Xometry Logo
CapabilitiesIndustriesResourcesSuppliesBecome a SupplierFind Suppliers
Sign In
Cookie Policy
Types of Plastic for CNC Machining
CNC machined plastics are widely used in every major industry from construction to automotive. Listed below are the types of plastics that Xometry offers for on-demand custom manufacturing. You can learn more about specific material properties and applications on each page.
Xometry ImageXometry Image
Machining Plastics Offered
CNC plastics can be used for a range of parts from prototypes to engineering models to end-use components. While plastics can be hard to machine, oftentimes their light weight and denseness paired with simple geometries may be more suitable to machining than 3D printing or injection molding. Many of the following materials are extremely durable with high fatigue resistance, inertness, and shock absorbance. Other plastics are general-use materials that are more easily machined and are therefore suitable for testing designs at a low cost, like ABS. Depending on the nature of your project, machined plastic may the best material for your custom parts. Explore our materials in depth below:
  • HDPE for CNC machining
  • Acetal (Delrin) for CNC machining
  • Polypropylene for CNC machining
  • UMHW-PE for CNC machining
  • Nylon 6/6 for CNC machining
  • Acrylic for CNC machining
  • ABS for CNC machining
  • Polycarbonate for CNC machining
  • PEEK for CNC machining
  • PTFE-Teflon for CNC machining
  • Garolite G-10 for CNC machining
  • PVC for CNC machining
We offer a wide range of surface finishes applicable to these plastics including:
  • Bead Blasting
  • Tumbled
  • Powder coat
  • Vapor polishing
  • Custom: we evaluate custom requests on a case-by-case basis.
    Need Plastic CNC Machined Parts?
    Quick Links
    • Contact Us
    • Help Center
    • Our Story
    • Xometry Go Green
    • Careers
    • Legal
    • Press
    • Refer a Colleague
    Locations
    • 7529 Standish Place
      Suite 200
      Derwood, MD 20855
    • 7940 Cessna Avenue
      Gaithersburg, MD 20879
      240-252-1138
    • 7315 Wisconsin Ave
      Suite 300 East
      Bethesda, MD 20814
    • 446 East High Street
      Lexington, KY 40507
    • 11777 San Vicente Blvd
      Suite 747
      Los Angeles, CA 90049
    • 117 Wright Industrial Cove
      Jackson, TN 38301
    • Ada-Lovelace-Str. 9
      85521 Ottobrunn, Germany
      +49 32 22 109 8186
      www.xometry.eu
    Xometry Go Green Initiative
    2.0M+
    LBS OF C02 OFFSET
    Xometry
