Metal Binder Jetting
Durable and Versatile
Metal Binder Jetting is a state-of-the-art technology that produces complex, fully-functional metal 3D printed parts at a fraction of the cost of traditional manufacturing methods.
We use industrial-grade stainless steel infiltrated with bronze to build large-scale metal parts (up to 29″ x 15″ x 14.25″).
In as little as 13 business days
Featured Resources
Maximum Print Sizes for 3D Printed Parts
We often receive questions from customers regarding the maximum size of a part that can be printed. It’s a great question and the answer depends entirely on the process you decided to use.
Applications
End-use Industrial Components
420 SS / Bronze is ideally suited for abrasive environments where parts are exposed to thermal, chemical and mechanical stress.
Precision, durability and a low cost per unit make Metal Binder Jetting a great option for prototyping.
Manufacturing Tools
High-performance materials make Metal Binder Jetting an excellent solution for producing jigs, fixtures, tool masters and production tooling.
Advantages
Durability
Metal Binder Jetting parts achieve greater than 90% density and offer excellent wear resistance.
Lightweight
Half-open mesh and honeycomb structures can be designed to reduce part weight while maintaining strength.
Large Build
Xometry can produce Metal Binder Jetting parts with build volumes up to 29″ x 15″ x 14.25″.
Complex Geometry
Geometries, including internal conformal cooling and heating channels, can be built more easily due to the 3D printing process.
Part Production
Metal Binder Jetting is capable of producing end-use parts on-demand, without the need for tooling or molds.
Materials
Metals
  • Brass/Bronze
  • Stainless Steel
Finishes
Standard
Parts are media tumbled for a clean, consistent polish.
Bead Blast
A process that leaves parts with a professional matte finish.
BJ3D Design Guide
Metal Binder Jetting (BJ3D) is a two-part process that produces incredibly durable additive parts in composite metal. BJ3D is a great choice for customers looking for a less expensive alternative to Direct Metal Laser Sintering and CNC parts.
Download out convenient Metal Binder Jetting Design Guide and learn how to design the perfect BJ3D parts for your next job!
Download Guide
Save 20% on your first order with code FIRST20
Offer valid on orders up to $10,000. One-time use for first-time Xometry users only. Cannot be combined with another offer. Limited time offer. Not valid on manual quotes.
