CapabilitiesWire EDM Machining Service
High-quality wire EDM parts with free shipping in the US. ISO 9001:2015, AS9100D, IATF 16949:2016 & ISO 13485 certified.
Custom Wire EDM Machining With Xometry
    Other CNC Machining Services From Xometry
    CNC milling
    Custom CNC Milling Services
    Instant quotes on custom milled metal and plastic parts | Quick-turn prototypes and production parts in days | Free standard shipping on all US orders | International prototype pricing includes tariffs | ISO 9001:2015, ISO 13485, IATF 16949:2016, AS9100D certified. ITAR registered.
    CNC Turning
    CNC Turning Service
    Instant quotes on custom metal and plastic turned parts | Quick-turn prototypes and production parts in days | Free standard shipping on all US orders | International prototype pricing includes tariffs | ISO 9001:2015, ISO 13485, IATF 16949:2016, AS9100D certified. ITAR registered.
    CNC Turning Service
    Wire EDM Machining Finishes Available
    Standard Finish (as-milled)
    Bead Blast
    Tumbled
    Type II  (MIL-A-8625/MIL-PRF-8625, Type II) creates a corrosion-resistant finish. Parts can be anodized in different colors—clear, black, red, and gold are most common—and is usually associated with aluminum. Type III (MIL-A-8625/MIL-PRF-8625, Type III, Class 1/2 "hardcoat") is thicker and creates a wear-resistant layer in addition to the corrosion resistance seen with Type II.
    Titanium Anodize
    PTFE Impregnated Hard Anodize
    Chem Film
    Passivation
    Powder Coat
    Electropolishing
    Electroless Nickel Plating
    Silver Plating
    Silver offers high solderability and electrical conductivity but is susceptible to tarnish. Conforms to AMS QQ-S-365D. Thickness is about 0.00002” - 0.0003.”
    Gold Plating
    Zinc Plating
    Ready to get started on your wire EDM machining project?
    Free shipping available for domestic CNC orders ; learn more!
