Material Selection Gallery
CNC machined part made by Xometry.
CNC Metal Materials
Aluminum, stainless, steels, titanium alloys, and more.
CNC Black Acetal Delrin Part
CNC Plastic Materials
Acetal, ABS, nylon, HDPE, PP, PEEK, PTFE, and more.
Garolite G-10 CNC Machined Composite
CNC Composite Materials
Garolite, and more.
Various aluminum sheet cut parts made by Xometry.
Sheet Metal Materials
Aluminum, stainless, steel, and copper alloys.
A stainless steel part printed with Xometrys DMLS service.
3D Printed Metals
Aluminum, stainless steel alloys, metal composites, and more.
3D printed polypanels made of PLA.
3D Printed Plastics
Engineering plastics like ABS, Nylon, ULTEM, PC, and photopolymers.
3D Printed Resins
Carbon DLS, SLA and PolyJet resins
Teal transparent cast urethane part made by Xometry.
Cast Urethane Materials
Rigid, rubbery, flame retardent, and more durable urethanes.
A blue plastic cap injection molded by Xometry.
Injection Molded Plastics
Commodity plastics like ABS, PC-ABS, PBT, PC, Acrylic, as well as high performing PEEK and more.
Sheet Cut Foam Materials
EVA Foam, Extra Soft PU, Flame Retardant Foams, and more
Sheet Cut Wood Materials
Hardwoods, Masonite, Plywood, and more
Rubber gasket sheets.
Sheet Cut Rubber Materials
Buna-N Rubber Blends, EPDM, Silicone Rubber, Paper Fiber, PTFE
Carbon fiber sheet cut parts.
Sheet Cut Composite Materials
Carbon Fiber and Garolite
The front of a binder jet printed Xometry tile printed in 316L stainless steel.
Metal Binder Jetting Materials
Alloys and X1 Metals
Custom Materials
Not seeing what you are looking for? We can source it! Submit your quote request using "Other" in the material drop-down, write in your request, and our expert team will be happy to review the project!
CNC Machined Metals
A CNC machined aluminum part made by Xometry.
Black Plastic CNC Machined Part
Bent sheet metal bracket made of galvanized steel.
3D Printed Metals
DMLS / DMLM Metal 3D Printing
Binder Jet Metal 3D Printing
    MJF Materials
    Urethane Casting Materials
    Rigid Polyurethane (Black, Natural, Color-Match)
    • ABS-like, FR
    • General Purpose Shore 78D
    • Glass-Filled Nylon-like Shore 85D
    • Polypropylene-like Shore D65-D75
    • Polycarbonate-like Shore 84D
    Rigid Clear Polyurethane (Colorless)
    • Rigid Clear Shore D 80
    Rubber-like Polyurethane (Black, Natural, Color-Match)
    • Rubber-like Shore A 25-35, ranging to Shore A 85-95
    Clear Rubber-like Polyurethane (Colorless)
    • Clear Rubber-like Shore A 40-50, ranging to Shore A 85-95
    Cast Silicone Materials
    • Shore A 10 (TC-5005 or equiv.), ranging to Shore A 50-60 (Smooth‑Sil™ 960 or equiv.)
    Learn more on our urethane and silicone casting page.
      Injection Molding Plastics and Elastomers
      Rigid plastic materials
      • ABS (acrylonitrile butadiene styrene)
      • ASA (acrylonitrile styrene acrylate)
      • CA (cellulose acetate)
      • HDPE (high-density polyethylene)
      • LCP (liquid crystal polymer)
      • LDPE (low-density polyethylene)
      • PA 6 (polyamide 6, nylon 6)
      • PA 6/6 (polyamide 6/6, nylon 6/6)
      • PARA (polyarylamide)
      • PBT (polybutylene terephthalate, Valox)
      • PBT-PET (polybutylene terephthalate-polyethylene terephthalate)
      • PC (polycarbonate)
      • PC-ABS (polycarbonate-acrylonitrile butadiene styrene)
      • PC-PBT (polycarbonate-polybutylene terephthalate, Xenoy)
      • PC-PET (polycarbonate-polyethylene terephthalate)
      • PCT (polycyclohexylenedimethylene terephthalate)
      • PE (polyethylene
      • PEEK (polyether ether ketone)
      • PEI (polyetherimide, Ultem)
      • PE-PP (polyethylene-polypropylene)
      • PE-PS (polyethylene-polystyrene)
      • PES (polyethersulfone)
      • PET (polyethylene terephthalate, Rynite)
      • PLA (polylactic acid)
      • PMMA (polymethyl methacrylate, acrylic)
      • POM (acetal polyoxymethylene, Delrin)
      • PP (polypropylene)
      • PPA (polyphthalamide)
      • PPS (polyphenylene sulfide, Ryton)
      • PS (polystyrene)
      • PS-PPE (polystyrene-polyphenyl ethers, Noryl)
      • PSU (polysulfone, Udel)
      • PVC (polyvinyl chloride (Shore D)
      • PVDF (polyvinylidene fluoride, Kynar)
      • SAN (styrene acrylonitrile)
      • TPO (thermoplastic polyolefin)
      • TPU (thermoplastic polyurethane (Shore D))
      Elastomer/Rubber molded materials
      • EPDM (ethylene propylene diene monomer rubber (Viton))
      • PEBA (polyether block amide)
      • PVC (polyvinyl chloride (Shore A))
      • TPE (thermoplastic elastomer)
      • TPU (thermoplastic polyurethane (Shore A))
      • TPV (thermoplastics elastomer, vulcanized rubber (Santoprene))
      • LSR (liquid silicone rubber)
      See more details on injection molding materials.
        Black plastic part injection molded by Xometry.
        • EVA Foam, Black
        • EVA Foam, Blue
          Blue EVA sheet cut parts.
          • Cherry Hardwood
          • Hardboard (Masonite)
          • MDF
          • Poplar Hardwood
          • Red Oak Hardwood
          • Uncoated Wood Laminate (Plywood), Birch
            • Buna-N Rubber, Adhesive-Backed, Black
            • Buna-N Rubber, Black
            • Cork and Buna-N Blend, Brown
            • EPDM
            • High Temp Silicone Rubber, Adhesive-Backed, Red
            • High Temp Silicone Rubber, Red
            • Paper Fiber and Buna-N Blend, Gray
            • PTFE Gasket Material
            • Carbon Fiber
            • Garolite G-10 (FR4), Black
            • Garolite G-11 (FR5), Green
            • Garolite LE (Phenolic), Brown
