Xometry Logo
CapabilitiesIndustriesResourcesSuppliesBecome a SupplierFind Suppliers
Sign In
Cookie Policy
3D Printing in Resin (DLS)
3D printing in Carbon DLS™ resins offers something that many material and machine manufacturers strive for: the ability to manufacture both prototypes and high-quality production parts using the same common materials and the same process. Read on to learn more about the wide range of available DLS photopolymers.
Carbon DLS RPU 70 rigid polyurethaneCarbon DLS RPU 70 rigid polyurethane
About 3D Printing in Resin (DLS)
Parts made from DLS materials make use of the CLIP (Continuous Liquid Interface Production) process. To the outside observer, the production looks similar to standard photopolymer printing (similar to SLA 3D printing) but it uses a far more complex process to achieve high-quality parts, including a curing stage after printing. The increased complexity of DLS printing means that it can use a wide array of engineered materials and all parts are isotropic. This allows for unique applications in cost-effective, advanced materials that have not been traditionally possible with other printing technologies.
3D Printed DLS at a Glance
ApplicationFixtures, skin-contact wearables, connectors, vibration isolation, living hinges
AdvantagesBiocompatible, rigid and soft materials, extremely fine detail
DisdvantagesCostly
Lead TimeAverage 6 days; expedited parts as are fast as 3 days. More economical lead times are available as well.
Price$$
Minimum Feature Size0.030” (0.762 mm)
Tolerances+/- 0.005” for the first inch is typical, plus +/- 0.002” for every inch thereafter.
Layer HeightN/A - continuous growth with vertical striations
Max Part SizeThe typical build area is 7.4” x 4.6” x 12.8”. Parts with dimensions exceeding 4” x 4” x 6” will require manual review.
MJF Nylon 11 EX
Nylon 11 EX for MJF-printed parts has good mechanical properties with excellent chemical resistance and low moisture absorption rates. It is resilient and can deform to a much larger extent than other nylons, making it ideal for snap-fit components.
DLS UMA 90 (Urethane Methacrylate)
Tensile Strength (MPa)Elongation at Break (%)Hardness (Shore D)Heat Deflection Temperature (℃)Impact Strength Notched (kJ/m2)
461786510.033
DLS EPX 82 (Epoxy)
This is an epoxy-based photopolymer that offers excellent strength, durability, and toughness. Its strength is comparable to that of glass-filled thermoplastics. Its applications can include brackets and connectors.
DLS EPX 82 (Epoxy) Properties
825.9891300.044
DLS CE 221 (Cyanate Ester)
This is an advanced material that offers extremely high temperature and chemical resistance. This makes it ideal for applications that include exposure to corrosive fluids at high temperatures and pressures such as compressor screws or fluid manifolds.
DLS CE 221 (Cyanate Ester) Properties
Ultimate Tensile Strength (MPa)Elongation at Break (%)Hardness (Shore D)Heat Deflection Temperature (℃)Impact Strength Notched (kJ/m2)
923.3922310.015
DLS RPU 70 (Rigid Polyurethane)
This material is a rigid polyurethane with typical thermoset plastic benefits such as good impact resistance, durability, and relatively high-temperature resistance. Some applications can include push-in rivets or equipment housings.
DLS RPU 70 Properties
35100771200.075
DLS FPU 50 (Flexible Polyurethane)
This flexible polyurethane exhibits excellent abrasion, fatigue, and impact resistance. These properties make it ideal for applications that undergo multiple load/unload cycles like living hinges or friction fits.
DLS FPU 50 Properties
2520071700.04
DLS EPU 40 (Elastomeric Polyurethane)
This polyurethane is highly elastic and is comparable to other conventional casting thermosetting elastomers. Its energy-return properties are excellent, and it performs better in terms of tear strength and elongation than most similar materials. These properties make it perfect for vibration isolation or sealing applications.
DLS EPU 40 Properties
Tensile Strength (MPa)Elongation at Break (%)Hardness (Shore A)Heat Deflection Temperature (℃)Tear Strength (kN/m)
7.7> 250681020
DLS SIL 30 (Silicone)
This material exhibits low hardness ratings but high tear resistance. Thanks to these properties, plus its biocompatibility, this material is ideal for consumer products like wearables, headphones, and other items that come into regular contact with skin.
DLS SIL 30 (Silicone) Properties
Ultimate Tensile Strength, (MPa)Elongation at Break (%)Hardness (Shore A)Glass Transition Temperature (℃)Tear Strength (kN/m)
3.5350351010
Finishes
Materials intended for 3D printing in DLS resin—especially the softer elastomeric types—do not typically lend themselves to many surface finishes.
  • Standard: DLS parts ordinarily come off the machine with a matte or semi-glossy appearance. The specific appearance depends on the feature direction as well as the type of material.
  • Custom color: Only UMA 90 allows for custom color mixing; it typically comes in black or white.
SLS selective laser sinter nylon dyed blue part
Cost-saving Design Tips
To reduce expenditures when 3D printing in DLS, follow these cost-saving design tips:
  • DFM: DLS 3D printing technology requires special considerations when designing parts. Avoid creating internal voids and build drainage holes into the design to allow excess resin to be evacuated after printing.
  • Choose the right resin: Each of the above resins are well-suited to certain applications. If prototyping is the goal, then UMA 90 is ideal. If a soft, skin-contacting product is required, then the DLS SIL 30 is better suited. Selecting the best material for the job will reduce the number of finishing operations you need to perform to make the part perform its intended function.
    Need Parts 3D Printed in DLS Resin?
    Quick Links
    • Contact Us
    • Help Center
    • Our Story
    • Xometry Go Green
    • Careers
    • Legal
    • Press
    • Refer a Colleague
    Locations
    • 7529 Standish Place
      Suite 200
      Derwood, MD 20855
    • 7940 Cessna Avenue
      Gaithersburg, MD 20879
      240-252-1138
    • 7315 Wisconsin Ave
      Suite 300 East
      Bethesda, MD 20814
    • 446 East High Street
      Lexington, KY 40507
    • 11777 San Vicente Blvd
      Suite 747
      Los Angeles, CA 90049
    • 117 Wright Industrial Cove
      Jackson, TN 38301
    • Ada-Lovelace-Str. 9
      85521 Ottobrunn, Germany
      +49 32 22 109 8186
      www.xometry.eu
    Xometry Go Green Initiative
    2.0M+
    LBS OF C02 OFFSET
    Xometry
