Name
Nylon 6 CF
48-102
5.8, 3.7
186
13.4 kJ/m² per ISO 179
Notes
Carbon fiber-filled, stiff, improved aesthetics
Material Name
Nylon 12
41.8-49.3
6.5-30
91.9-94.7
71-138 J/m per ASTM D256
Notes
Stratasys OEM brand, balanced performance
Figures are indicative values based on supplier data and may vary depending on processing conditions. Provided for reference only.
Nylon 6 CF material properties and appearance may vary slightly due to a broad material and equipment allowance; data is for reference only. Nylon 12 properties achieved by running OEM materials and parameters on OEM Fortus equipment. See our FDM page for complete data sheets.
MJF Nylon Materials
Our Multi Jet Fusion (MJF) offering elevates Nylon's already excellent material properties, delivering production-ready parts with unmatched quality and consistency. MJF utilizes a unique fusing process that creates components with significantly greater isotropic properties and superior surface finish compared to FDM or FFF. Parts printed using MJF exhibit high detail and resolution, are inherently watertight, and are suitable for both rapid prototyping and end-use applications.
We offer multiple high-performance Nylon variants to meet your specific application needs:
  • Nylon 12 is our "go-to" material for MJF, providing an excellent balance of mechanical strength, ductility, and chemical resistance. It is the ideal choice for general-purpose end-use parts, durable enclosures, and complex components.
  • Nylon 11 is derived from renewable castor seeds, offering enhanced impact strength and ductility, making it more flexible and fracture-resistant. Use it for parts requiring higher flexibility, snap-fit features, and applications where fatigue resistance is critical.
  • Nylon 12, Glass-filled (GF), is nylon 12 reinforced with glass beads. This variant provides significantly increased stiffness, rigidity, and dimensional stability. It is the best option for jigs, fixtures, and structural components that require higher temperature resistance and greater load-bearing capabilities.
  • Nylon 12, White offers the same mechanical benefits as our standard Nylon 12, but with a bright white base, allowing for parts to be dyed a variety of vibrant colors. This material is well-suited for prosthetics, orthotics, and functional prototypes.
  • Nylon 12, Smooth is a material specifically formulated to produce exceptionally smooth parts right off the machine. This material is a cost-effective choice for highly visible, end-use components. When paired with a vapor-smoothed finish, components are left with a finish rivaling that of injection-molded parts.
  • Nylon 12, Multi-Color (CB) enables the production of full-spectrum color parts with functional engineering properties, perfect for architectural models and functional multi-color prototypes and assemblies complete with branding or photorealistic textures. Users who require a versatile and functional material but need to eliminate the time and cost associated with secondary painting or labeling will find great value in this option.
MJF Nylon Material Properties
Material NameTensile Strength (MPa)Elongation at Break (%)Heat Deflection Temperature (℃) @ 66psiImpact Strength, NotchedNotes
Material Name
Nylon 11
52
55, 40 (XY, ZX)
185
6, 5 kJ/m² (XY, ZX)
Notes
Flexible and fracture-resistant, snap-fits and clips
Material Name
Nylon 12
48
20, 15 (XY, Z)
175
3.5 kJ/m²
Notes
Balanced properties, general-purpose
Material Name
30
10
174
3 kJ/m²
Notes
40% glass bead-filled, increased stiffness
Material Name
Nylon 12, White
45
17, 9 (XY, Z)
N/A *
4.4 kJ/m²
Notes
General purpose, bright white parts
Material Name
Nylon 12, Smooth
43
12, 5 (XY, Z)
N/A *
2.5, 2 kJ/m² (XY, Z)
Notes
Produces extra smooth parts
Material Name
46
20, 14 (XY, Z)
N/A *
3.1, 2.8 kJ/m² (XY, Z)
Notes
Produces full-color parts
Figures are indicative values based on US-supplier data and may vary depending on processing conditions. Provided for reference only. See our MJF page for full data sheets.
* HDT not tested; expected to be comparable to standard Nylon 12.
SLS Nylon Materials
Our Selective Laser Sintering (SLS) process allows for enhanced design and material customization for nylon components. SLS produces parts with exceptional resolution and detail, providing high-dimensional accuracy and reliable mechanical properties. A key benefit of SLS nylon is the availability of naturally white materials that can be easily dyed a variety of colors, allowing for visual customization without sacrificing performance. Furthermore, SLS boasts a broad array of filled and specialty materials, enabling you to select the exact properties needed for demanding applications, from rigidity and thermal stability to flame resistance.
We offer both standard and advanced nylon formulations through our SLS process:
  • Nylon 11 EX is an excellent choice for parts requiring high flexibility and impact resistance. Derived from renewable sources, this material is ideal for thin-walled components, living hinges, and applications that require superior ductility and fatigue performance. Nylon 11 EX is naturally off-white.
  • Nylon 12 is the industry-standard SLS polymer, known for its balanced mechanical strength, excellent chemical resistance, and high rigidity. It serves a wide range of applications for durable, general-purpose functional prototypes and end-use parts. Our standard nylon 12 is white and can be dyed in a variety of colors.
  • Nylon 12, Smooth (PA950 HD) produces parts with enhanced stability and surface quality, in part due to its formulation and fine particle size. It's an excellent choice for creating components with balanced mechanical properties with a smooth, aesthetically pleasing finish. When paired with our vapor-smoothed finishing option, you can easily achieve cosmetics that rival those of injection-molded parts.
  • Formlabs Nylon materials are also available, offering additional cost-effective solutions. Formlabs Nylon 12 is available in standard and glass-filled variants, and is great for general-purpose or extra-rigid parts, respectively. For parts that require extra flexibility, such as snapfits and clips, Formlabs Nylon 11 is an excellent option. These materials are naturally dark gray, so they do not require additional dyeing for dark parts.
  • Specialty nylon 12 materials are available for enhanced performance. We offer advanced composite powders infused with various fillers, including Glass-Filled (GF), Carbon-Filled (CF), and Aluminum-Filled (AF) options, which provide increased stiffness and thermal resistance. Additionally, we offer specialized variants such as Mineral-Filled (HST) for enhanced stability and Flame Retardant (FR) for safety compliance.
SLS Nylon Material Properties
Material Name
Nylon 11 EX
45
45
188
No Break
Notes
Flexible and impact-resistant, off-white color
Material Name
Formlabs
Nylon 11
49
40
182
71 J/m (notched izod)
Notes
Flexible and impact-resistant, black color
Material Name
Nylon 12
48-42 (XY, Z)
4-18 (Z, XY)
157-146 (XY, Z)
4.8 kJ/m²
Notes
Balanced properties, general-purpose white parts
Material Name
Nylon 12, Smooth
(PA950 HD)
44-41 (XY, Z)
6-13 (Z, XY)
164-167 (XY, Z)
N/A
Notes
Extra smooth surface finish, high-visibility parts, grey color
Material Name
Formlabs
Nylon 12
50
6-11 (Z, XY)
171
32 J/m (notched izod)
Notes
Balanced properties, general-purpose dark gray parts
Material Name
51-47 (XY, Z)
9
157
5.4 kJ/m²
Notes
40% glass bead-filled, increased stiffness, beige color
Material Name
Formlabs
Nylon 12 , GF
38
3-4 (Z, XY)
170
36 J/m (notched izod)
Notes
Extra rigid, high thermal stability, dark gray color
Material Name
Nylon 12, AF
(PA 605-A)
43-37 (XY, Z)
3
180
58.7 J/m
Notes
40% Aluminum-filled, highly stiff, metallic appearance
Material Name
Nylon 12, CF
(PA 602-CF)
66
5
175
54 J/m
Notes
23% carbon-fiber-filled, resistant to warping at high heat
Material Name
Nylon 12 HST
(PA 620-MF)
51-34 (XY, Z)
3-5
184
N/A
Notes
25% mineral-filled, increased stiffness for higher heat applications
Material Name
Nylon 12 FR
(PA 606-FR)
48
24
180
32 J/m
Notes
Flame retardant (FAR 25.853 60 second)
Figures are indicative values based on US-supplier data and may vary depending on processing conditions. Provided for reference only. See our SLS page for full data sheets.
Cost-saving Design Tips
DFM: Each type of 3D printing technology requires special considerations during the design phase. For example, with FDM parts you should be mindful of support structures and consider the layer orientation that will generate maximum strength. SLS and MJF parts need drain holes to remove unused powder from internal cavities and should not have overly thick walls. Design-for-manufacturability (DFM) principles need to be applied from the start.
Choose the right plastic and process: Each of the above plastics and process combinations is better suited to certain applications. If the goal is to produce a temporary tooling jig, then Nylon 12 in FDM may be suitable. However, if a visual prototype is required, then SLS or MJF may better suit your needs. Use specialty or filled materials when the application demands it; otherwise, you may be paying more for characteristics you don't need.
    MJF Materials
    Finishes
    Xometry offers a wide range of surface finishes for nylon 3D prints, some of which are listed below. Visit our finishes page to learn about our other finishing options.
    Standard: Available for all technologies and materials. Printing supports are removed from the part, but no additional work is done to the finish. Note that SLS and MJF parts have much better off-the-machine finishes than FDM and do not require the removal of support structures.
    Color Dyeing: Parts are submerged in a dye solution that penetrates roughly ~0.010” into the surface, altering the surface’s color. Coloration may vary slightly from batch to batch. Available for SLS and MJF nylon parts.
    Vapor Smoothing: Vapor smoothing creates a uniform, sealed surface with a semi-gloss appearance. It can be combined with our color dyeing option. Available for SLS and MJF nylon 12 parts.
    Nickel plating: This surface treatment is not for cosmetic applications, as it creates a rough nickel finish. However, it adds additional durability, stiffness, and wear resistance. This finish is only available for SLS nylon parts.
      Samples of SLS PA12 dyed in various colors.
      Drone part 3D printed in Nylon 6 CF via FDM.
      Bust 3D printed in Nylon 12 via SLS.
      SLS Nylon 12 Aluminum-Filled (AF) with Polyshot Finish
      Need Parts 3D Printed in Nylon?
      Get instant pricing and lead times today!
