Custom Manufacturing On Demand
The platform for everyone from startups to global enterprises
Loading...
Video Thumbnail
ISO 9001:2015
ISO13485:2016
AS9100D
IATF 16949:2016
ITAR
CMMC Level 2
JCP
Xometry Instant Quoting Engine® is covered by U.S. Patent Numbers 11,086,292,11,347,201, 11,693,388, 11,698,623, 12,099,341, and 12,189,361. Other patents pending.
Xometry values your file privacy and security. Learn more.
0+
Buyers
0+
Suppliers
0.0/5
Trustpilot Score
0M+
Parts Shipped
CNC Machining
  • Virtually any metal or plastic material, expertly finished your way
  • Scalable capacity from one-offs and prototypes to production
Learn More
3D Printing
Instantly Prototype and Scale with Agility
Innovate and iterate quickly with 8 unique additive manufacturing processes to get functional parts faster and bypass traditional tooling.
  • Access over 100 materials, including nylon, ABS, TPU, and stainless steel
  • Zero minimums and parts produced in as little as one day
  • Includes: SLS, HP MJF, FDM, SLA, DMLS, and more
Sheet & Tube Fabrication
Complex Assemblies, Simplified Through One-Source Control
Durable, precise components are brought to life through cutting, bending, and assembling sheet metal and custom tubes.
  • Tight tolerances (sub ±0.005′′) on functional, durable parts
  • One source for cutting, bending, welding, and assembly
  • Extensive finishes that safeguard parts for long-term use
  • Includes: laser/waterjet/plasma cutting, tube and sheet bending/cutting, welding, assembly, and more
Injection Molding
Flexible Tooling Options for Every Stage of Production
This industry-leading process delivers high-volume parts with precise, repeatable performance and consistent quality you can rely on for demanding end-use applications.
  • Support for any moldable resin with SPI, VDI, and MoldTec finishing options
  • Full range of tooling solutions, from quick-turn to production-grade
  • Expert DFM and dedicated program management support included
  • Includes: plastic molding, insert and overmolding, compression molding, and more
High-Volume Metal Production
Dependable Large-Scale Metal Part Production Solutions
This category includes specialized tooled processes like die casting, metal stamping, and metal extrusion for creating high-strength metal components at scale.
  • Unlock capacity by producing parts in the millions
  • Multiple high-volume metal processes sourced on one platform
  • Reliable production for high-strength and industrial-grade metal components
  • Includes: metal stamping, metal extrusion, and die casting
Prototyping
Turn Ideas Into Reality – Fast
Accelerate product development from napkin sketch to final part with speed and confidence.
  • Instant Answers: Get quotes and feedback in clicks, not days, to maintain momentum.
  • No Minimums: Prototype one part or ten; eliminate the blockages that kill big ideas.
  • 48-Hour Prototypes: Access lead times as fast as one business day to quickly validate your designs.
  • Trusted Quality: Vetted suppliers and quality systems provide a stable environment for design iteration.
Production
Grow with Confidence
Move seamlessly from prototype to production with a predictable, globally accessible supply chain partner.
  • Massive Network: Access thousands of vetted suppliers and instant production capacity.
  • Certified & Traceable: We are the manufacturer of record and stand behind the outcome, de-risking your operation.
  • Dependable Manufacturing: Redundancy and controls keep your orders on schedule.
  • Every Way to Build: Access CNC machining, 3D printing, molding, and more under a single quote flow.
Scalable Manufacturing
Seamlessly Expand Capacity
From prototypes to high-volume production runs, navigate your product development and changing volume needs with agile solutions that keep your project moving.
  • Integrated Digital Workflow: Leverage Teamspace, a collaboration tool for shared sourcing visibility, and integrate with your ERP for a fluid process.
  • Project Management: Built-in tools give real-time visibility and simplify supply chain oversight, cutting admin work.
  • Scale Without Overhead: Expand capacity instantly without new bureaucracy or chasing multiple vendors.
  • Trusted, Certified Quality: Vetted, ISO-certified partners ensure the quality control you need for high-volume runs.
Supply Chain Management
Sourcing with Assurance
Transform sourcing from a risk-filled daily hurdle into a reliable, streamlined process that protects your reputation.
  • De-Risk Your Supply Chain: We provide certified quality and traceability, mitigating supplier risk across your entire operation.
  • Single Source of Truth: Centralize files, quotes, and suppliers in one place, eliminating scattered spreadsheets.
  • Manufacturing Accountability: Every part is certified, traceable, and backed by Xometry.
  • Frictionless Workflow: Integrate directly into your procurement system to move builds forward without extra steps.
Makers & Creators
Grow From Workshop to Worldwide
Get the speed, support, and accessible pricing you need to turn your dream project into reality, no matter the size.
  • Keep Ideas Moving: We clear the path, remove the headaches, and smooth the journey from sketch to part.
  • Easy and Accessible: Think of us as your reliable team extension, providing relief and confidence when the pressure is on.
  • No Minimums, No Limits: Zero minimum orders, competitive pricing, and instant feedback.
