Full-Service Injection Molding
Validate and scale your design with confidence
ISO 9001:2015
ISO 13485:2016
AS9100D
IATF 16949:2016
ITAR
CMMC Level 2
JCP
Xometry Instant Quoting Engine® is covered by U.S. Patent Numbers 11,086,292,11,347,201, 11,693,388, 11,698,623, 12,099,341, and 12,189,361. Other patents pending.
Xometry values your file privacy and security. Learn more.
Your Design. Our Expertise.
Instant Quote
We offer instant quotes with competitive pricing and lead times for both domestic and international production.
DFM Feedback
Our experts conduct a comprehensive DFM review to flag issues and reduce risk.
Guaranteed Precision
Tool validation, T1 samples, and rigorous quality checks ensure your precision parts are made to spec.
Expert Support
A dedicated case manager and our engineers work with you from the first conversation to the final delivery.
Any Moldable Material
Industry-Standard Finishes
Real Stories, Real Impact
Get More Capacity With Our Global Network
Production Molding
Produce up to 1M+ parts at scale. Our tooling strategies allow a seamless transition from prototype or bridge tooling into early and serial production, even if you switch suppliers.
Medical Injection Molding
Access capabilities like FDA Class I and II devices and ISO Class 7 & 8 clean room environments. We support precision molding for part sizes ranging from micro to 300 square inches.
Automotive Injection Molding
Get superior quality for your automotive molding, backed by IATF 16949 certification and support for APQP and PPAP. Unlike traditional suppliers, we can pivot quickly when parts or requirements change.
Compression Molding
Produce high-strength parts at scale with this cost-effective process. We offer a variety of rubber elastomers for compression molding, including silicone and NBR.
Overmolding Part
Overmolding
Fuse materials for better grip and durability. We support complex overmolded projects, including those with side actions or hand-loaded inserts.
Insert molding part
Insert Molding
Eliminate assembly after production and produce high-strength parts with this one-shot process that adds metal inserts to your plastic components.
Prototyping
Turn Ideas Into Reality – Fast
Accelerate product development from napkin sketch to final part with speed and confidence.
  • Instant Answers: Get quotes and feedback in clicks, not days, to maintain momentum.
  • No Minimums: Prototype one part or ten; eliminate the blockages that kill big ideas.
  • 48-Hour Prototypes: Access lead times as fast as one business day to quickly validate your designs.
  • Trusted Quality: Vetted suppliers and quality systems provide a stable environment for design iteration.
Production
Grow with Confidence
Move seamlessly from prototype to production with a predictable, globally accessible supply chain partner.
  • Massive Network: Access thousands of vetted suppliers and instant production capacity.
  • Certified & Traceable: We are the manufacturer of record and stand behind the outcome, de-risking your operation.
  • Dependable Manufacturing: Redundancy and controls keep your orders on schedule.
  • Every Way to Build: Access CNC machining, 3D printing, molding, and more under a single quote flow.
Scalable Manufacturing
Seamlessly Expand Capacity
From prototypes to high-volume production runs, navigate your product development and changing volume needs with agile solutions that keep your project moving.
  • Integrated Digital Workflow: Leverage Teamspace, a collaboration tool for shared sourcing visibility, and integrate with your ERP for a fluid process.
  • Project Management: Built-in tools give real-time visibility and simplify supply chain oversight, cutting admin work.
  • Scale Without Overhead: Expand capacity instantly without new bureaucracy or chasing multiple vendors.
  • Trusted, Certified Quality: Vetted, ISO-certified partners ensure the quality control you need for high-volume runs.
Supply Chain Management
Sourcing with Assurance
Transform sourcing from a risk-filled daily hurdle into a reliable, streamlined process that protects your reputation.
  • De-Risk Your Supply Chain: We provide certified quality and traceability, mitigating supplier risk across your entire operation.
  • Single Source of Truth: Centralize files, quotes, and suppliers in one place, eliminating scattered spreadsheets.
  • Manufacturing Accountability: Every part is certified, traceable, and backed by Xometry.
  • Frictionless Workflow: Integrate directly into your procurement system to move builds forward without extra steps.
CNC Machining
  • Virtually any metal or plastic material, expertly finished your way
  • Scalable capacity from one-offs and prototypes to production
3D Printing
Instantly Prototype and Scale with Agility
Innovate and iterate quickly with 8 unique additive manufacturing processes to get functional parts faster and bypass traditional tooling.
  • Access over 100 materials, including nylon, ABS, TPU, and stainless steel
  • Zero minimums and parts produced in as little as one day
  • Includes: SLS, HP MJF, FDM, SLA, DMLS, and more
Sheet & Tube Fabrication
Complex Assemblies, Simplified Through One-Source Control
Durable, precise components are brought to life through cutting, bending, and assembling sheet metal and custom tubes.
  • Tight tolerances (sub ±0.005′′) on functional, durable parts
  • One source for cutting, bending, welding, and assembly
  • Extensive finishes that safeguard parts for long-term use
  • Includes: laser/waterjet/plasma cutting, tube and sheet bending/cutting, welding, assembly, and more
Injection Molding
Flexible Tooling Options for Every Stage of Production
This industry-leading process delivers high-volume parts with precise, repeatable performance and consistent quality you can rely on for demanding end-use applications.
  • Support for any moldable resin with SPI, VDI, and MoldTec finishing options
  • Full range of tooling solutions, from quick-turn to production-grade
  • Expert DFM and dedicated program management support included
  • Includes: plastic molding, insert and overmolding, compression molding, and more
High-Volume Metal Production
Dependable Large-Scale Metal Part Production Solutions
This category includes specialized tooled processes like die casting, metal stamping, and metal extrusion for creating high-strength metal components at scale.
  • Unlock capacity by producing parts in the millions
  • Multiple high-volume metal processes sourced on one platform
  • Reliable production for high-strength and industrial-grade metal components
  • Includes: metal stamping, metal extrusion, and die casting
Chat with an expert
Phone
+1-800-983-1959
Email
hello@xometry.com
