ResourcesMachining DesignDFM Tips: A Quick Look at Designing Parts That Are Easy to CNC Machine
Aaron Lichtig
Published October 9, 2020
Updated June 3, 2025
While an entire book could be written on the subject of designing parts for CNC machining, we have a few tips that should at least help you get started.
parts and drawings on a table
There are dozens of good reasons to design your parts so they’re easy to machine. Besides the fact that CNC machining is one of the most sought after manufacturing processes Xometry offers, a part design that’s ready to be machined will also cost you a whole lot less than one that isn’t or one that is just less ready.
At Xometry, we call a part that’s been designed so it’s easy to be machined ‘DFM ready’. Design for Manufacturability (DFM) is a philosophy of part design that reduces errors in machining, reduces part cost and ensures parts are produced timely and efficiently. In short, it’s a way of designing that enables engineers to always get the part they’re after for the lowest price possible.
While an entire book could be written on the subject, we have a few tips that should at least help you get started.
Clear 2D
A DFM ready part starts with a clear 2D three-view drawing. What makes it clear? It needs to provide all the details and information your average machinist would need to make the part, including:
  • Material type
  • Tolerance range
  • Surface finish requirements
  • Plain and tapped hole sizes
  • Clear dimensions
Sometimes, designs are particularly complicated and require more detail. If your part fits that bill, be sure to tell all. Extra tight tolerances, specific features — whatever it is, note it and explain it. It’s better to overstate than pay for a batch of parts that look just like the design you provided but nothing like the design in your head.
Crystal Clear
Clear dimensions don’t happen by accident. All features of the part should be measured from a common point to guarantee every one of its critical features is properly placed. When a 3D part file’s measurements haven’t been taken from a common point — e.g. one feature is measured from the left top corner and another is measured from the right — tolerance “build-up” can occur so that the parts that make up your overall assembly no longer fit together.
Designing parts that are easy to machine saves time, money and increases the likelihood your parts will be delivered to you at quality.
Be Reasonable With Tolerances
Super-tight tolerances exist for a reason, but engineers often dictate a tighter tolerance than is necessary given a particular part’s application. It’s important to be as loose as you can and still get the part you need. Most materials and most machines can achieve a reliable general tolerance of .005”. Anything tighter is going to start increasing the price of a part almost exponentially. So if you don’t need it tighter, don’t ask for it. You’ll save yourself time and money and increase the likelihood that your parts will be delivered to you at quality.
Xometry tolerances
Xometry tolerances
Go Stock With Materials
Whenever possible, design parts to use stock material sizes. Not only will doing so reduce how much material is wasted, but stock material sizes also decrease the amount of machining time required to make a part since bulk removal won’t be necessary. An added bonus? Anything about a CNC machined part design that can reduce waste and save time will also save you money.
The Iceberg
DFM is a world unto itself, and these tips are just the beginning. You can check out our in-depth CNC machining design guideherefor more recommendations on optimizing your designs, reducing machining time, and lowering your costs.
William Krueger
Read more articles by William Krueger
