ResourcesMaterialsMeet Your Materials: Formlabs SLA Resins
picture of Greg Paulsen
 2 min read
Published May 15, 2025
Formlabs SLA resins offer high-resolution 3D printing with diverse material properties. Xometry provides instant online quotes for these materials, ensuring you find the perfect resin for your project needs.
New Formlabs Materials
We are proud to offer Formlabs SLA resins on Xometry’s Instant Quoting Engine®. Formlabs is a key innovator in stereolithography (SLA) 3D printing, offering a versatile portfolio of low-cost engineered materials with professional results, meeting various engineering and design needs. From general prototyping to demanding functional applications, their materials empower users to create high-resolution parts with specific mechanical, thermal, and visual properties.
These materials run on the Form 4 and 4L platforms to achieve consistent and repeatable results. This guide provides a concise overview of eight key Formlabs SLA resins, highlighting their characteristics, benefits, and ideal use cases to help you select the optimal material for your next project.
Formlabs Clear Resin V5
Colorless and Cosmetic
Clear Resin V5 is a colorless material offering an optimal balance of print speed, accuracy, and high transparency.
  • Exceptional optical clarity and color neutrality
  • Produces stiff, strong parts with a smooth surface finish
  • Ideal for transparent enclosures, optical components, and lighting
  • Suitable for showcasing internal features and fluidic devices (<1% moisture absorption)
A hand holding a part printed with Formlabs Clear Resin V5.
Formlabs Tough 1500 Resin V2
Resilient and Rugged
A dark grey, resilient engineering resin that balances stiffness and compliance, offering toughness comparable to polypropylene.
  • Excellent balance of stiffness and ductility for impact resistance
  • High fracture toughness for durable parts in demanding applications (155% elongation at break)
  • Ideal for impact-resistant jigs and fixtures (Izod Notched 45 J/m)
  • Ideal for prostheses, insoles, sports goods, snap fits, and living hinges
  • Creates rugged enclosures and prototypes with snap-fits or living hinges
A snap buckle made from Formlabs 1500 V2 resin.
Formlabs ESD Resin
Static-Dissipative Protection
A dark black, rugged engineering resin for ESD-safe parts, essential for protecting sensitive electronics in manufacturing environments.
  • Static-dissipative (surface resistivity 10⁵ - 10⁸ Ω/sq); protects sensitive electronics from electrostatic discharge
  • Used for anti-static prototypes, jigs, and electronics manufacturing fixtures
  • Ideal for enclosures, housings, fixtures, and tooling
  • Creates protective housings for sensitive electronic components
Electrical probe holder made from Formlabs ESD resin.
Formlabs Grey Resin V5
General Purpose and Smooth
A versatile grey, general-purpose material delivering a strong balance of accuracy, excellent finish, and robust mechanical properties.
  • Smooth, opaque matte surface ideal for detailed presentation models
  • Good all-around mechanical properties for general prototyping needs
  • Suitable for form/fit prototypes and detailed concept models
An adjustable angle bracket made from Formlabs Grey V5 resin.
Formlabs High Temp Resin
Extreme Heat Resistance
A translucent engineering resin offering the highest heat resistance in the Formlabs portfolio, with a Heat Deflection Temperature (HDT) of 238°C @ 0.45 MPa.
  • Exceptional thermal stability (HDT 238°C) for high-heat applications
  • Produces detailed, precise parts that maintain integrity at high temperatures
  • Ideal for hot air, gas, and fluid flow components
  • Suitable for heat-resistant mounts, housings, fixtures, molds, and inserts
A fluid mixing nozzle made from Formlabs High Temperature resin.
Formlabs Rigid 10K Resin
Ultra-Stiff and Strong
An off-white, highly glass-filled material, representing the stiffest material in Formlabs' engineering portfolio, ideal for industrial parts requiring high rigidity and resistance to significant loads without bending.
  • Extremely high stiffness (~10 GPa) for minimal deflection under load
  • Offers high heat and chemical resistance with a smooth matte finish
  • Suitable for short-run injection molds, press tooling, and inserts
  • Used for demanding industrial components and aerodynamic test models
A thermoforming mold made from Formlabs Rigid 10K resin.
Formlabs Tough 2000 Resin
Strong and Sturdy
The strongest and stiffest grey material within Formlabs' Tough and Durable family, engineered for rugged prototyping of parts that must resist bending.
  • Offers ABS-like strength and stiffness characteristics
  • Produces strong, sturdy parts that maintain their form under stress
  • Ideal for strong, stiff functional prototypes that resist deformation
  • Suitable for sturdy jigs and fixtures needing high rigidity and durability
A pump housing made from Formlabs Tough 2000 resin.
Formlabs White Resin V5
Bright and Clean
A bright white general-purpose material that blends high accuracy, a smooth matte finish, and solid mechanical properties.
  • Bright white, opaque, smooth matte surface for aesthetics or painting
  • Good all-around properties for general prototyping applications
  • Suitable for form/fit prototypes and detailed presentation models
  • Used for medical or anatomical models and jigs/fixtures needing a clean white look
An architectural model made from Formlabs White V5 resin.
Making Your Formlabs SLA Selection
Choosing the correct Formlabs SLA resin is critical for achieving optimal results for your specific project. Consider the primary functional requirements: Is optical clarity essential (Clear Resin V5)? Do you need parts that can withstand impacts (Tough 1500 or 2000 Resin)? Are you creating components that demand extreme stiffness (Rigid 10K Resin) or must perform under high temperatures (High Temp Resin)? ESD Resin provides a targeted solution for specialized needs, such as static dissipation in electronics applications. Grey or White Resin V5 offers excellent surface finishes and well-balanced properties for general visual models and initial prototypes.
These Formlabs Resins complement Xometry’s extensive photopolymer offerings. To check out Xometry’s resins, download datasheets, or our design guides, go to our Stereolithography (SLA) Capabilities page.
Want to see how all Xometry’s SLA materials stack up? Check out our guide to navigating stereolithography resins by application.
