Ethylene Propylene Diene Monomer (EPDM): Properties and Density
Ethylene Propylene Diene Monomer (EPDM) is a synthetic rubber and synthetic polymer produced through the copolymerization of ethylene, propylene, and a diene monomer (ethylidene norbornene, dicyclopentadiene, or 1,4-hexadiene). EPDM ethylene content ranges from 45% to 75% by weight, directly influencing crystallinity, low-temperature flexibility, and mechanical strength. The diene component occupies from 2.5% to 12% by weight, providing unsaturated sites for sulfur vulcanization. EPDM density ranges from 0.86 g/cm³ to 0.87 g/cm³, ranking it among the lightest synthetic elastomers in industrial use.
Ethylene Propylene Diene Monomer holds industrial significance across automotive, construction, electrical, and roofing sectors due to its exceptional resistance to heat, ozone, UV radiation, and weathering. EPDM retains elastic properties across temperatures from -50°C to 150°C, achieving tensile strength from 1,500 psi to 3,000 psi after vulcanization. Global EPDM production exceeded 1.3 million metric tons annually by 2020, with production costs ranging from [$1.50 to $3.50] per kilogram. The material achieves service life from 20 to 40 years across outdoor roofing membranes and automotive sealing systems.
What Is Ethylene Propylene Diene Monomer (EPDM)?
Ethylene Propylene Diene Monomer (EPDM) is a synthetic rubber formed through the copolymerization of three monomers: ethylene, propylene, and a diene component, producing a saturated polymer backbone with pendant unsaturation sites for vulcanization. Ethylene contributes from 45% to 75% by weight, with content above 55% forming rigid crystalline segments. Propylene disrupts crystalline regularity, improving low-temperature flexibility down to -50°C and processability across extrusion and injection molding systems. The diene monomer (ethylidene norbornene, dicyclopentadiene) occupies from 2.5% to 12% by weight, providing crosslinking sites for sulfur and peroxide cure systems.
EPDM raw polymer density ranges from 0.86 g/cm³ to 0.87 g/cm³, though commercial components exhibit higher densities due to compounding fillers and additives. The saturated polymer backbone resists ozone, UV radiation, and weathering without surface cracking across service temperatures from -50°C to 150°C. Global EPDM production exceeded 1.3 million metric tons annually by 2020, with production costs from [$1.50 to $3.50] per kilogram. The material achieves a service life of 20 to 40 years, making EPDM a reliable elastomer across outdoor and high-temperature industrial sealing systems.
How Is EPDM Classified As a Synthetic Rubber?
Ethylene Propylene Diene Monomer (EPDM) is classified as a synthetic rubber through its production via coordination polymerization of ethylene, propylene, and diene monomers using Ziegler-Natta or metallocene catalysts. EPDM belongs to the M-class rubber category under ASTM D1418, defined by a saturated polymer backbone with diene unsaturation confined to pendant side chains. The saturated backbone differentiates EPDM from unsaturated synthetic rubbers (styrene-butadiene rubber, nitrile rubber), providing superior ozone and UV resistance without antiozonant additives.
Crosslink density ranges from 1.0 × 10⁻⁴ mol/cm³ to 5.0 × 10⁻⁴ mol/cm³ after vulcanization, producing elastic recovery from 80% to 95% across repeated deformation cycles. EPDM tensile strength ranges from 1,500 psi to 3,000 psi, comparable to neoprene at 1,500 psi to 3,500 psi. The material retains flexibility across temperatures from -50°C to 150°C, positioning it among reliable Synthetic Rubbers in outdoor and high-temperature sealing applications.
What Are the Chemical Components of EPDM?
The chemical components of EPDM are listed below.
- Ethylene: Ethylene occupies from 45% to 75% by weight in the EPDM polymer chain, forming crystalline segments that determine tensile strength and hardness. Higher ethylene content increases Shore A hardness from 40 to 90 and impairs processing flow during extrusion and calendering.
- Propylene: Propylene disrupts crystalline regularity within the polymer backbone, improving low-temperature flexibility down to -50°C. Propylene content ranges from 25% to 55% by weight, balancing rigidity and elastic recovery across vulcanized compounds.
- Diene Monomer: The diene component (ethylidene norbornene, dicyclopentadiene) occupies from 2.5% to 12% by weight, providing unsaturated crosslinking sites for sulfur cure systems. Higher diene content accelerates cure rate and increases crosslink density from 1.0 × 10⁻⁴ mol/cm³ to 5.0 × 10⁻⁴ mol/cm³.
- Vulcanization Agents: Sulfur-based systems activate at temperatures from 140°C to 180°C, while peroxide systems cure at temperatures from 160°C to 200°C. Sulfur loading ranges from 1 phr to 3 phr, while peroxide loading ranges from 3 phr to 8 phr, depending on crosslink density targets.
- Processing Additives: Carbon black fillers at loading levels from 20 phr to 100 phr reinforce tensile strength from 1,500 psi to 3,000 psi across vulcanized EPDM compounds. Plasticizers (paraffinic oil, naphthenic oil) at loading levels from 20 phr to 150 phr improve processing flow and low-temperature flexibility.
What Are the Main EPDM Material Properties?
The main EPDM material properties are listed below.
- Tensile Strength: EPDM achieves tensile strength from 1,500 psi to 3,000 psi after vulcanization, depending on carbon black loading and cure system. Peroxide-cured EPDM retains higher tensile strength at elevated temperatures compared to sulfur-cured compounds.
- Hardness: EPDM Shore A hardness ranges from 30 to 90, depending on plasticizer content and carbon black loading levels from 20 phr to 100 phr. Higher carbon black concentration increases hardness while reducing elongation at break values.
- Elongation at Break: EPDM retains elongation at break from 100% to 600%, depending on vulcanization system and compound formulation. Peroxide-cured EPDM maintains elongation performance across thermal cycling from -50°C to 150°C.
- Density: EPDM raw polymer density ranges from 0.86 g/cm³ to 0.87 g/cm³, ranking it among the lightest synthetic elastomers in industrial use. Low density reduces component weight across automotive sealing and roofing membrane applications.
- Thermal Resistance: EPDM retains mechanical properties across continuous service temperatures from -50°C to 150°C, with short-term heat resistance reaching 180°C. The saturated backbone prevents thermal oxidation and surface cracking under sustained heat exposure.
- Ozone and UV Resistance: EPDM resists ozone concentrations up to 100 parts per billion (pphm) without surface cracking per ASTM D1171 standards. UV resistance maintains surface integrity across outdoor service conditions for 20 to 40 years.
- Compression Set: EPDM compression set values range from 15% to 40%, measured at 150°C for 22 hours per ASTM D395 standards. Lower compression set values confirm elastic recovery performance in dynamic sealing applications.
- Dielectric Strength: EPDM maintains dielectric strength from 400 V/mil to 500 V/mil across electrical cable insulation and high-voltage sealing applications. The material meets IEC 60502 standards for medium-voltage cable insulation systems.
What Physical Properties Does EPDM Have?
The physical properties that EPDM has are listed below.
- Compression Set: EPDM compression set values range from 15% to 40%, measured at 150°C for 22 hours per ASTM D395 standards. Lower compression set values confirm elastic recovery in dynamic sealing applications.
- Abrasion Resistance: EPDM retains abrasion resistance ratings from 100 mm³ to 250 mm³ volume loss per DIN 53516 standards. Carbon black reinforcement at loading levels from 50 phr to 100 phr improves abrasion resistance across conveyor belt and automotive weatherstrip applications.
What Mechanical Properties Make EPDM Suitable for Industrial Applications?
The mechanical properties that make EPDM suitable for industrial applications are listed below.
- Tear Resistance: EPDM achieves tear strength from 100 lb/in to 300 lb/in per ASTM D624 standards, depending on carbon black loading and cure system. Higher carbon black concentration from 50 phr to 100 phr improves tear resistance across dynamic sealing and weatherstrip applications.
- Flexural Fatigue Resistance: EPDM retains elastic recovery from 80% to 95% after 100,000 flexural fatigue cycles, depending on crosslink density from 1.0 × 10⁻⁴ mol/cm³ to 5.0 × 10⁻⁴ mol/cm³. Peroxide-cured EPDM maintains flexural performance across thermal cycling from -50°C to 150°C.
- Shear Strength: EPDM shear strength ranges from 200 psi to 800 psi, depending on hardness grade and compound formulation. Shore A hardness from 60 to 90 produces higher shear resistance across structural bonding and vibration-damping applications.
- Impact Resistance: EPDM absorbs mechanical impact across dynamic loading conditions without permanent deformation at temperatures from -50°C to 150°C. Carbon black reinforcement at loading levels from 20 phr to 100 phr improves impact energy absorption across automotive body sealing applications.
- Creep Resistance: EPDM retains dimensional stability under sustained compressive loads from 100 psi to 500 psi across service temperatures from -50°C to 120°C. Stress relaxation and compressive creep data confirm long-term dimensional stability in static sealing applications.
What Thermal Properties Des EPDM Have?
The thermal properties that EPDM has are listed below.
- Heat Resistance: EPDM retains mechanical properties at continuous service temperatures up to 150°C, with short-term heat resistance reaching 180°C. The saturated backbone prevents thermal oxidation and surface cracking under sustained heat exposure.
- Low-Temperature Flexibility: EPDM maintains elastic recovery and flexibility at temperatures down to -50°C without brittleness or permanent deformation. Propylene content from 25% to 55% by weight disrupts crystalline regularity, preserving flexibility across low-temperature service conditions.
- Thermal Aging Resistance: EPDM retains from 80% to 90% of its original tensile strength after 1,000 hours of heat aging at 150°C per ASTM D573 standards. Peroxide-cured compounds demonstrate superior thermal aging resistance compared to sulfur-cured EPDM formulations.
- Glass Transition Temperature (Tg): EPDM glass transition temperature ranges from -50°C to -60°C, depending on ethylene-to-propylene ratio and plasticizer content. Low Tg values confirm elastic behavior at subzero service temperatures across outdoor sealing applications.
- Thermal Conductivity: EPDM thermal conductivity ranges from 0.25 W/m·K to 0.40 W/m·K, depending on carbon black and filler loading levels. Carbon black addition at loading levels from 50 phr to 100 phr alters thermal properties across thermal insulation applications.
Can EPDM Withstand High Temperatures?
Yes, EPDM can withstand high temperatures. The saturated polymer backbone retains mechanical properties at continuous service temperatures up to 150°C, with short-term heat resistance reaching 180°C. Thermal degradation initiates above 200°C, causing surface cracking, tensile strength loss, and permanent deformation in vulcanized compounds. Peroxide-cured EPDM retains from 80% to 90% of original tensile strength after 1,000 hours at 150°C per ASTM D573 standards, outperforming sulfur-cured compounds at elevated temperatures. Compression set values remain from 15% to 40% after prolonged heat exposure at 150°C for 22 hours per ASTM D395 standards. Long-term heat aging at 125°C for 3,000 hours reduces elongation at break from 600% to below 200%, signaling advanced thermal degradation. EPDM roofing membranes and automotive seals maintain performance across thermal cycling from -50°C to 150°C, achieving service life from 20 to 40 years.
What Is EPDM rubber density?
EPDM rubber density ranges from 0.86 g/cm³ to 0.87 g/cm³ in unfilled base compound form, ranking it among the lightest synthetic elastomers in industrial use. Density directly influences engineering selection by determining component weight, material volume requirements, and cost per unit volume. Lower density reduces finished component weight by 15% to 25% compared to denser elastomers (neoprene at 1.23 g/cm³, nitrile rubber at 1.00 g/cm³). Engineers select EPDM in weight-sensitive applications (aerospace gaskets, automotive weatherstripping, roofing membranes) where mass reduction improves system efficiency.
Carbon black additions at loading levels from 20 phr to 100 phr increase EPDM compound density from 0.87 g/cm³ to 1.20 g/cm³. Paraffinic oil plasticizers at loading levels from 20 phr to 150 phr reduce compound density below 0.90 g/cm³, improving low-temperature flexibility. Mineral fillers (calcium carbonate, clay) at loading levels from 20 phr to 80 phr increase density from 1.10 g/cm³ to 1.40 g/cm³ across cost-reduced formulations. Foam EPDM achieves density from 0.10 g/cm³ to 0.50 g/cm³, depending on blowing agent concentration, targeting thermal insulation and lightweight sealing applications.
How Is EPDM density measured?
EPDM density is measured through water displacement per ASTM D792 and gas pycnometry per ISO 12154, determining mass-to-volume ratios of vulcanized compound samples. ASTM D792 immerses a weighed EPDM sample in water at 23°C, calculating density from buoyancy force differences at accuracies within ±0.001 g/cm³. Gas pycnometry measures volume displacement using inert gas (helium, nitrogen), achieving measurement accuracies within ±0.0005 g/cm³.
Carbon black additions from 20 phr to 100 phr increase compound density from 0.87 g/cm³ to 1.20 g/cm³, reducing elongation at break from 600% to 200%. Paraffinic oil plasticizers from 20 phr to 150 phr maintain density below 0.90 g/cm³, preserving low-temperature flexibility down to -50°C. Higher density formulations from 1.10 g/cm³ to 1.40 g/cm³ improve dimensional stability across static sealing applications, while lower density compounds from 0.86 g/cm³ to 0.90 g/cm³ reduce material costs across high-volume roofing membrane production.
Which Factors Affect EPDM Rubber Density?
The factors that affect EPDM rubber density are filler loading, plasticizer content, cure system selection, and base polymer composition. Carbon black additions from 20 phr to 100 phr increase compound density from 0.87 g/cm³ to 1.20 g/cm³, directly reducing elongation at break from 600% to 200% across reinforced formulations. Mineral fillers (calcium carbonate, clay) at loading levels from 20 phr to 80 phr increase density from 1.10 g/cm³ to 1.40 g/cm³, reducing material cost from [$1.50 to $2.50] per kilogram across cost-reduced compounds.
Paraffinic oil plasticizers from 20 phr to 150 phr maintain compound density below 0.90 g/cm³, preserving flexibility at temperatures down to -50°C. Peroxide cure systems produce lower crosslink density compounds compared to sulfur systems, reducing compression set resistance from 15% to 25%. Higher ethylene content from 60% to 75% by weight increases base polymer density, improving tensile strength from 2,000 psi to 3,000 psi at the expense of low-temperature flexibility. Foam EPDM formulations incorporating blowing agents reduce density from 0.87 g/cm³ to 0.10 g/cm³, targeting lightweight thermal insulation and sealing applications.
Do Fillers Influence the Density of EPDM Rubber?
Yes, fillers influence the density of EPDM rubber. Carbon black additions from 20 phr to 100 phr increase compound density from 0.87 g/cm³ to 1.20 g/cm³, directly affecting component weight and material cost across high-volume manufacturing applications. Mineral fillers (calcium carbonate, clay) at loading levels from 20 phr to 80 phr increase density from 1.10 g/cm³ to 1.40 g/cm³, reducing material cost from [$1.50 to $2.50] per kilogram across cost-reduced formulations. Higher filler loading reduces elongation at break from 600% to 200%, limiting flexibility in dynamic sealing applications. Silica fillers at loading levels from 20 phr to 60 phr increase density from 0.90 g/cm³ to 1.10 g/cm³, improving tear strength from 100 lb/in to 300 lb/in while increasing Shore A hardness. Filler concentration directly determines the balance between mechanical reinforcement, flexibility, durability, and production cost across EPDM compound formulations.
What Are the Common Applications of EPDM?
The common applications of EPDM are listed below.
Automotive Sealing Systems: EPDM weatherstrips, door seals, and window gaskets maintain elastic recovery across temperatures from -50°C to 150°C in vehicle cabin environments. Compression set values from 15% to 40% confirm long-term sealing integrity across 10 to 20 years of automotive service.
- Roofing Membranes: EPDM roofing membranes achieve service life from 20 to 40 years, resisting UV radiation, ozone, and thermal cycling across outdoor exposure conditions. Membrane thickness ranges from 1.0 mm to 3.0 mm, covering flat and low-slope commercial roofing systems.
- Electrical Cable Insulation: EPDM insulates medium-voltage cables operating at voltages from 5 kV to 35 kV, maintaining dielectric strength from 400 V/mil to 500 V/mil. The material meets IEC 60502 standards for medium-voltage cable insulation across industrial and utility power distribution systems.
- Hydraulic and Pneumatic Seals: EPDM seals and O-rings operate at pressures from 0 psi to 1,500 psi across hydraulic and pneumatic systems handling water, steam, and glycol-based fluids. The material resists compression set below 40% after continuous pressure cycling at temperatures up to 150°C.
- Industrial Hoses and Tubing: EPDM hoses handle hot water and steam at temperatures up to 150°C and pressures from 50 psi to 300 psi across industrial process systems. Tensile strength remains from 1,500 psi to 3,000 psi after continuous fluid exposure from 6 months to 12 months.
- Construction Weatherstripping: EPDM weatherstripping seals door and window frames in commercial and residential buildings, maintaining elastic recovery across thermal cycling from -50°C to 120°C. The material resists ozone concentrations up to 100 pphm per ASTM D1171 standards across 20 to 40 years of outdoor service.
Which Automotive Products Use EPDM?
The automotive products that use EPDM are listed below.
- Door and Window Seals: EPDM door and window seals maintain elastic recovery across temperatures from -50°C to 150°C, preventing air and water infiltration at compression loads from 5 psi to 30 psi. Compression set values remain below 40% after 10 to 20 years of continuous automotive service.
- Weatherstripping: EPDM weatherstripping seals body gaps and trunk lids, maintaining sealing integrity across thermal cycling from -50°C to 120°C. The material resists ozone concentrations up to 100 pphm per ASTM D1171 standards across vehicle service life from 10 to 15 years.
- Radiator and Coolant Hoses: EPDM coolant hoses handle engine coolant (ethylene glycol, water mixtures) at temperatures from -40°C to 150°C and pressures from 15 psi to 30 psi. Tensile strength remains from 1,500 psi to 3,000 psi after continuous fluid exposure for 5 to 10 years.
- Vibration Damping Mounts: EPDM vibration mounts absorb mechanical shock and noise across dynamic loading conditions at frequencies from 10 Hz to 1,000 Hz. Shore A hardness from 40 to 70 provides the required stiffness-to-damping ratio across engine and suspension mounting applications.
- Brake System Components: EPDM brake fluid reservoir seals and master cylinder cups resist glycol-based brake fluids (DOT 3, DOT 4) at temperatures from -40°C to 120°C. The material meets SAE J1703 and FMVSS 116 standards for automotive brake system sealing components.
"When designing outdoor or high-temperature sealing systems, engineers must separate the theoretical properties of an unfilled base elastomer from the physical realities of a highly filled industrial compound. Neglecting how carbon black loading and cure chemistry alter crosslink densities or thermodynamic limits (such as specifying solid EPDM rings for high-pressure fluid environments) introduces immediate risks of mechanical extrusion and catastrophic line blowout. True design for manufacturability demands that geometric GD&T callouts are directly matched to long-term compressive stress relaxation metrics rather than simplified raw material data sheets."
Which Industrial Products Are Made from EPDM?
The industrial products that are made from EPDM are listed below.
- Industrial Gaskets: EPDM gaskets seal flange faces and pipe joints handling water, steam, and dilute chemical solutions at temperatures up to 150°C and pressures from 0 psi to 250 psi. Compression set values remain below 40% after continuous static loading across service periods from 5 to 15 years.
- Conveyor Belts: EPDM conveyor belts handle material transport across outdoor environments exposed to UV radiation, ozone, and temperature cycling from -50°C to 120°C. Tensile strength remains from 1,500 psi to 3,000 psi after continuous mechanical loading across service periods from 3 to 10 years.
- Steam Hoses: EPDM steam hoses handle saturated steam at temperatures up to 210°C and pressures from 50 psi to 250 psi across industrial process systems. The material meets ISO 6134 and ASTM D380 standards for steam and hot fluid hose applications.
- Electrical Cable Jacketing: EPDM cable jacketing insulates medium-voltage power cables operating at voltages from 5 kV to 35 kV, maintaining dielectric strength from 400 V/mil to 500 V/mil. The material meets IEC 60502 standards across utility and industrial power distribution installations.
- Expansion Joints: EPDM expansion joints absorb thermal expansion and mechanical vibration in piping systems operating at temperatures from -50°C to 150°C and pressures from 0 psi to 300 psi. Axial movement capacity ranges from 10 mm to 50 mm, depending on joint diameter and wall thickness.
- Pond and Reservoir Liners: EPDM geomembranes line ponds, reservoirs, and containment basins at thicknesses from 0.75 mm to 1.5 mm, achieving water impermeability across service life from 20 to 40 years. The material resists UV radiation and ozone without surface cracking per ASTM D7465 standards.
Is EPDM Used in Weatherstripping Products?
Yes, EPDM is used in weatherstripping products across automotive and construction applications. EPDM weatherstripping maintains elastic recovery across temperatures from -50°C to 120°C, preventing air, water, and noise infiltration at compression loads from 5 psi to 30 psi. The material resists ozone concentrations up to 100 pphm per ASTM D1171 standards, preventing surface cracking across outdoor service conditions. Compression set values remain below 40% after continuous compression cycling, confirming long-term sealing integrity across service life from 10 to 20 years. Shore A hardness from 40 to 70 provides the required stiffness-to-flexibility ratio across door seals, window frames, trunk lids, and building envelope weatherstripping applications. EPDM weatherstripping meets ASTM D2000 classification standards for automotive sealing components, retaining tensile strength from 1,500 psi to 3,000 psi across thermal cycling from -50°C to 120°C.
How Is EPDM manufactured?
EPDM is manufactured through the process listed below.
- Monomer Preparation: Ethylene, propylene, and diene monomers (ethylidene norbornene, dicyclopentadiene) are purified to purity levels above 99.5% before polymerization. Ethylene and propylene feedstocks are sourced from petrochemical steam cracking units operating at temperatures from 750°C to 900°C.
- Polymerization: EPDM polymerization follows solution, suspension, or gas-phase processes using Ziegler-Natta or metallocene catalysts at reaction temperatures from 30°C to 60°C. Ethylene content from 45% to 75% by weight and diene content from 2.5% to 12% by weight are controlled through monomer feed ratios during polymerization.
- Compounding: Base EPDM resin gets combined with carbon black (20 phr to 100 phr), plasticizers (20 phr to 150 phr), vulcanization agents, and processing additives in internal mixers (Banbury mixers) at temperatures from 100°C to 160°C. Compound Mooney viscosity ranges from 20 to 100 ML(1+4) at 125°C, depending on formulation targets.
- Vulcanization: Sulfur-based systems activate at temperatures from 140°C to 180°C, while peroxide systems cure at temperatures from 160°C to 200°C. Cure time ranges from 2 minutes to 30 minutes, depending on part thickness, mold temperature, and the cure system selected.
- Processing and Forming: Unvulcanized EPDM compounds are processed through extrusion, injection molding, compression molding, and calendering systems. Extrusion produces continuous profiles (seals, tubing, weatherstripping) at output rates from 50 kg/hr to 500 kg/hr, while injection molding produces discrete components at cycle times from 30 seconds to 5 minutes.
- Quality Testing: Finished EPDM compounds undergo tensile strength testing per ASTM D412, compression set testing per ASTM D395, and ozone resistance testing per ASTM D1171. Density verification follows ASTM D792 at measurement accuracies within ±0.001 g/cm³ across production batches.
How Does the Polymerization Process Produce EPDM?
Ethylene Propylene Diene Monomer (EPDM) polymerization produces the base elastomer through coordination insertion of ethylene, propylene, and diene monomers into growing polymer chains using Ziegler-Natta or metallocene catalysts. Ziegler-Natta catalysts (titanium tetrachloride, vanadium oxytrichloride) activate at reaction temperatures from 30°C to 60°C, controlling molecular weight distribution from 50,000 g/mol to 500,000 g/mol. Monomer feed ratios control ethylene content from 45% to 75% and diene content from 2.5% to 12% by weight during polymerization.
Solution polymerization dissolves monomers in hexane solvent at pressures from 5 bar to 20 bar, accounting for 70% of global EPDM production. Diene monomer incorporation creates pendant unsaturation sites along the saturated backbone, providing crosslinking positions for sulfur and peroxide cure systems. Finished EPDM resin achieves Mooney viscosity from 20 to 100 ML(1+4) at 125°C, determining processability across extrusion and injection molding systems.
How Does Vulcanization Improve EPDM Properties?
Vulcanization improves EPDM properties by forming covalent crosslinks from 1.0 × 10⁻⁴ mol/cm³ to 5.0 × 10⁻⁴ mol/cm³ across polymer chains, converting uncured gum stock into a dimensionally stable elastomer. Sulfur cure systems activate at 140°C to 180°C, forming polysulfidic crosslinks that improve flexibility and dynamic fatigue resistance. Peroxide cure systems cure at 160°C to 200°C, producing carbon-carbon crosslinks that improve heat resistance and lower compression set from 15% to 25%.
Vulcanized EPDM achieves tensile strength from 1,500 psi to 3,000 psi, compared to uncured EPDM below 300 psi without crosslink network formation. Elongation at break improves from below 100% in uncured stock to 600% after full vulcanization, confirming elastic network development. Uncured EPDM exhibits permanent deformation under load, while vulcanized compounds recover from 80% to 95% of original dimensions after compression cycling at temperatures from -50°C to 150°C.
Does Vulcanization Improve EPDM Aging Resistance?
Yes, vulcanization improves EPDM aging resistance. Peroxide-cured EPDM retains from 80% to 90% of original tensile strength after 1,000 hours of heat aging at 150°C per ASTM D573 standards, outperforming uncured compounds that degrade above 100°C. Carbon-carbon crosslinks formed during peroxide vulcanization resist thermal scission, preventing chain breakage and surface cracking across long-term heat exposure. Vulcanized EPDM resists ozone concentrations up to 100 pphm per ASTM D1171 standards, compared to uncured EPDM surface cracking below 25 pphm exposure. Compression set values remain from 15% to 40% after 1,000 hours of thermal aging at 125°C, confirming elastic recovery retention across extended service periods. Vulcanized EPDM achieves service life from 20 to 40 years across outdoor roofing and automotive sealing applications.
What Are the Advantages of EPDM Over Natural Rubber?
Ethylene Propylene Diene Monomer (EPDM) outperforms natural rubber across weather resistance, ozone resistance, thermal stability, and long-term durability in outdoor and high-temperature industrial applications. EPDM resists ozone concentrations up to 100 pphm per ASTM D1171 standards, while natural rubber degrades at concentrations above 25 pphm without antiozonant additives. EPDM retains elastic properties across temperatures from -50°C to 150°C, exceeding natural rubber performance limits of -40°C to 80°C. Weather resistance eliminates protective surface treatments, reducing maintenance costs by 20% to 35% across roofing and automotive sealing applications.
EPDM compression set values remain from 15% to 40% after 1,000 hours at 125°C, compared to natural rubber, which experiences complete thermal breakdown under equivalent conditions.. Peroxide-cured EPDM retains from 80% to 90% of original tensile strength after 1,000 hours at 150°C per ASTM D573 standards, while natural rubber loses above 50% of tensile strength above 100°C. Production costs from [$1.50 to $3.50] per kilogram are justified by service life from 20 to 40 years, reducing long-term replacement expenditure across engineering material selection, favoring EPDM over Natural Rubber alternatives.
What Are the Limitations of EPDM?
The limitations of EPDM are listed below.
- Poor Oil and Fuel Resistance: EPDM swells and degrades when exposed to petroleum-based oils, fuels, and hydrocarbon solvents, limiting use in automotive fuel systems and oil-contact sealing applications. Volume swell exceeds 100% after 70 hours of immersion in ASTM Oil No. 3 at 100°C per ASTM D471 standards.
- Difficult Bonding: EPDM non-polar surface chemistry resists adhesion to metals, plastics, and other substrates without primer treatment. Peel strength without primer remains below 5 psi, requiring specialized bonding primers and adhesives to achieve peel strength from 10 psi to 50 psi.
- Limited High-Temperature Performance: EPDM mechanical properties degrade above 150°C during continuous service, restricting use in high-temperature sealing applications above 180°C. Tensile strength drops below 500 psi after prolonged exposure at temperatures exceeding 175°C.
- High Compound Cost at Low Volumes: EPDM compounding requires carbon black (20 phr to 100 phr) and plasticizer additions (20 phr to 150 phr), increasing formulation costs from [$2.00 to $5.00] per kilogram at low production volumes. Cost reduction requires high-volume production runs exceeding 10,000 kg per batch.
- Poor Resistance to Aromatic Solvents: EPDM swells and loses dimensional stability when exposed to aromatic solvents (toluene, xylene) at concentrations above 10% by volume. Volume swell reaches 200% to 400% after 24 hours of aromatic solvent immersion at 23°C.
Which Environments Are Unsuitable for EPDM?
The environments that are unsuitable for EPDM are listed below.
- Petroleum Oil and Fuel Environments: EPDM volume swell exceeds 100% after 70 hours of immersion in ASTM Oil No. 3 at 100°C per ASTM D471 standards. Petroleum-based fluid contact causes permanent dimensional distortion and tensile strength loss below 500 psi in sealing components.
- Aromatic Solvent Environments: EPDM volume swell reaches 200% to 400% after 24 hours of exposure to aromatic solvents (toluene, xylene) at concentrations above 10% by volume. Dimensional instability prevents reliable sealing performance in chemical processing environments handling aromatic compounds.
- Concentrated Acid Environments: EPDM degrades when exposed to concentrated sulfuric acid (above 70% concentration) and concentrated nitric acid at temperatures above 60°C. Tensile strength drops below 500 psi after continuous acid exposure from 30 days to 90 days.
- High-Temperature Steam Environments: Specialty peroxide-cured EPDM mechanical properties degrade above 210°C under continuous saturated steam exposure, limiting use in high-pressure steam systems above 250 psi. Compression set values exceed 60% after 500 hours of steam exposure at 160°C.
- Halogenated Solvent Environments: EPDM swells and loses elastic recovery when exposed to halogenated solvents (methylene chloride, trichloroethylene) at concentrations above 5% by volume. Volume swell reaches 150% to 300% after 48 hours of halogenated solvent immersion at 23°C.
Is EPDM Incompatible With Hydrocarbon Solvents?
Yes, EPDM is incompatible with hydrocarbon solvents. The non-polar saturated backbone of EPDM absorbs hydrocarbon solvents through diffusion, causing volume swell from 100% to 400% depending on solvent type and concentration. Aromatic solvents (toluene, xylene) cause volume swell from 200% to 400% after 24 hours of immersion at 23°C, exceeding acceptable dimensional limits for sealing applications. Aliphatic hydrocarbon solvents (hexane, heptane) produce volume swell from 50% to 150% after 70 hours of immersion at 23°C per ASTM D471 standards. Petroleum-based oils cause tensile strength loss below 500 psi after continuous exposure at 100°C, preventing reliable sealing performance in fuel and oil contact environments. Halogenated solvents (methylene chloride, trichloroethylene) produce volume swell from 150% to 300% after 48 hours of immersion at 23°C. Alternative elastomers (nitrile rubber, fluorocarbon rubber) demonstrate volume swell below 10% in equivalent hydrocarbon solvent exposure conditions.
How Does EPDM Compare With Other Types of Synthetic Rubber?
Ethylene Propylene Diene Monomer (EPDM) differs from other Types of Synthetic Rubber across heat resistance, chemical resistance, density, and outdoor durability. EPDM raw base density from 0.86 g/cm³ to 0.87 g/cm³ ranks as the lightest among raw NBR, SBR, silicone rubber, and neoprene. Outdoor durability from 20 to 40 years positions EPDM above SBR and NBR, which require protective coatings after 5 to 10 years of outdoor exposure. Heat resistance up to 150°C exceeds SBR limits of 100°C and NBR limits of 120°C, confirming EPDM reliability across high-temperature sealing applications.
The comparison between EPDM and other types of synthetic rubber is shown in the table below.
Which Types of Synthetic Rubber Are Most Resistant to Weather?
The types of synthetic rubber that are most resistant to weather are listed below.
- Ethylene Propylene Diene Monomer (EPDM): EPDM resists ozone concentrations up to 100 pphm per ASTM D1171 standards without surface cracking, achieving outdoor service life from 20 to 40 years. The saturated polymer backbone prevents UV degradation and surface chalking across thermal cycling from -50°C to 150°C.
- Silicone Rubber: Silicone rubber maintains surface integrity across UV radiation and ozone exposure at service temperatures from -60°C to 230°C without protective coatings. The Si-O backbone resists atmospheric degradation, achieving outdoor service life from 20 to 30 years across roofing and electrical insulation applications.
- Neoprene (Polychloroprene): Neoprene resists ozone and weathering at concentrations up to 50 pphm, achieving outdoor service life from 10 to 20 years across marine and industrial sealing applications. The chlorine content of 35% by weight provides inherent flame and weather resistance without antiozonant additives.
- Hypalon (Chlorosulfonated Polyethylene): Hypalon resists UV radiation, ozone, and chemical exposure across outdoor service temperatures from -40°C to 135°C, achieving service life from 15 to 25 years. The chlorosulfonated backbone prevents surface oxidation and color fading across marine, roofing, and chemical containment applications.
- Fluorocarbon Rubber (FKM): FKM resists UV radiation, ozone, and chemical exposure at service temperatures from -20°C to 200°C, achieving outdoor service life from 15 to 30 years. Fluorine content from 65% to 70% by weight provides superior chemical and weather resistance across aerospace and industrial sealing applications.
Which Types of Synthetic Polymers Are Commonly Used in Engineering Applications?
The types of synthetic polymers that are commonly used in engineering applications are listed below.
- Polyamide (Nylon): Nylon achieves tensile strength from 8,000 psi to 12,000 psi and continuous service temperatures up to 120°C, covering gears, bearings, and structural fasteners. Moisture absorption ranges from 1.5% to 3.5% by weight, requiring dimensional tolerance compensation in precision engineering applications.
- Polycarbonate (PC): Polycarbonate achieves tensile strength up to 9,500 psi and impact strength from 12 ft·lb/in to 18 ft·lb/in, covering optical lenses, safety glazing, and electronic enclosures. The material retains dimensional stability across service temperatures from -40°C to 135°C.
- Polytetrafluoroethylene (PTFE): PTFE operates across service temperatures from -200°C to 260°C, maintaining a friction coefficient from 0.04 to 0.10 across bearing, seal, and chemical lining applications. Chemical resistance covers concentrated acids, alkalis, and solvents across a pH range from 0 to 14.
- Polyetheretherketone (PEEK): PEEK achieves tensile strength from 14,000 psi to 21,000 psi at continuous service temperatures up to 250°C, covering aerospace structural components, medical implants, and high-temperature sealing systems. The material retains mechanical properties after sterilization (autoclaving, gamma radiation) without dimensional degradation.
- Epoxy Resin: Epoxy achieves tensile strength from 5,000 psi to 10,000 psi and adhesive shear strength from 2,000 psi to 5,000 psi, covering structural adhesives, composite matrices, and electronic encapsulation systems. Cure temperatures range from 20°C to 180°C, depending on the hardener system and application requirements.
- Polyurethane (PU): Polyurethane achieves hardness ratings from Shore 20A to Shore 85D and tensile strength from 3,000 psi to 8,000 psi, covering wheels, rollers, flexible foam, and industrial coating applications. Abrasion resistance ratings from 20 mm³ to 100 mm³ volume loss per DIN 53516 standards position PU above natural rubber in wear-intensive applications.
Is Polyethylene Widely Used in Engineering Applications?
Yes, Polyethylene (PE) is widely used in engineering applications. High-density polyethylene (HDPE) achieves tensile strength from 3,000 psi to 5,000 psi and operates at continuous service temperatures up to 60°C, covering pipe systems, chemical storage tanks, and structural liners. HDPE density ranges from 0.94 g/cm³ to 0.97 g/cm³, providing dimensional stability across pressure ratings from 50 psi to 200 psi in fluid distribution systems. Ultra-high molecular weight polyethylene (UHMWPE) achieves abrasion resistance ratings below 20 mm³ volume loss per DIN 53516 standards, covering conveyor liners, bearing pads, and wear plates. Low-density polyethylene (LDPE) achieves dielectric strength from 400 V/mil to 500 V/mil, covering electrical cable insulation and film applications at thicknesses from 0.05 mm to 2.0 mm. Polyethylene (PE) meets ASTM D3350 standards for pressure-rated piping applications, achieving service life from 50 to 100 years across water distribution and gas pipeline systems.
