Local 3D Printing Service in Columbus
High quality Columbus 3D printing
Get an Instant Quote
Your Columbus 3D Printing Service
Stereolithography (SLA)
HP Multi Jet Fusion (HP MJF)
PolyJet 3D (PJ3D)
Advantages of 3D Printing
Durability
Rapid Turnaround
Part Production
Complex Geometry
Scalability
Precision
3D Printing Materials
Rigid Plastics
  • ABS
  • ABSi
  • ABS-ESD7
  • ABS-M30
  • ABS-M30i
  • Accura 48HTR
  • Accura 60
  • Accura ABS
  • Accura Bluestone
  • Accura ClearVue
  • Accura Xtreme
  • ASA
  • Nylon 12 (Unfilled)
  • Nylon 12 (Glass-Filled)
  • PC-ISO
  • Polycarbonate
  • PPSF
  • Rigid Photopolymer
  • Somos NeXt
  • Somos PerFORM
  • Somos Protogen 18420
  • Somos ProtoTherm 12120
  • Somos Taurus
  • Somos Watershed XC 11122
  • Ultem 1010
  • Ultem 9085
Available Aluminum Varieties:
  • AlSiMg
Steel
Available Steel Varieties:
  • Stainless Steel 17-4
  • Stainless Steel 316L
Flexible Plastics
  • Accura 25
  • PC-ABS
Rubber-Like Plastics
3D Printing Finishes
Standard
Media Tumbled
Additional Finishes
Applications for 3D Printing
Concept Models
Concept Models
Production Parts
Production Parts
Medical
Aerospace
Robotics
Industrial
Electronics
Consumer Products
Automotive
Tommy Lynch
Tommy Lynch
Applications Engineer
Additive Guru
Ready to quote?
Machine Hours
13MM+
Parts Quoted
1MM+
