Manufacturing Capabilities
Xometry’s 4,000-strong Manufacturing Partner Network offers wide-ranging capabilities including CNC Machining, industrial-grade 3D Printing, Sheet Metal, Urethane Casting, and production-grade Injection Molding, all on one platform and just a click away. With Xometry you always have instant access to multiple manufacturing processes from quality facilities in our network.
CNC Machining Service
Xometry's Online CNC Machining Service
Xometry is the industry leader in custom, quick-turn CNC machining services for rapid prototyping and production parts. Our online Instant Quoting Engine gives you a CNC machining quote within seconds. Then we make your machined metal or plastic parts and get them to your door in as few as 2 days. We inspect the parts and guarantee their quality.
Sheet Metal Fabrication
Sheet metal fabrication is the process of forming parts from a metal sheet. 3D CAD files are converted into machine code, which controls a machine to precisely cut and form the sheets into the final part. Typical forming tools are brakes, punches, and dies which can form angular bends and features. Installing inserts, such as PEM inserts, is standard practice along with welding and finishing services. Sheet metal parts are known for their durability, which makes them great for end-use applications (e.g. chassis). Parts used for low volume prototypes and high volume production runs are most cost-effective due to large initial setup and material costs.
Our custom sheet metal services offer a cost-effective and on-demand solution for your manufacturing needs. Fabrication services range from low-volume prototype to high-volume production runs with significant cost savings.
Injection Molding Service
Xometry delivers high-quality, on-demand injection molded parts. Injection molding is the most cost-effective way to make a plastic part at scale and offers consistent quality for low-to-high volume manufacturing. Molding also has the highest variety of materials, colors, and configurations when compared to CNC machining or even 3D printing. Beyond materials, injection molded parts can have custom cosmetics, polishes, or surface textures.
Xometry takes a “have it your way” approach to molding. We specialize in complex projects, including those requiring side action or hand loaded inserts. Our goal is to provide a long-term solution, moving beyond rapid prototyping, with dedicated project managers and engineering experts to communicate through all project stages from design to production.
Xometry’s injection molding services include:
  • Free online file upload and quote submission
  • 24-hour quoting with design for manufacturing (DFM) feedback
  • Large domestic partner network as well as international options
  • Single point of contact per customer
  • Expert consultation
  • Single, multi-cavity, and family mold options
  • Insert molding and overmolding
  • Most plastic materials, including custom sourcing and matching
  • Press availability from 50 to 1,100+ tons
  • Part inspection, including FAI and PPAP options
  • Customer-owned tooling
  • Learn about our Injection Molding capabilities for the Medical Devices industry
Is your project ready for injection molding? Upload your 3D model for a free quote.
Stereolithography (SLA) 3D Printing Service
Stereolithography (SLA) is a powerful 3D printing technology that produces extremely accurate and high resolution parts that are capable of being used directly in end-use, low-volume production, or for rapid prototyping.
Stereolithography is an additive manufacturing process that focuses an ultraviolet (UV) light on a vat of photopolymer resin. It offers higher resolution printing than many other 3D printing technologies, allowing customers to print parts with fine details and surface finishes. Stereolithography 3D printing is a highly-versatile platform for making custom parts in prototype and production settings, often acting as a stand-in for injection molded plastic parts.
Xometry offers both standard and high-resolution options for fine detail parts, and can also print larger sized parts and products, offering up to a 29" inch build area. In addition, Xometry's manufacturing partner network allows us to offer a larger variety of materials than other 3D printing companies - we offer a wide range of both Accura and Somos brand materials.
For engineers who are heavy users of industrial 3D printing services, we have designed a subscription service to stretch your budget: 3D Printing Pro Membership.
Selective Laser Sintering (SLS) is a powerful 3D printing technology that produces highly accurate and durable parts that are capable of being used directly in end-use, low-volume production, or for rapid prototyping. SLS is one of the most inexpensive options for industrial 3D printing services because it can build parts in bulk without support structure requirements.
An additive manufacturing layer technology, Selective Laser Sintering involves the use of a high power laser (for example, a carbon dioxide laser) to fuse small particles of plastic powders into a mass that has a desired three-dimensional shape. The laser selectively fuses powdered material by scanning cross-sections generated from a 3-D digital description of the part (for example from a CAD file or scan data) on the surface of a powder bed. After each cross-section is scanned, the powder bed is lowered by one layer thickness, a new layer of material is applied on top, and the selective laser sintering process is repeated until the part is completed.
For engineers who are heavy users of industrial 3D printing services, we designed a subscription service to stretch your budget: 3D Printing Pro Membership.
HP Multi Jet Fusion
HP Multi Jet Fusion is a powerful 3D printing technology that produces highly accurate and durable parts at fast speeds, especially compared to other powder bed fusion technologies. Multi Jet Fusion parts are used for end-use, low-volume production, for rapid prototyping, or as a bridge process to injection molding. Get a feel for how your parts will perform with minimal upfront costs.
Xometry's HP Multi Jet Fusion 3D Printing service has a recommended build envelope of 15” x 11” x 15”.
Fused Deposition Modeling (FDM) is a 3D printing technology widely known for its speed, accuracy, and competitive cost. An FDM machine precisely extrudes melted plastic filament to create a part. Parts are very rigid, especially compared to Selective Laser Sintering (SLS), and can be lightweighted through multiple infill options.
Xometry's Fused Deposition Modeling 3D printing service offers large build volumes up to 24″ x 36″ x 36″, a variety of colors, and a diverse selection of production-grade thermoplastics — from ABS / ASA to Polycarbonate to Ultem. Our FDM prices are competitive and our lead times are often as fast as one day.
For engineers who are heavy users of industrial 3D printing services, we designed a subscription service to stretch your budget. Learn more at 3D Printing Pro Membership.
Carbon DLS™ Technology
Carbon® uses digital light projection, oxygen permeable optics, and programmable liquid resins to produce products with end-use durability, resolution and surface finish. This technology, along with Carbon’s custom liquid resins, unlocks new business opportunities and product designs previously impossible, including mass customization and on-demand inventory. The Carbon platform enables companies to bring products to market that were never thought possible.
Direct Metal Laser Sintering (DMLS) Metal 3D Printing
Direct Metal Laser Sintering (DMLS) is a metal 3D printing technology that builds prototype and production metal parts from a CAD file using a laser to selectively fuse a fine metal powder in either stainless steel or aluminum materials. A DMLS machine is capable of producing highly complex features and all-in-one assemblies using metal materials that would be difficult to achieve with subtractive manufacturing techniques. DMLS is often used as a substitution for aluminum or steel metal casting.
Our Direct Metal Laser Sintering metal 3D printing service typically offers build volumes up to 250 x 250 x 325 mm, but we may be able to accommodate larger part volumes upon request in the quote (See our Manufacturing Standards for more details). Find out the cost of the parts you need using Direct Metal Laser Sintering or compare the costs of DMLS vs. SLS. Get a free instant quote today.
PolyJet 3D Printing Technology
PolyJet 3D is a 3D printing technology known for its customizable material properties and excellent surface finish. It works by jetting UV curable resin onto a build tray in a process that is somewhat similar to inkjet printing. PolyJet 3D printing offers one of the most advanced industrial 3D printing solutions available, producing parts with incredible precision and speed. It also supports the ability to print in multiple materials at once and can simulate rubber materials and overmolds.
Urethane Casting
Urethane casting provides end-use, rigid or flexible plastic parts with production-level quality. Built without expensive and time-consuming hard tooling, our urethane casting process uses a 3D printed master pattern and silicone molds to deliver high-quality, short-run parts up to 30” long. The finished dimensions of urethane cast parts depend on the accuracy of the master model, part geometry and casting material. In general, a shrinkage rate of + 0.15% is expected.
