Sheet Metal Fabrication Services for West Virginia
High Quality West Virginia Sheet Metal Fabrication | Lead times as fast as 1 day and free standard shipping on all US orders.
Rapid Tooling
End-Use Production
Your West Virginia Sheet Metal Fabrication Service: Prototypes and Production Cuts
Stainless steel 301
Stainless steel 304
Stainless steel 316/316L
Steel 1018 (Low Carbon)
Type II (MIL-A-8625, Type II) creates a corrosion-resistant finish. Sheet metal parts can be anodized in different colors—clear, black, red, and gold are most common—and are usually associated with aluminum. Type III (MIL-A-8625, Type III, Class 1/2 "hardcoat") is thicker and creates a wear-resistant layer in addition to the corrosion resistance seen with Type II.
Standard Sheet Thicknesses
Locations near West Virginia
