ResourcesSheetLaser Etching: Definition, How It Works, and Process
 11 min read
Published March 9, 2023
Updated March 12, 2026
A decorative and important manufacturing process
Laser etching. Image Credit: Shutterstock.com/Evgeny Haritonov
Although lasers were invented in 1964, it took a whole 12 years for laser etching to be discovered. No one really knows who exactly came up with the idea, but since 1978, this technique has been used in industrial settings and by large manufacturers, but also by small businesses and hobbyists. In this article, we’ll talk about how this process works, why it’s so loved, and we’ll also get into practical aspects like which machines are worth buying and their costs.
What Does Laser Etching Mean?
Laser etching is used to create markings, patterns, and designs on materials for aesthetic or informational purposes using a focused laser beam. It can be performed on organic, synthetic organic, and inorganic materials, and there are different types of lasers that work best with each material, including CO2, fiber, crystal, and diode. The only exceptions are materials that release harmful toxins when heated.
Perhaps its most important use is adding serial numbers to products so that companies can easily track them, isolate problems, and deal with recalls, defects, and necessary design changes. Ultimately, it’s important to the quality assurance, safety, and durability of products. What’s more, it can be a highly profitable business. Sure, you’ll have to initially invest in the machinery but there is a big demand for these services, and the method is pretty beginner-friendly and easy to learn. There are also many online tutorials and resources available.
Below are all the important details on laser etching, like compatible (and non) materials, as well as applications and pros and cons.
Compatible materials
  • Easy to do on low melting point metals (magnesium, aluminum, anodized aluminum, zinc, lead)
  • Can be done on steel with a more powerful laser
  • Can be done on stainless steel but removes its protective coating (better to do laser annealing here)
  • Laserable brass
  • Wood
  • MDF (medium-density fiberboard)
  • Leather
  • Paper/cardstock
  • Ceramics
  • Glass
Non-compatible materials
  • PVC (polyvinyl chloride)
  • PVB (polyvinyl-butyral)
  • PTFE or Teflon
  • Beryllium oxide
  • Any material with halogen elements
Benefits
  • Durable, precise, clean marks (better quality than by acid or abrasive methods)
  • Quick, reduces production time
  • Highly customizable
  • Can be used on many different materials
  • No-contact, so no mechanical stress to the material and no chemical reactions
Disadvantages
  • Can wear out or distort in abrasive conditions
  • Machinery can be expensive
Applications
  • Personalized gifts, trinkets, and jewelry made of paper, wood, glass, and precious metals
  • DIY and home decor, decorative items
  • Brand symbols (logos, slogans, motifs)
  • Traceability and identification features (QR and barcodes, serial numbers)
  • Parts for the aerospace, automotive, and medical sectors
Who Invented Laser Etching?
Despite the fact that lasers were invented back in 1964, the laser etching process was not developed until 1978. Between 1964 and 1978, lasers were primarily used for welding and cutting. No one can say for sure who created the laser etching process but its creation has enabled hobbyists, small businesses, and large manufacturers alike to leverage its capabilities and benefits.
How Does Laser Etching Function?
Let’s get a little more technical. The etch mark is made with a laser that is blasted at the material. This modifies its surface, which expands and cools, and results in a slightly discolored and depressed mark that has raised edges all around it (shown below):
Laser etching machine
Pulsed lasers are typically used in the process as they’re better at etching than continuous wave lasers. These deliver powerful bursts of energy at set intervals, something that increases the energy absorbed by the material in a short period of time. Taking a 100W pulsed laser as an example, this can emit up to 100,000 pulses in just one second, whereas a continuous wave laser delivers the equivalent of 10,000 joules in the same timeframe. These short, high-intensity bursts, which are more powerful than a gentler, continuous stream, rapidly heat the material, causing it to melt, expand or, in the case of wood, decompose.
The laser power needed depends on the material used and its properties, like melting point or decomposition temperature. Wood, for instance, doesn’t melt but turns directly into charcoal and gases such as carbon dioxide. Plastics and metals melt into liquids before hardening again, but steel and other similar metals with high melting points will need much more laser power due to their thermal resistance. Also, some metals might need some pre-treating with a metal marking spray or paste before you can etch them so that their reflectivity is reduced and they can absorb more radiation.
What Is the Importance of Laser Etching?
Laser etching offers a fast, infinitely customizable, non-contact method for creating both artwork and practical product features, such as identification marks. In the aerospace, automotive, and medical industries, laser etching marks parts with serial numbers, barcodes, and QR codes. These markings contain vital information that tracks the source of a particular product throughout its entire life cycle. Laser etching can help manufacturers to ensure the safety and durability of their products for end users by allowing them to trace every part, enabling them to quickly institute recalls and make design or process changes if a product is defective.
What Are the Applications of Laser Etching?
There are many applications of laser etching. Some examples are listed below:
  1. Personalized gifts, trinkets, and jewelry made of paper, wood, glass, precious metals, and other materials
  2. DIY decor
  3. Brand symbols such as logos, slogans, and motifs
  4. Traceability and identification features, including barcodes, QR codes, and serial numbers.
How to Do Laser Etching?
As already discussed, the process isn’t a difficult one, but you do want to follow these steps for a high-quality and precise result.
  1. Safety first: Before you do anything else, make sure you look after yourself. This means putting on protective eyewear rated for the specific laser you’re using and working in a well-ventilated area so that fumes can escape.
  2. Prep: Convert your pattern into a format that’s compatible with your machine. This could be .dxf or a similar vector-based format.
  3. Settings: Adjust the machine’s settings—power, speed, frequency, and focus—according to the material you’re working on and the design. You’ll find how to do this in the manual.
  4. Secure the material: The workpiece has to be firmly held in place if you are to have any chance of success, and you can do this with clamps, tape, or adhesives.
  5. Begin: Once you double-check everything is in order, you’re ready to go—but don’t forget to continuously monitor the progress! Focusing the laser lens can be done manually as needed, but you can also use the auto-focus function that many machines come with.
Laser etching has many useful applications with a few being artwork, labeling, and locating. The artwork and labeling are self explanatory but to elaborate on the locating, laser etching is used for assembly work of sheet metal parts for alignment or installing hardware. Laser etching is a top surface detail that is not as durable as laser engraving, where engraving removes material. Laser etching is only achievable with fiber lasers, while laser engraving can be done with both fiber lasers and CO2 lasers.
Jake Thompson
Senior Solutions Engineer
What Kinds of Materials Can a Laser Etch?
Laser etching is used on a wide range of materials, including: metals, organic materials, plastics, and ceramics. Many metals may need to be coated with a metal marking spray or paste to reduce reflectivity and enhance the material’s absorption of laser radiation. Some examples of metals that can be laser etched are described in the list below:
1. Magnesium
It is easy to laser etch magnesium due to its relatively low melting point (1215°F) compared to other metals. Laser etching magnesium and its alloys have low reflectivity and therefore do not need to be pretreated.
2. Aluminum
Aluminum’s relatively low melting point (1216°F) compared with other metals makes it easy to laser etch. Its widespread use in several industries makes aluminum one of the most common metals for laser etching.
3. Zinc
Zinc’s exceptionally low melting point (786°F) makes it easy to laser etch. Zinc and its alloys are commonly used in diecast parts and automotive components. Laser etching can efficiently produce high-contrast and permanent marks such as barcodes on zinc parts.
4. Lead
Lead is another metal that is easy to laser etch because of its low melting point (621°F). Laser etching lead can result in surfaces displaying different shades of black, white, and gray. This makes traceability easy for lead parts.
5. Steel
Steel is a commonly used material for laser etching considering its widespread use across several industries. The degree of difficulty for laser etching steel largely depends on the type of steel alloy and its chemical composition. Steel requires more powerful lasers compared to the other metals on this list due to its higher melting point (2370-2800°F).
6. Anodized Aluminum
The melting point of anodized aluminum is the same as that of naturally oxidized aluminum. The primary difference between the two materials is that anodized aluminum has a thin layer (between 0.002-0.07 mm) of aluminum oxide on its surface that protects it against corrosion and abrasion. This makes laser etching ideal for anodized aluminum as it does not affect the material’s passivation layer.
7. Stainless Steel
Caution is advised when laser etching stainless steel. The outer protective coating that makes it resistant to corrosion is removed by the laser etching process. While the material can be etched, its appearance and performance can be affected. Consequently, laser annealing is more commonly used to mark stainless steel.
8. Laserable Brass
Laserable brass is a special type of brass that is coated with lacquer or enamel. This material assists the metal in absorbing laser radiation since bare brass is typically highly reflective.
What Kinds of Materials Are Commonly Used in Laser Etching?
A wide variety of materials are used in laser etching. Some of them are listed below:
  1. Wood
  2. Medium-density fibreboard (MDF)
  3. Leather
  4. Paper and cardstock
  5. Plastics
  6. Metals
  7. Ceramics
  8. Glass
What Kind of Materials Can You Not Laser Etch?
Several materials should not be laser etched, including:
  1. Polyvinyl chloride (PVC)
  2. Polyvinyl-butyral (PVB)
  3. PTFE or Teflon™
  4. Beryllium oxide
  5. Any material containing halogen elements
What Are the Advantages of Laser Etching?
The advantages of laser etching are listed below:
  1. Produces superior quality marks compared to traditional methods that use acids or abrasion
  2. A faster process compared to traditional marking methods
  3. Can be used on a wide variety of materials
  4. Is a non-contact process that doesn’t introduce mechanical stresses into the part or cause chemical reactions
What Are the Disadvantages of Laser Etching?
The disadvantages of laser etching are listed below:
  1. Marks made by laser etching wear out and become distorted if in an abrasive environment
  2. Upfront costs for laser etching machines can be high for smaller operations
What Are the Best Laser Etching Machines?
These machines cost anywhere from around $300 for basic starter machines to over half a million dollars for industrial-grade options. More expensive machines will understandably have a lot more capabilities, features, power, and precision. If you don’t have mass production needs and would rather not invest that much, there are some affordable options that work well. Just make sure that the piece of equipment you’re looking at can actually do what you need it to.
Whether you buy it from the manufacturer’s website or a large online retailer like Walmart or Amazon, check that a warranty and direct customer support are offered. Customer reviews are also helpful when you’re deciding which one to pick.
Here are three options that are fairly reasonably priced that we can recommend:
AttributeOMTech 50WAtomstack X7 ProOrtur Laser Engraver, Laser Master 2 S2 SF
Attribute
Type
OMTech 50W
Fiber laser
Atomstack X7 Pro
10W diode laser
1.6W diode laser
Attribute
Features
OMTech 50W
Works with many materials, exceptional precision, tolerances of ±0.0001 mm, operation speeds of up to 275 inches per second
Atomstack X7 Pro
Work area: 16.14 x 15.75 inches, spot size 0.002 x 0.002 inches, etching accuracy of ±0.08 mm
Compatible with many materials, etching accuracy of ±0.0125 mm
Attribute
OMTech 50W
$5,300
Atomstack X7 Pro
$570
$233
Attribute
Best for
OMTech 50W
Professionals who need to work on various materials with high precision and speed
Atomstack X7 Pro
Both beginners and professionals and those looking for a balance of affordability and efficiency
Beginners who need a low-cost entry-level machine for simpler projects
Where to Buy Laser Etching Machines?
Laser etching machines are primarily sold online and are available either directly from manufacturers or through e-commerce sites such as Amazon and Walmart.
How Much Does a Laser Etching Machine Cost?
A laser etching machine can cost anywhere from $300 to $500,000. The cost largely depends on the type of laser and the equipment and materials used to manufacture the system.
How Long Do Laser Etching Machines Last?
With proper care, use, cleaning, and maintenance (as per the manufacturer’s guidelines), these laser etching machines could last a good 10 years, sometimes even more. Other factors that contribute to their lifespan are construction quality, the type of laser it uses, how often it’s used, and the types of materials it works on.
FAQs on Laser Etching
Does laser etching wear off?
Yes; over time, the etching can wear off, especially if the item is in an abrasive or harsh environment. With etching, you’re essentially removing some of the surface of the material, and this can actually make it a little more vulnerable to wear and tear.
How does laser etching work on glass?
Laser etching glass involves the melting and deforming of the material’s surface, causing interactions between the metallic oxides used in glass coloring or strengthening, and silica with the air. This reaction forms tiny but visible fractures that result in the desired etched look.
Can You Make Money in Laser Etching?
Yes, laser etching can be a highly profitable business. There is high demand for laser etching for crafts, decor, and numerous other applications. Additionally, laser etching is easy to learn and has a low cost of entry.
Is Laser Etching Hard To Do?
No, laser etching is not difficult to learn. With plenty of low-cost machines and tutorials available online, anyone can master the basics and quickly get started with laser etching.
Can You Laser Etch Glass?
Yes, glass can be laser etched. Laser etching glass melts and deforms the surface, causing the metals (such as metallic oxides used for coloring or strengthening the glass) and silica in the glass to react with the air. This causes tiny fractures that can be seen and felt.
Is Laser Engraving the Same As Laser Etching?
No, laser engraving is not the same as laser etching. Laser engraving requires more laser power and vaporizes material away to create shallow cuts into a part. Laser etching requires less power and only melts material at its surface.
What Is the Difference Between Laser Engraving and Laser Etching?
The terms laser etching and laser engraving are often used interchangeably, but they shouldn’t be as they’re quite different. Laser engraving needs more laser power and works by vaporizing material away to create shallow cuts into a part, while etching requires less power and melts the material at its surface, making an altered or slightly raised mark. Basically, laser engraving makes cuts deeper into the part. We’ve got a couple of dedicated articles on these processes if you’re interested in learning more:
A Comprehensive Guide to Laser Engraving
Differences Between Laser Engraving vs. Etching
For any more information on laser etching, or if you want to know how you could get started with either performing the process yourself or finding services for your projects, feel free to contact an Xometry representative. You could also upload your designs to the Xometry Instant Quoting Engine® for a free, no-obligation quote.
